MOX Classic, .5 GB, simple config.
reForis error:
AttributeError Python 3.7.8: /usr/bin/python3
Fri Sep 18 21:34:15 2020
A problem occurred in a Python script. Here is the sequence of function calls leading up to the error, in the order they occurred.
[/usr/lib/python3.7/site-packages/flup/server/fcgi_base.py](file:///usr/lib/python3.7/site-packages/flup/server/fcgi_base.py) in run (self=<flup.server.fcgi_base.Request object>)
[/usr/lib/python3.7/site-packages/flup/server/fcgi_base.py](file:///usr/lib/python3.7/site-packages/flup/server/fcgi_base.py) in handler (self=<flup.server.fcgi.WSGIServer object>, req=<flup.server.fcgi_base.Request object>)
[/usr/lib/python3.7/site-packages/reforis/main.py](file:///usr/lib/python3.7/site-packages/reforis/main.py) in call (self=<reforis.main.AppWrapper object>, environ={‘CONTENT_LENGTH’: ‘0’, ‘DOCUMENT_ROOT’: ‘/www’, ‘GATEWAY_INTERFACE’: ‘CGI/1.1’, ‘HTTPS’: ‘on’, ‘HTTP_ACCEPT’: ‘text/html,application/xhtml+xml,application/xml;…,/;q=0.8,application/signed-exchange;v=b3;q=0.9’, ‘HTTP_ACCEPT_ENCODING’: ‘gzip, deflate, br’, ‘HTTP_ACCEPT_LANGUAGE’: ‘cs-CZ,cs;q=0.9,en-US;q=0.8,en;q=0.7’, ‘HTTP_CONNECTION’: ‘keep-alive’, ‘HTTP_HOST’: ‘192.168.1.1’, ‘HTTP_REFERER’: ‘https://192.168.1.1/’, …}, start_response=<function BaseFCGIServer.handler..start_response>)
[/usr/lib/python3.7/site-packages/flask/app.py](file:///usr/lib/python3.7/site-packages/flask/app.py) in call (self=<Flask ‘reforis’>, environ={‘CONTENT_LENGTH’: ‘0’, ‘DOCUMENT_ROOT’: ‘/www’, ‘GATEWAY_INTERFACE’: ‘CGI/1.1’, ‘HTTPS’: ‘on’, ‘HTTP_ACCEPT’: ‘text/html,application/xhtml+xml,application/xml;…,/;q=0.8,application/signed-exchange;v=b3;q=0.9’, ‘HTTP_ACCEPT_ENCODING’: ‘gzip, deflate, br’, ‘HTTP_ACCEPT_LANGUAGE’: ‘cs-CZ,cs;q=0.9,en-US;q=0.8,en;q=0.7’, ‘HTTP_CONNECTION’: ‘keep-alive’, ‘HTTP_HOST’: ‘192.168.1.1’, ‘HTTP_REFERER’: ‘https://192.168.1.1/’, …}, start_response=<function BaseFCGIServer.handler..start_response>)
[/usr/lib/python3.7/site-packages/flask/app.py](file:///usr/lib/python3.7/site-packages/flask/app.py) in wsgi_app (self=<Flask ‘reforis’>, environ={‘CONTENT_LENGTH’: ‘0’, ‘DOCUMENT_ROOT’: ‘/www’, ‘GATEWAY_INTERFACE’: ‘CGI/1.1’, ‘HTTPS’: ‘on’, ‘HTTP_ACCEPT’: ‘text/html,application/xhtml+xml,application/xml;…,/;q=0.8,application/signed-exchange;v=b3;q=0.9’, ‘HTTP_ACCEPT_ENCODING’: ‘gzip, deflate, br’, ‘HTTP_ACCEPT_LANGUAGE’: ‘cs-CZ,cs;q=0.9,en-US;q=0.8,en;q=0.7’, ‘HTTP_CONNECTION’: ‘keep-alive’, ‘HTTP_HOST’: ‘192.168.1.1’, ‘HTTP_REFERER’: ‘https://192.168.1.1/’, …}, start_response=<function BaseFCGIServer.handler..start_response>)
[/usr/lib/python3.7/site-packages/flask/app.py](file:///usr/lib/python3.7/site-packages/flask/app.py) in handle_exception (self=<Flask ‘reforis’>, e=AttributeError("‘NullTranslations’ object has no attribute ‘json_catalog’"))
[/usr/lib/python3.7/site-packages/reforis/init.py](file:///usr/lib/python3.7/site-packages/reforis/init.py) in internal_error (error=AttributeError("‘NullTranslations’ object has no attribute ‘json_catalog’"))
[/usr/lib/python3.7/site-packages/flask/templating.py](file:///usr/lib/python3.7/site-packages/flask/templating.py) in render_template (template_name_or_list=‘errors/500.html’, **context={‘error’: AttributeError("‘NullTranslations’ object has no attribute ‘json_catalog’"), ‘g’: <flask.ctx._AppCtxGlobals object>, ‘request’: <Request ‘https://192.168.1.1/reforis/’ [GET]>, ‘session’: <FileSystemSession {’_permanent’: True}>})
[/usr/lib/python3.7/site-packages/flask/app.py](file:///usr/lib/python3.7/site-packages/flask/app.py) in update_template_context (self=<Flask ‘reforis’>, context={‘error’: AttributeError("‘NullTranslations’ object has no attribute ‘json_catalog’"), ‘g’: <flask.ctx._AppCtxGlobals object>, ‘request’: <Request ‘https://192.168.1.1/reforis/’ [GET]>, ‘session’: <FileSystemSession {’_permanent’: True}>})
[/usr/lib/python3.7/site-packages/reforis/init.py](file:///usr/lib/python3.7/site-packages/reforis/init.py) in add_translations_catalog_to_ctx ()
[/usr/lib/python3.7/site-packages/reforis/locale.py](file:///usr/lib/python3.7/site-packages/reforis/locale.py) in get_translations ()
AttributeError : ‘NullTranslations’ object has no attribute ‘json_catalog’
args = ("‘NullTranslations’ object has no attribute ‘json_catalog’",)
with_traceback =
