I found issue at page /foris/config/main/dns/ I have checked “Enable DHCP clients in DNS” and the next field filled by name. When “Test connection” button bottom is used, First result looks as excellent all OK including
|DNS|OK|
|DNSSEC|OK|
and than two following result all OK, but
|DNS|Error|
|DNSSEC|Error|
Why?
I noted /foris/config/main/netmetr_plugin/ show me radically diferent results from DSLreports.com
- Bufferbloat is missing (test of stability during data flow). I have here problem with quality and stability during upload for years (I am far away - 3,9Km from DSLam).
- Download speed on NetMetr is approx 2MB/s higher than shows DSLreports. The DSLreports value is closer to maximum value measured few months ago by professionalist (CETIN guy).
- Graph of DSLreports show me Waved upload speed curve, NetMetr graph is almost straight
- Graph of DSLreports show me on the beginning of both measurement slow values that increasing (up the hill), NetMetr almost straight.
IDEA:
On this page can be some option / recommandation for modification of QoS settings. To get better results for speed, connection stability, fastest reply, bufferbloat reduction, etc.
IDEA2: Can be the measurement times (now every whole hour) generated in some random periods far close that times?
PS: On netmetr.cz is the
|Network|LAN|
|Technology|LAN|
but I am connected trough xDSL (currently VDSL).
NOTE: not well stability can be a part of the problem turris-nevyuziva-plnou-rychlost-linky-pro-upload
