I solved this by the following:
root@turris:~# updater.sh
DIE:
inconsistent: Package cshark requires package libustream-polarssl that is not available.
root@turris:~# opkg remove libustream-polarssl
No packages removed.
root@turris:~# opkg remove cshark
Removing package cshark from root…
INFO:Queue install of libcurl/turris/7.53.0-1
Thanks.
I missed your edit, but have just spotted it - and added the ocsp switch.
This hack is no longer required now as 3.7.1 version now contains package transmission-web once again.
Actually I still did get errors, even on 3.7.1, untill I added the ocsp switch.
But perhaps this was a symptom of having the hack installed?
I’ll have to revert the hack as soon as I get back to my router…
Not sure exactly what I did, but the update took place over the weekend. Rebooted and now the Omnia is at the latest version (3.7) !
I’ve been able to install and configure the required packages to get WPA2-Enterprise mode working . Happy to share my install notes (ie. install recipe) if there’s interest.
It would be a good idea, best even if you put them in the Turris wiki.
