ALLNET ALL4781-VDSL2-SFP / Switch Modul (Mini-GBIC) appears not to be working with SFP.
- Changed the dbt link to sfp, rebooted
- Corrected via LuCI the WAN port association to eth1 (initially it was set to eth2), rebooted
The log stating
mdio_bus f1072004.mdio-mii: /soc/internal-regs/mdio@72004/sfp has invalid PHY address
and then
mdio_bus f1072004.mdio-mii: scan phy sfp at address 0
mdio_bus f1072004.mdio-mii: scan phy sfp at address 31
No issues with the modem/SFP in the 3.x branch
cynerd
23
It is not suggested to update from alpha2 because updater is going to remove device tree in /boot/dtb
. You can if you want recreate link to chosen device tree which will fix that. Problem is described in this issue: Conflict between updater cleanup and post* script (swap post* and cleanup in transaction) (#260) · Issues · Turris / updater / updater · GitLab
Updating from subsequent versions is fully possible and is suggested.
(Also you could edit your previous post instead of creating new one)
I managed to reproduce that. I will look in to that, thank you for reporting it.
