Thanks a lot of your help, @moeller0 and @tohojo!
I haven’t restarted my Omnia, so here’s the output you asked for:
# tc -s qdisc
qdisc noqueue 0: dev lo root refcnt 2
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
qdisc mq 0: dev eth0 root
Sent 896 bytes 8 pkt (dropped 0, overlimits 0 requeues 0)
qdisc fq_codel 0: dev eth0 parent :8 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
maxpacket 0 drop_overlimit 0 new_flow_count 0 ecn_mark 0
new_flows_len 0 old_flows_len 0
qdisc fq_codel 0: dev eth0 parent :7 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :6 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :5 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth0 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc mq 0: dev eth1 root
Sent 1294976867366 bytes 1303232104 pkt (dropped 5, overlimits 0 requeues 2782676)
backlog 0b 0p requeues 2782676
qdisc fq_codel 0: dev eth1 parent :8 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :7 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :6 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :5 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth1 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
maxpacket 1522 drop_overlimit 0 new_flow_count 2272599 ecn_mark 0
qdisc mq 0: dev eth2 root
qdisc fq_codel 0: dev eth2 parent :8 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :7 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :6 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :5 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :4 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :3 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :2 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc fq_codel 0: dev eth2 parent :1 limit 10240p flows 1024 quantum 1514 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
qdisc noqueue 0: dev lan0 root refcnt 2
qdisc noqueue 0: dev lan1 root refcnt 2
qdisc noqueue 0: dev lan2 root refcnt 2
qdisc noqueue 0: dev lan3 root refcnt 2
qdisc noqueue 0: dev lan4 root refcnt 2
qdisc noqueue 0: dev br-lan root refcnt 2
qdisc fq_codel 0: dev wwan0 root refcnt 2 limit 10240p flows 1024 quantum 1500 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
Sent 82220016571 bytes 362225933 pkt (dropped 1, overlimits 0 requeues 46)
backlog 0b 0p requeues 46
maxpacket 1431 drop_overlimit 0 new_flow_count 11320 ecn_mark 0
qdisc fq_codel 0: dev wwan1 root refcnt 2 limit 10240p flows 1024 quantum 1500 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
Sent 36298 bytes 291 pkt (dropped 0, overlimits 0 requeues 0)
maxpacket 109 drop_overlimit 0 new_flow_count 1 ecn_mark 0
qdisc noqueue 0: dev br-wan root refcnt 2
qdisc noqueue 0: dev wlan2 root refcnt 2
qdisc fq_codel 0: dev vypr-us root refcnt 2 limit 10240p flows 1024 quantum 1500 target 5.0ms interval 100.0ms memory_limit 4Mb ecn
Sent 781571851 bytes 5988913 pkt (dropped 0, overlimits 0 requeues 0)
maxpacket 1310 drop_overlimit 0 new_flow_count 97 ecn_mark 0
new_flows_len 1 old_flows_len 0
# cat /etc/config/sqm
config queue 'eth1'
option enabled '0'
option interface 'eth1'
option download '85000'
option upload '10000'
option qdisc 'fq_codel'
option script 'simple.qos'
option qdisc_advanced '0'
option ingress_ecn 'ECN'
option egress_ecn 'ECN'
option qdisc_really_really_advanced '0'
option itarget 'auto'
option etarget 'auto'
option linklayer 'none'
But I actually need to check what eth1 is… OK. It’s the LAN, I guess, given the amount of data. RX bytes:149970699095 (139.6 GiB) TX bytes:1295009404691 (1.1 TiB)
If you did not see this meessage things should be fine…
I mean, being stuck for 10 minutes is far from fine.
Should it really take this long? It was the first time it actually succeeded in front of me (read: I never had patience to wait this long). All previous times I aborted it, disabled mwan3, then ran postinsts, then reenabled it. So something isn’t right if restarting the OS gets you there 10x faster than doing it “online”.
