I would prefer independent startup scripts (as with stock OpenWRT) for each DNS resolver, so I can choose precisely what I want. I use a mixed DNSmasq + Unbound setup: DNSmasq for DHCP everywhere and resolving on my internal networks, then it forwards DNS requests to Unbound. Unbound listens on the guest wifi interface and acts as a standalone resolver for both DNSmasq and guest clients.
The point is that this way the router can work independently of my ISP, and possibly compromised guest devices (e.g. unpatched Android devices of the kidsā friends) cannot map out my internal networks.
Hmm, today, I had a call from home that wifi was off. When I went there, 5GHz SSID was missing and 2.4 GHz one said Wrong password to correct password. I received mail notification about the update, so I had a suspicion. Reboot fixed it, thankfully.
DIE:
inconsistent: Package luci-ssl requires package libustream-polarssl that is not available.
Whatās strange, is that if try to install the packageā¦it seems it is already installedā¦
opkg install libustream-polarssl
Package libustream-polarssl (2015-07-09-c2d73c22618e8ee444e8d346695eca908ecb72d3) installed in root is up to date.
What are the steps to resolve the issue so that update can proceed?
Second restart solved problem, but I have new one. I use VPN (first setup was on 3.6.x FW) and everything works fine. When I connect today to my TO, trought VPN, and turn on Guest WiFi in Forris WiFi section, WEB was stop responding, so I can not connect to Forris (and LuCi). VPN looks connected, but no service was accessed (my NAS, RPi, ā¦). Reconnect VPN didnāt solve problem, SSH not working too. I am not home, so I can not unplug my TO from power and force restart.
I tried opkg remove libustream-polarssl, and then running update againā¦ and still have an issue. I get the following error now:
DIE:
inconsistent: Package uhttpd-mod-tls requires package libustream-polarssl that is not available.
As well, I think I am starting to get the dreaded segmentation fault error again when I try to install new packages
This same happened in Czech section.
Somebody from Turris team said that package luci-ssl is not tested and supported for now.
Now you can remove it. This dependency should be fixed in 3.7.1
Since the update I canāt connect to subaru-community.com First i thought it is a problem on their side, but isup.me says itās up and when I try to connect from my mobile connection I can reach the site. Any idea what causes this problem? Up til now itās only this one homepage.
Name resolution doesnāt seem to be the problem, as a ping directs me to 193.138.215.112 what is the correct IP, but I canāt get an answer, all packets are lost If I insert that IP directly into the browser it also times out.
Edit: when I try the ping feature of LuCI i get the error: ping: sendto: Operation not permitted
but only for the aforementioned url, no problem with, e.g., google.com
Edit2: before the rainbow cron-job starts everything works as itās supposed to do, afterwards I have the described problems with that single websiteā¦
We are sorry for inconvenience, but it seems that OpenWRT build system skipped build of transmission-web package. We hope that we will re-release it in one of the following fixup releases.
Edit: Sorry I missed new ocsp switch. Add it and it should I hope work.
Thanks.
I made the changes yesterday, and eagerly awaited the update.
This morning I got the following (Lots of lines omitted):
##### Update notifications #####
ā¢ Installed version git-17.125.68803-99f44f6-2 of package luci-app-transmission
ā¢ Installed version git-17.125.68803-99f44f6-2 of package luci-i18n-transmission-cs
ā¢ Installed version git-17.125.68803-99f44f6-2 of package luci-i18n-transmission-en
##### Error notifications #####
Updater failed:
ā¢ unreachable: https://api.turris.cz/openwrt-repo/archive/omnia/3.6.5/packages/telephony/Packages.gz: No OCSP response received
ā¢ unreachable: https://api.turris.cz/openwrt-repo/archive/omnia/3.6.5/packages/routing/Packages.gz: No OCSP response received
ā¢ unreachable: https://api.turris.cz/openwrt-repo/archive/omnia/3.6.5/packages/printing/Packages.gz: No OCSP response received
So it seems like one step forward, but also a step backward?
I just tried it on older Turris and same problem. (But Iām not regular visitor. Just tried your issue)
In Chrome it says:" ERR_CONNECTION_TIMED_OUT" and I tried it on cellular data and there it works.
root@turris:~# traceroute subaru-community.com
traceroute to subaru-community.com (193.138.215.112), 30 hops max, 38 byte packets
1traceroute: sendto: Operation not permitted
So itās not an isulated issue on my part where maybe I damaged a config, thank you very much!
Could you maybe restart your router and as soon as you have a connection try to reach the homepage? Because right after the reboot it works for me, only after the rainbow cron-job (ca. 1 Min after restart) is finished the first time (and my LEDs change color) I canāt reach the homepage anymore ā¦
