Actually I bookmarked reForis and LuCI - so that message I shared is that what was shown with direct access. Cleared cache, used another browser - problem stayed.
Today all failed -
Luci Errors (direct link)
/usr/lib/lua/luci/dispatcher.lua:431: /etc/config/luci seems to be corrupt, unable to find section ‘main’
TypeError boardinfo.release is undefined
reForis (direct link)
TypeError: u.data.modules is undefined
Wifi Status light is gone, Wifi connection too - ethernet still working.
Then, if you have time, look at the latest 5.15 kernel, if it helps, and discuss it with the community when you are not able to reproduce it on your own.
Hi, do you need the crashlogs or test device? I have no problem testing new kernel - say with offloading compile time disabled. And I actually made a medkit a month ago and can share the link for download.
Hi, yes and yes - DM me for access credentials.
I’ve experimented yesterday with it, and it seems that the crash doesn’t happen without thought traffic. I’ve set the router outside of normal traffic flow and the crash doesn’t happen. Just accessing/pinging the device doesn’t trigger it either. But as soon as I connect again real internet upstream it goes into reboot loop. I’ve captured the logs and can make them available
until @mbehun figures out what is wrong in the kernel, we are once again reverting the kernel update and we will do release 7.0.1 without it in the meantime.
New changelog is as follows:
Updates
• openssh: Update to 9.8p1 (Security update)
• ethtool: Update to 6.6
• iproute2: Update to 6.7.0
• cronie: Update to 1.7.2
• schnapps: Update to 2.13.1 - support for Turris 1.x
Bug Fixes
• transmission: Downgrade to version 3 as new version seems to have some issues
• modem-manager-autosetup: Proceed with configuration even for unknown service providers
Breaking Changes
• Drop experimental mwifiex-nxp driver (not used anywhere)
I can offer MOX device for testing, if you’ll need it. For time being it"s spare testing device.
MOX classic, HBK branch, .5 GB, 2x WiFi, simple config.
Note it’s behind main Turris Omnia router
