@ turris developers: please consider for future updates customers NOT using standard ports! Reasons for that are various and obvious.
I strongly recommend for future updates to tell us users what you exactly changed (have a look at Discussion: updater-configuration - SW tweaks - Turris forum)
This Update seems to crash my Turris Omnia completely!
I was busy a couple days and when I came back home yesterday I had no network connection in my house. I wasn’t able to even ping the Omnia, so I decided to recover with a previous settings-backup. Everything worked back normal.
Then today I received again the mail notification, that the Omnia was updated, but I need to restart the router to take effect of the update. At this point, my Omnia was already crashed. Same behavior - no internet connection, no ping, no dhcp, etc. There is even no link on the port (switch has no link to the router).
The Omnia LED are first normal (some are white blinking), then they turn to completely blue (all at the same time), then just power-LED and completely blue again.
Because I’m not able to connect to the Turris Omnia in this state, I’m not even know whats exactly the problem.
Contact our support with this as I am software not hardware guy. But generally we are probably not keen to letting you replace them on your own. It might void warranty.
Yes those errors are from packages post-install scripts. Opkg and OpenWRT doesn’t care too much about exit codes of their postinst script but we do. So this results to errors and spam in log. It’s mostly harmless. But yes annoying. But we really can’t be asked to fix every single package (specially when these are now historical versions of those packages and we want to catch up Lede).
But I see that there is something failing with Foris. I will look in to it.
How do you debug no link on port? Have you tried to setup static ip? Just to check that DHCP is working? Do you have some special dnsmasq setting? Some people here on forum reports that DHCP stopped working and it’s because they did some changes that prevented it from starting (collision of port 53 with kresd).
My Cisco switch says there is no link and the port ist down.
I’ve tried to setup a static IP on my notebook and plugged in the ethernet-cable directly to the router, yes. But I was not even able to ping! My notebook as well says the ethernet-cable is not connected (red status in network-settings). I’m not sure if it is a hardware-related issue. What does these blue LED mean?
I’ll check the DHCP issue as well, but can’t imaging this is the problem in this case.
Right now, after resetting and restoring the settings, the router is working again.
Tried to update on 3.8… Lost SQM/QOS GUI on luci… I tried to search luci-app-sqm via Luci… Nothing found, reverted to 3.7.5, as I dont trust SQM on 3.8 - see below
Those messages are not good: + /etc/init.d/sqm-scripts enable /usr/lib/opkg/info//sqm-scripts.postinst: /usr/lib/opkg/info/sqm-scripts.postinst-pkg: line 1: /etc/init.d/sqm-scripts: not found
/etc/rc.common: eval: line 1: get_dnsmasq_dhcp_script: not found
Possible changes of filenames, and left some old references?
/usr/bin/updater.sh
WARN:Request not satisfied to install package: dnsmasq
INFO:Queue install of libcurl/turris/7.54.1-3
INFO:Queue install of syslog-ng3/turris/3.10.1-4
INFO:Queue install of vixie-cron/turris/7-3
INFO:Queue install of opkg-trans/turris/59.3-1
INFO:Queue install of updater-ng/turris/59.3-1
INFO:Executing preupdate hooks...
INFO:Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:
Snapshot number 11 created
INFO:End of subprogram output
WARN:Config file /etc/syslog-ng.conf modified by the user. Backing up the new one into /etc/syslog-ng.conf-opkg
WARN:Config file /etc/config/updater modified by the user. Backing up the new one into /etc/config/updater-opkg
WARN:Config file /etc/updater/user.lua modified by the user. Backing up the new one into /etc/updater/user.lua-opkg
WARN:Config file /etc/updater/auto.lua modified by the user. Backing up the new one into /etc/updater/auto.lua-opkg
Output from syslog-ng3.postinst:
Command failed: Not found
WARN:Morpher is obsoleted! You have used morpher syntax with function: Package
INFO:Queue install of userlists/turris/7
INFO:Queue install of busybox/turris/1.25.1-5
INFO:Queue install of create_notification/turris/46
INFO:Queue install of kernel/turris/4.4.87-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-ipt/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-conntrack/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-nat/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-nathelper/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-base/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-uhci/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb3/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of hostapd-common/turris/2016-12-19-5
INFO:Queue install of kmod-cfg80211/turris/4.4.87+2017-01-31-2-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-mac80211/turris/4.4.87+2017-01-31-2-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ath/turris/4.4.87+2017-01-31-2-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ath10k/turris/4.4.87+2017-01-31-2-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ath9k-common/turris/4.4.87+2017-01-31-2-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ath9k/turris/4.4.87+2017-01-31-2-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-libphy/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-swconfig/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-switch-mvsw61xx/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-i2c-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-i2c-mv64xxx/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-serial/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-serial-wwan/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-serial-qualcomm/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-hwmon-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-thermal/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-thermal-armada/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-mmc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-mvsdio/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-wdt-orion/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-default-on/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-gpio/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-heartbeat/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-morse/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-netdev/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ipt-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-netfilter/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-oneshot/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-timer/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-transient/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ledtrig-usbdev/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of btrfs-progs/turris/4.11-2
INFO:Queue install of luasec/turris/0.6-1
INFO:Queue install of resolver-conf/turris/0.0.1-12
INFO:Queue install of luajit/turris/2.0.5-1
INFO:Queue install of libuv/turris/1.12.0-1
INFO:Queue install of knot-libzscanner/turris/2.5.3-1
INFO:Queue install of libgmp/turris/6.1.2-1
INFO:Queue install of libnettle/turris/3.3-1
INFO:Queue install of knot-libs/turris/2.5.3-1
INFO:Queue install of knot-resolver/turris/1.3.3-1
INFO:Queue install of libunbound/turris/1.6.4-5
INFO:Queue install of kmod-ipt-nat/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-llc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-stp/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-bridge/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ebtables/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of switch-branch/turris/1.1
INFO:Queue install of cert-backup/turris/9
INFO:Queue install of curl/turris/7.54.1-3
INFO:Queue install of opkg/turris/4
INFO:Queue install of dnsmasq/turris/2.73-5
INFO:Queue install of kmod-lib-crc-ccitt/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-slhc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ppp/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-pppox/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-pppoe/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of cznic-repo-keys-test/turris/4
INFO:Queue install of kmod-ipt-conntrack/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-conntrack6/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-ipt6/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ip6tables/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of uboot-envtools/turris/2014.10-3
INFO:Queue install of bind-libs/turris/9.10.5-P3-1
INFO:Queue install of bind-client/turris/9.10.5-P3-1
INFO:Queue install of bind-dig/turris/9.10.5-P3-1
INFO:Queue install of libkmod/turris/20-1
INFO:Queue install of pciutils/turris/3.5.1-1
INFO:Queue install of lsof/turris/4.89-2
INFO:Queue install of user_notify/turris/46
INFO:Queue install of libatsha204/turris/27
INFO:Queue install of rainbow-omnia/turris/3.1
INFO:Queue install of watchdog_adjust/turris/3
INFO:Queue install of schnapps/turris/1.1-1
INFO:Queue install of kmod-ipt-conntrack-extra/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ipt-ipopt/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ifb/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-sched-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-sched/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of sqm-scripts/turris/1.0.7-3
INFO:Queue install of l10n_supported/turris/1.2-1
INFO:Queue install of luci-proto-ipv6/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-proto-ppp/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-app-firewall/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-theme-bootstrap/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-lib-jsonc/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-lib-ip/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-lib-nixio/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-base/turris/git-17.212.24321-49c3edd-7
INFO:Queue install of luci-mod-admin-full/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of ntpdate/turris/4.2.8p9-2
INFO:Queue install of foris/turris/95.8-1
INFO:Queue install of turris-diagnostics/turris/7-2
INFO:Queue install of foris-diagnostics-plugin/turris/7-1
INFO:Queue install of foris-l10n-cs/turris/95.8-1
INFO:Queue install of foris-diagnostics-plugin-l10n-cs/turris/7-1
INFO:Queue install of turris-version/turris/3.8
INFO:Queue install of lighttpd-https-cert/turris/4
INFO:Queue install of kmod-nfnetlink/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-conntrack-netlink/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of wpad/turris/2016-12-19-5
INFO:Queue install of ath10k-firmware-qca988x/turris/2017-03-29-956e2609b7e42c8c710bba10ef925a5be1be5137-1
INFO:Queue install of luci-app-commands/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-base-en/turris/git-17.212.24321-49c3edd-7
INFO:Queue install of luci-i18n-commands-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-base-cs/turris/git-17.212.24321-49c3edd-7
INFO:Queue install of luci-i18n-commands-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of uclibcxx/turris/0.2.4-3
INFO:Queue install of kmod-sched-cake/turris/4.4.87+2016-12-19-70c8eb766d5afcf3cf187594b7cd776da92bee3c-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of tcpdump/turris/4.9.2-0
INFO:Queue install of kmod-tun/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-atm/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-pppoa/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-pcompress/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-hash/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-null/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-aead/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-manager/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-ecb/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-sha1/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-mppe/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-iptunnel/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-gre/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-iptunnel6/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ip6-tunnel/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-iptunnel4/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-sit/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-textsearch/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nf-nathelper-extra/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-mii/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-net/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-net-cdc-ether/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-net-rndis/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-wdm/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-net-qmi-wwan/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-serial-option/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of luci-proto-3g/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of kmod-scsi-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ata-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ata-ahci/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-fscache/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-dnsresolver/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-fcrypt/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-pcbc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-rxrpc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-afs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-autofs4/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-xor/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-raid6/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-zlib/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-lzo/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-crc32c/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-crc32c/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-btrfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-sha256/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-des/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-md4/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-md5/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-hmac/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-cifs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-configfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-cramfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-exfat/turris/4.4.87+git-20151121-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-exportfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-crc16/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-ext4/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-f2fs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-hfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-utf8/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-hfsplus/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-isofs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-jfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-minix/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-vfat/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-msdos/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-nfs-common/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-nfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-oid-registry/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-nfs-common-v4/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-nfsd/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-ntfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-lib-crc-itu-t/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-udf/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fs-xfs/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp1250/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp1251/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp437/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp775/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp850/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp852/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp862/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp864/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp866/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-cp932/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-iso8859-1/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-iso8859-13/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-iso8859-15/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-iso8859-2/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-iso8859-6/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-iso8859-8/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-nls-koi8r/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-mod/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-linear/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-multipath/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-raid0/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-raid1/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-raid10/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-md-raid456/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-storage/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb-storage-extras/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-usb2/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ata-ahci-platform/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-ata-mvebu-ahci/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-marvell-cesa/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of libext2fs/turris/1.43.5-1
INFO:Queue install of e2fsprogs/turris/1.43.5-1
INFO:Queue install of resize2fs/turris/1.43.5-1
INFO:Queue install of kmod-dm/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-fuse/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of badblocks/turris/1.43.5-1
INFO:Queue install of libnfsidmap/turris/0.25-0
INFO:Queue install of nfs-kernel-server/turris/2.1.1-1
INFO:Queue install of nfs-kernel-server-utils/turris/2.1.1-1
INFO:Queue install of ntfs-3g/turris/2015.3.14-1-fuseint
INFO:Queue install of ntfs-3g-utils/turris/2015.3.14-1-fuseint
INFO:Queue install of rsync/turris/3.1.2-2
INFO:Queue install of rsyncd/turris/3.1.2-2
INFO:Queue install of luci-app-hd-idle/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of kmod-input-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-sound-core/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of libffmpeg/turris/3.3.4-1
INFO:Queue install of minidlna/turris/1.1.5-5
INFO:Queue install of luci-app-minidlna/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-app-samba/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-hd-idle-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-minidlna-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-samba-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-hd-idle-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-minidlna-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-samba-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of kmod-crypto-authenc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-cryptodev/turris/4.4.87+1.8-mvebu-2
INFO:Queue install of kmod-crypto-user/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-cbc/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-wq/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-rng/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-iv/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-seqiv/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-ctr/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-gf128/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-xts/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-cmac/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-sha512/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-ccm/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-crypto-deflate/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of kmod-veth/turris/4.4.87+2-1-cb5e816fa6b1a6b5342df69755869d71-2
INFO:Queue install of luci-app-ahcp/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-app-mjpg-streamer/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-app-statistics/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci-app-tinyproxy/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-app-transmission/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci-app-upnp/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-app-wol/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-proto-openconnect/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-proto-relay/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-ahcp-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-firewall-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-statistics-en/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci-i18n-tinyproxy-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-transmission-en/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci-i18n-upnp-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-wol-en/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-ahcp-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-firewall-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-statistics-cs/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci-i18n-tinyproxy-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-transmission-cs/turris/git-17.212.24321-49c3edd-2
INFO:Queue install of luci-i18n-upnp-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue install of luci-i18n-wol-cs/turris/git-17.212.24321-49c3edd-1
INFO:Queue removal of dhparam
INFO:Queue removal of https-cert
INFO:Queue removal of knot-libknot
INFO:Queue removal of foris-openvpn-plugin-l10n-cs
INFO:Queue removal of mtd
INFO:Queue removal of vsftpd
INFO:Queue removal of ucollect-config
INFO:Queue removal of luci-app-sqm
INFO:Queue removal of getbranch-deploy
INFO:Queue removal of foris-tls-plugin-l10n-cs
INFO:Queue removal of unbound-anchor
INFO:Queue removal of knot-libdnssec
INFO:Queue removal of libatomic
INFO:Queue removal of tune2fs
INFO:Queue removal of jansson
WARN:Config file /etc/config/resolver modified by the user. Backing up the new one into /etc/config/resolver-opkg
WARN:Config file /etc/dnsmasq.conf modified by the user. Backing up the new one into /etc/dnsmasq.conf-opkg
WARN:Config file /etc/config/dhcp modified by the user. Backing up the new one into /etc/config/dhcp-opkg
WARN:Config file /etc/cron.d/schnapps modified by the user. Backing up the new one into /etc/cron.d/schnapps-opkg
WARN:Config file /etc/config/sqm modified by the user. Backing up the new one into /etc/config/sqm-opkg
WARN:Config file /etc/config/foris modified by the user. Backing up the new one into /etc/config/foris-opkg
WARN:Config file /etc/config/luci_statistics modified by the user. Backing up the new one into /etc/config/luci_statistics-opkg
Output from resolver-conf.postinst:
Output from knot-resolver.postinst:
+ [ -z ]
+ /etc/init.d/dnsmasq restart
udhcpc: started, v1.25.1
udhcpc: sending discover
udhcpc: no lease, failing
+ sleep 2
+ /etc/kresd/kresd.postinst.sh
+ uci -q get resolver.kresd.static_domains
+ stat_dom=
+ [ ! -z ]
+ /etc/init.d/resolver restart
+ rm /etc/kresd/kresd.postinst.sh
+ /etc/kresd/convert_config.sh
uci: Entry not found
+ rm /etc/kresd/convert_config.sh
Output from opkg.postinst:
+ [ deploy = deploy ]
+ VBRANCH=
+ sed -i /\(turris\|omnia\)_nightly_/d;s#\(https://repo\.turris\.cz/\(turris\|omnia\)\)[^/]*/#\1/# /etc/opkg/distfeeds.conf
+ uci set updater.override=override
+ VBRANCH=
+ uci set updater.override.branch=
+ true
+ exit 0
Output from dnsmasq.postinst:
Output from sqm-scripts.postinst:
+ [ -n ]
Output from foris.postinst:
+ [ -n ]
+ [ -f /www2/forris.pyc ]
+ /etc/init.d/lighttpd enable
+ /etc/init.d/lighttpd restart
Output from foris-diagnostics-plugin.postinst:
+ [ -n ]
Output from foris-l10n-cs.postinst:
+ [ -n ]
Output from foris-diagnostics-plugin-l10n-cs.postinst:
+ [ -n ]
Output from unbound.postrm:
ERROR:Failed operations:
luci-app-sqm/postrm:
WARN:Restart your device to apply all changes.
INFO:Executing reboot_required hooks...
INFO:Executed: /etc/updater/hook_reboot_required/50-create-notification.sh
warning: commands will be executed using /bin/sh
job 1 at Wed Sep 20 03:30:00 2017
Could not agree more with Marek. I was away on business travel when the auto-update happened, and it left the family without working Internet access for days. Family Acceptance Factor = 0. I am disabling auto update now. Thanks for helping out getting the DNS issues fixed now I am back home.
Great, got rid of luci-ssl. Found it was empty package anyway. Now the update to 3.8 finally proceeded.
BUT… sorry guys, you might write “luci-ssl is broken and not supported”, but YOU had it in YOUR repository and YOU broke it. (Reminds me of grammar used in military: “the things were done”, just to avoid mentioning WHO did it, to avoid being blamed…)
Yeah, I made “mistake” by installing luci-ssl some time ago (on my defense it was based on my previous experience with OpenWrt and nothing warned me it’s of no use on Omnia). But if this package is so useless, it should either not be present in Omnia repository at all, or you should maintain it as “unbroken dummy” (maybe with notice to user to uninstall it). Because this way it was really blocking my upgrade and I had little chance to find it, so I found best idea is to ask on this forum (and as I can see I was not alone!). Yeah, now it looks like I kind of complain about it (which I do not really enjoy)… I just believe you could do better next time.
And unfortunately, I hit another annoying trouble after upgrade: The lighttpd re-installed original configuration with self-signed certificate (which is by the way kicked out by Firefox and you cannot connect to configuration via https anymore). And ALL of my modifications in /etc/lighttpd/conf.d/ssl-enable.conf are gone away (like HSTS)! Why the hell was my custom configuration busted WITHOUT ANY NOTICE (and I don’t think I can set my SSL certificate some other way, than editing /etc/lighttpd/conf.d/ssl-enable.conf - so if the upgrade silently overwrites it, usual admin is really pi**ed off about it).
Together with changed kresd behavior noticed by others (need to change policy.FORWARD->policy.STUB) and changed knotd behavior too (also unnoticed during upgrade, only running knotc gave me the hint), I am really worried what other time bomb is hidden in the upgrade.
Seriously guys, cannot you make some “release notes” for major upgrades, listing all the changes which could break the things. Something like Debian guys do for their stable releases.
Having upgrades is great stuff, I really appreciate your approach of providing them. But PLEASE try to not break things silently next time.
I do have saved backups too.
But manual intervention is needed to restore things which I had running before - that kills the advantage of automatic upgrades. (And, I still do not know what other services were broken by upgrade, seems I will have to make my own tests of all my little customizations - that’s annoying, I prefer to have things not broken in first place.)
I am sorry. It seems like this is another package that missed our radar and was dropped silently by build system. Will hope to fix it with 3.8.1 release.
