miska
January 9, 2018, 1:17pm
1
Dear Turris users,
we just released Turris OS 3.9.2 into RC branch and you can start testing it.
What it contains? Mostly bunch of bugfixes and security fixes.
musl & busybox: use stronger password hash by default
kernel: update to the latest version
netmetr: fix configuration reset
updater: various small fixes
openssl, libtiff, socat, rsync, coreutils, php, irssi: security updates
tvheadend: update to the latest version
knot-resolver & unbound: fixes in local domains
suricata: fix startup issue on some routers, performance tweaks
If your run into regressions, please let us know!
UPDATE: Updated HaaS and more resilient fix for netmetr configuration overwrite
Looks good, but does it contain a fix for the problem in the below thread? (I posted a patch in there you can use for reference)
Software
SW bugs discussion
Done some checking myself and from what I can conclude it’s not a problem with luci - it’s in hostapd. It’s true that wpa_group_rekey is set to 86400 by default in hostapd, but only in more recent versions, the version of hostapd used in Turris is...
Can’t see it on git, that’s why I asked.
jada4p
January 9, 2018, 9:03pm
4
Bendys
January 10, 2018, 7:08am
5
Turris 1.0 BRTFS, Openvpn client. OK
Perry
January 10, 2018, 3:19pm
6
Turris Omnia 2 GB + NAS (Time Machine).
DNS test and Netmetr in Foris over https in Safari doesn’t work
for me (with per session exception). I sent the team my solution.
Without https DNS test and netmetr works.
Looks like everything’s ok.
The same problem with uCollect … other things not installed (Netmeter) or working (Connectivity testing)
miska
January 12, 2018, 9:48am
8
it is not there yet, will be part of some future release, maybe a bigger one as it needs some testing whether it wouldn’t broke some older devices.
Nones
January 12, 2018, 7:36pm
9
Today was released the next RC version of TurrisOS 3.9.2
Pepe
January 15, 2018, 1:27pm
10
we released another RC, which fixes socat (ucollect) on our Turris 1.x routers.
