Turris OS 6.0.3 is now released
That might be just a hiccup of the update server. Try it again later.
Update ok with no unplanned Internet connection or wifi outage. Reboot needed. Turris Omnia 2017, 1 GB RAM, dead eMMC, system running from mSATA SSD, original wifi cards. Storage plugin enabled, USB HDD shared over samba4 and minidlna, OpenVPN, PPtP VPN, minipots.
After upgrading to 6.0.3 tailscale package is available and working again. Version is a bit outdated (1.24.2), but i don`t care too much as it works fine :slight_smile:
Hello!
Are there any current plans when the problem with fwlogs (firewall logs) will be fixed? Still not working and reForis says failed under Sentinel State.
This is happening to me on an Omnia as well.
Boots up with all blue. Manually changing values in /sys/class/leds works fine, but neither the ‘rainbow’ command nor anything in /etc/config/rainbow seems to do anything.
Apparently Turris OS 6.0.4 is now released ?
(When I am not wrong ?)
Since update to 6.0.3 I can’t access the web interface anymore. lighttpd process doesn’t start and I get nothing in /var/log.
Maybe, but not in stable. 6.0.3 is still the latest stable version.
Turris OS 6.0.4 is only present in our development branch - HBK. It is not available in HBT(Testing) and HBS(Stable), yet.
Could you send us the contents of the /etc/config/rainbow file?
This is expected. SIDN feed was available on Turris OS 5, but it is not available on Turris OS 6 and the hbs feed currently contains TOS6. It is only a warning.
Here:
config led 'power'
        option status 'auto'
        option color '00ff44'
config led 'lan_4'
        option color 'ff22200'
config led 'lan_3'
        option color 'ff2200'
config led 'wlan_1'
        option color '4400ff'
config led 'wlan_2'
config led 'wlan_3'
        option color 'blue'
config led 'wan'
config led 'indicator_2'
config led 'indicator_1'
config led 'all'
        option brightness '032'
        option color 'white'
I deleted the file and started fresh on 6.0.x already. The strangest part is that LAN0-4 stay illuminated regardless of whether or not anything is plugged in.
hello
i send messages to support with a “please reflash” answer, i try to reup the support with no answer :confused: .
i can not upgrade to from 5x to 6.x
INFO:Queue removal of kmod-swconfig
INFO:Queue removal of kmod-ledtrig-default-on
INFO:Queue removal of kmod-crypto-pcompress
INFO:Downloading packages
line not found
line not found
line not found
WARN:Crash report of stack trace dump failed.
DIE:
download: Download of https://repo.turris.cz/hbs/omnia/packages/packages/**<each_intempt_a_different_package>**.ipk failed: Couldn't resolve host 'repo.turris.cz'
Aborted
resolve works at start but not at download stage, i now that we are two in that stuck with @tomskra
The other problem i have, is that i can not flash from stock, because it does not include neither USB tethering, neither QMI support. and i have no wire connection.
Please if someone read and have the same problem. maybe we can do something.
Maybe something like this can help, but I am not sure (it is from this manual Btrfs migration - Turris Documentation)
cd /tmp
wget https://repo.turris.cz/hbs/medkit/turris1x-medkit-latest.tar.gz
schnapps import -f turris1x-medkit-latest.tar.gz
schnapps rollback factory
reboot
You have just to edit that link in wget command.
I got the same error message in logs
And wired devices can’t get an IPV4 address.
No problem for wifi connections.
I’m back to version 5.4.3 for the moment.
dhcp-script.sh: /etc/resolver/dhcp_host_domain_ng.py: line 3: import: not found
 turris dnsmasq[5923]: script process exited with status 2
you will also need to set up http://192.168.1.1/cgi-bin/luci/admin/system/leds (or file /etc/config/rainbow) accordingly.
For more see How to control LED color & brightness, how to set all LEDs low brightness, or off, and survive reboots
nano /etc/lighttpd/lighttpd.conf
add
server.port = 88
server.bind = “Turris LAN IP”
It is set up, the software LED triggers never broke for me, it’s just the hardware-controlled LAN LED behavior as well as the colors that are broken for me.
@michalko58 Is this will install USB tethering and qmi related package?
I have no Ethernet neither SPF connection. So I need 4g modern or USB tethering support in the medikit
Use your phone as WiFi hotspot and configure Omnia to use it as WAN. And then download needed packages. And configure modem as Internet source. You can do all of that in LuCi
