Dear Turris users,
we just released Turris OS 3.7.3 for all users of Omnia and Turris 1.x routers. It is a small update focused on security issues in tcpdump and also brings some our fixes.
Changes are:
tcpdump: seurity fixes
updater: fixes of minor bugs
pakon-guts: less verbosity in logs
kernel: security update to the latest version
You can find more info in testing topic and you can participate in testing next time. There will be 3.8 in following weeks. With way more features
Output from turris-version.postinst:
/usr/lib/opkg/info//turris-version.postinst: /usr/lib/opkg/info/turris-version.postinst-pkg: line 10: syntax error: unterminated quoted string
INFO:Executing postupdate hooks…
cat: can’t open ‘/tmp/user_notify/1501759917-32296/message_pl’: No such file or directory
This small bug means that you won’t be notified about changed packages in Foris’ Home tab. It won’t harm your system and it won’t appear in the next version.
One error occured at my Omnia but proceeded fine: /usr/lib/opkg/info//turris-version.postinst: /usr/lib/opkg/info/turris-version.postinst-pkg: line 10: syntax error: unterminated quoted string
I’m sorry for that error. It’s completely harmless, we made a typo (forgotten quotation mark) in new version notification when we were adding the last change to 3.7.3 release.
The error doesn’t affect any real package, just that notification.
But writing the changelog notification is pretty much the last thing to be done before release. And even though we tested the changed packages thoroughly, we didn’t think that something could go wrong with this notification, which is just a piece of text.
We’ll try to avoid such mistakes in future releases.
There is a small fix queued in updater’s master that should potentinally fix in on boot. If you are encountering it every day (updater is executed once a day) than please contact our support. There might be some problem with your Internet connection durring night time (time when updater is sheduled).
I get the message only after router restart required by firmware update (it does not display message every day) and this did not appear until previous update…
I did not mention earlier that I use Turris 1.0.
