As with the last update, i had to stop and disable /etc/init.d/ddns for the update to run through…
@alump I did figure out how to get DNS over TLS to Cloudflare (or other supported providers) working again. It seems that 3.11 added initial support for Foris configuration of DNS over TLS, but in a way that the previous manual configurations no longer work. It’s not clear why this wasn’t mentioned in the 3.11 release. Findings updated at gitlab here
Could you please edit community page https://doc.turris.cz/doc/en/public/dns_knot_misc to be up to date? It prevent future errors of potentionall new users…
@Jirka done, please check the page https://doc.turris.cz/doc/en/public/dns_knot_misc#using_dns_over_tls
2 posts were merged into an existing topic: Mdadm 4.0 monitor mode doesn’t send email notifications
Great! I cant check new method, as I dont have 3.11 yet, but its important that other users will not be confused!
Sorry about the late reply for Pakon, yesterday I spoke with @mpetracek.
It should be just a temporary issue, rebooting of the router should fix it.
My updater also hangs forever. My updater hangs at
DEBUG:backend.lua:1009 (script_run):Running postinst of firewall
DEBUG:src/lib/interpreter.c:320 (lua_run_generic):Command: /usr/lib/opkg/info//firewall.postinst configure
TRACE:src/lib/events.c:542 (run_command_a):Running command /usr/lib/opkg/info//firewall.postinst
I have started support ticket and waiting for the reply.
Seems the updater got stuck. Turris already reports version 3.11, but no notification has been sent out.
Also the updater is apparently still running.
~# ps | grep update
18191 root 10396 S python /usr/bin/updater-supervisor -d --rand-sleep
28296 root 302m S pkgupdate --batch --state-log --task-log=/usr/share/updater/updater-log --reexec
When I’ve tried to run it again it died
~# pkgupdate
INFO:Detected existing journal. Trying to recover it.
line not found
line not found
line not found
line not found
DIE:
[string "backend"]:1194: [string "backend"]:1185: Failed to lock the lock file //var/lock/opkg.lock: Resource temporarily unavailable
Aborted
Nothing special in the log
2018-12-10 16:07 TRANSACTION START
2018-12-10 16:07 install 20180409-2 ca-bundle
2018-12-10 16:07 install 7.62.0-2 libcurl
2018-12-10 16:07 install 60.4.6-3.6-2 updater-ng
2018-12-10 16:08 TRANSACTION START
2018-12-10 16:08 install 1.3-2 l10n_supported
2018-12-10 16:08 remove - python-jsonschema
2018-12-10 16:08 remove - python-functools32
2018-12-10 16:08 remove - updater-ng-py2-supervisor
2018-12-10 16:08 remove - python-uci
2018-12-10 16:08 remove - lcollect
Update: So I killed the process and run it again… It run for a while and got stuck again. This time with notification:
Error from 2018/12/12 17:11:48
Updater selhal:
[string “backend”]:1194: [string “backend”]:1185: Failed to lock the lock file //var/lock/opkg.lock: Resource temporarily unavailable
Thanks for the answer, @Pepe. I actually did not expect one, as most of my posts in this forum are not answered by Turris team (yes, I understand it’s because you are most likely busy with more important items, so this is a statement, not complaint).
I slightly scrambled that 4-letter word previously, to not be so straight - anyway it is not the most dirty word in my vocabulary, yet it describes my view of the updates, as this wasn’t the first situation when things broke for me after an update, and as I could see from forum, I am not alone who has this kind of troubles. Well, maybe I should rephrase it to make it more clear for others that it’s just purely my personal view, something like: “I’m too old for this…” (No! Not that word again! You are right, let’s not use that word, let’s just end the sentence with ellipsis.)
More seriously, my genesis took more than a year and it was like: Automatic updates on (cool!) -> troubles, troubles… it’s too much for me, so -> Updates after approvals (great option they added!) -> OK, OK… some small troubles which I could resolve (took me some time though)… some more troubles (not possible to resolve, but well, I just let it be as it’s not that important for me)… update to 3.11 HUH! not again! -> Turn off automatic updates completely.
IMHO root cause of this is not technical, but rather process issue. It happens repeatedly, we as users cannot help you with it (and maybe even those from Turris team working on technical aspects also cannot), and actually we users shouldn’t - CZ.NIC should sort these things out (unsolicited feedback here is undesired and wouldn’t work, I believe). So well, there came my decision to disable automatic updates for now. I don’t really like it, it’s just pragmatic decision.
The only thing I can do is to give my feedback here, so you see that my decision is not completely unjustified. Maybe this description helps a bit… Or maybe you will throw it to waste-basket, but that would be fine for me too, I just did my part :-).
Sure, people tend to give negative feedback and not give positive one… but… which one will help you more?
But OK, I like the HW of Omnia, it has a great potential. And I appreciate your answer too (and not only the fact that you replied me, but also the content, really). And once I reported Omnia bug via e-mail (that was kind of those things which happen from time to time and cannot be completely avoided), and it got resolved very quickly, next update brought solution and since then that particular bug is gone. Thanks.
I haven’t heard anything yet.
Did you try to stop and disable DDNS scripts?
Your issue might be different than anyone else had as you we’re updating from older versions. We’ll look into it.
My first update failed, update didn’t finish. I went back with schnapps to the old build and then disabled ddns, then update ran through fine. Enabled ddns again after update was finished and router had rebooted. Now everything is working like it should.
I had the problem that the update was going on for a very long time and it was waiting…
root@turris:~# pkgupdate --batch
WARN:Requested package daemon-watchdog that is missing, ignoring as requested.
WARN:Requested package https-cert that is missing, ignoring as requested.
WARN:Requested package luci-i18n-wshaper-cs that is missing, ignoring as requested.
WARN:Requested package luci-i18n-wshaper-en that is missing, ignoring as requested.
INFO:Queue install of ca-bundle/turris/20180409-2
INFO:Queue install of libcurl/turris/7.62.0-2
INFO:Queue install of updater-ng/turris/60.4.6-3.6-2
INFO:Executing preupdate hooks...
INFO:Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:
Snapshot number 152 created
INFO:End of subprogram output
INFO:Unpacking download packages
INFO:Checking for file collisions between packages
INFO:Running pre-install scripts and merging packages to root file system
WARN:Config file /etc/config/updater modified by the user. Backing up the new one into /etc/config/updater-opkg
INFO:Running post-install and post-rm scripts
INFO:Removing packages and leftover files
INFO:Cleaning up control files
INFO:Queue install of l10n_supported/turris/1.3-2
INFO:Queue install of userlists/turris/11.6
INFO:Queue install of python3-base/turris/3.6.0-3.6-3
INFO:Queue install of python3-light/turris/3.6.0-3.6-3
INFO:Queue install of python3-uci/turris/0.3-3.6-1
INFO:Queue install of updater-ng-supervisor/turris/60.4.6-3.6-2
INFO:Queue install of base-files/turris/195-r47055
INFO:Queue install of busybox/turris/1.29.3-1
INFO:Queue install of create_notification/turris/58
INFO:Queue install of kernel/turris/4.4.165-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-ipt/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-conntrack/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-nat/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-nathelper/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-base/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-uhci/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb3/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-cfg80211/turris/4.4.165+2017-01-31-4-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-mac80211/turris/4.4.165+2017-01-31-4-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ath/turris/4.4.165+2017-01-31-4-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ath10k/turris/4.4.165+2017-01-31-4-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ath9k-common/turris/4.4.165+2017-01-31-4-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ath9k/turris/4.4.165+2017-01-31-4-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-mmc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-sdhci/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-mmc-fsl-p2020/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-input-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-button-hotplug/turris/4.4.165-3-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-i2c-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-hwmon-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-hwmon-lm90/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-leds-gpio/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-input-gpio-keys/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of resolver-conf/turris/0.0.1-27
INFO:Queue install of libunbound/turris/1.8.1-2
INFO:Queue install of unbound/turris/1.8.1-2
INFO:Queue install of unbound-anchor/turris/1.8.1-2
INFO:Queue install of kmod-ipt-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-nat/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-conntrack/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of firewall/turris/2018-06-13
INFO:Queue install of kmod-llc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-stp/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-bridge/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ebtables/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of switch-branch/turris/1.6-1
INFO:Queue install of curl/turris/7.62.0-2
INFO:Queue install of opkg/turris/6
INFO:Queue install of kmod-lib-crc-ccitt/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-slhc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ppp/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-pppox/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-pppoe/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of cznic-repo-keys/turris/4.1
INFO:Queue install of cznic-repo-keys-test/turris/4.1
INFO:Queue install of updater-ng-localrepo/turris/60.4.6-3.6-2
INFO:Queue install of updater-ng-opkg/turris/60.4.6-3.6-2
INFO:Queue install of kmod-nf-conntrack6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-ipt6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ip6tables/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of openssh-client/turris/7.9p1-1
INFO:Queue install of openssh-keygen/turris/7.9p1-1
INFO:Queue install of openssh-client-utils/turris/7.9p1-1
INFO:Queue install of openssh-moduli/turris/7.9p1-1
INFO:Queue install of openssh-server/turris/7.9p1-1
INFO:Queue install of openssh-sftp-client/turris/7.9p1-1
INFO:Queue install of openssh-sftp-server/turris/7.9p1-1
INFO:Queue install of bind-libs/turris/9.11.5-2
INFO:Queue install of bind-client/turris/9.11.5-2
INFO:Queue install of bind-dig/turris/9.11.5-2
INFO:Queue install of libhavege/turris/1.9.4-1
INFO:Queue install of haveged/turris/1.9.4-1
INFO:Queue install of oneshot/turris/26
INFO:Queue install of libatsha204/turris/28-3.6-1
INFO:Queue install of user-notify/turris/58
INFO:Queue install of libintl-full/turris/0.19.4-6
INFO:Queue install of gettext/turris/0.19.4-6
INFO:Queue install of user-notify-l10n-cs/turris/1.0.7-1
INFO:Queue install of luci-proto-ipv6/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-proto-ppp/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-firewall/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-theme-bootstrap/turris/git-18.328.59464-9636605-1
INFO:Queue install of lighttpd/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-setenv/turris/1.4.50-3
INFO:Queue install of luci-lib-jsonc/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-lib-ip/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-lib-nixio/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-base/turris/git-18.328.59464-9636605-10
INFO:Queue install of luci-mod-admin-full/turris/git-18.328.59464-9636605-3
INFO:Queue install of lighttpd-mod-cgi/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-alias/turris/1.4.50-3
INFO:Queue install of luci/turris/git-18.328.59464-9636605-1
INFO:Queue install of python3-xml/turris/3.6.0-3.6-3
INFO:Queue install of python3-unittest/turris/3.6.0-3.6-3
INFO:Queue install of python3-sqlite3/turris/3.6.0-3.6-3
INFO:Queue install of python3-pydoc/turris/3.6.0-3.6-3
INFO:Queue install of python3-openssl/turris/3.6.0-3.6-3
INFO:Queue install of python3-ncurses/turris/3.6.0-3.6-3
INFO:Queue install of python3-multiprocessing/turris/3.6.0-3.6-3
INFO:Queue install of python3-lzma/turris/3.6.0-3.6-3
INFO:Queue install of python3-logging/turris/3.6.0-3.6-3
INFO:Queue install of python3-gdbm/turris/3.6.0-3.6-3
INFO:Queue install of python3-email/turris/3.6.0-3.6-3
INFO:Queue install of python3-distutils/turris/3.6.0-3.6-3
INFO:Queue install of python3-decimal/turris/3.6.0-3.6-3
INFO:Queue install of python3-dbm/turris/3.6.0-3.6-3
INFO:Queue install of python3-ctypes/turris/3.6.0-3.6-3
INFO:Queue install of python3-codecs/turris/3.6.0-3.6-3
INFO:Queue install of python3-asyncio/turris/3.6.0-3.6-3
INFO:Queue install of python3/turris/3.6.0-3.6-3
INFO:Queue install of python3-lib2to3/turris/3.6.0-3.6-3
INFO:Queue install of python3-dev/turris/3.6.0-3.6-3
INFO:Queue install of python3-setuptools/turris/22.0.5-3.6-2
INFO:Queue install of python3-ubus/turris/0.1-3.6-1
INFO:Queue install of foris-client-python3/turris/0.8-3.6-1
INFO:Queue install of lighttpd-mod-proxy/turris/1.4.50-3
INFO:Queue install of python3-prctl/turris/1.6.1-3.6-1
INFO:Queue install of python3-websocket-server/turris/0.4-3.6-6
INFO:Queue install of foris-ws/turris/0.2-3.6-1
INFO:Queue install of lighttpd-mod-redirect/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-fastcgi/turris/1.4.50-3
INFO:Queue install of python3-markupsafe/turris/1.0-3.6-1
INFO:Queue install of python3-jinja2/turris/2.10-3.6-1
INFO:Queue install of python3-flup/turris/1.0.3-3.6-1
INFO:Queue install of python3-bottle/turris/0.12.13-3.6-1
INFO:Queue install of python3-bottle-i18n/turris/0.1.5-3.6-3
INFO:Queue install of foris-common/turris/98.17-3.6-1
INFO:Queue install of foris-config/turris/98.17-3.6-1
INFO:Queue install of foris/turris/98.17-3.6-1
INFO:Queue install of kmod-ipt-conntrack-extra/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-ipopt/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ifb/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-sched-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-sched/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of turris-maintain/turris/3-4
INFO:Queue install of python3-turrishw/turris/0.4-3.6-1
INFO:Queue install of python3-jsonschema/turris/2.6.0-3.6-1
INFO:Queue install of foris-schema-python3/turris/0.7.1-3.6-1
INFO:Queue install of python3-pbkdf2/turris/1.3-3.6-3
INFO:Queue install of foris-controller/turris/0.10.12-3.6-1
INFO:Queue install of foris-controller-diagnostics-module/turris/0.4-3.6-1
INFO:Queue install of foris-diagnostics-plugin/turris/10.4-3.6-1
INFO:Queue install of turris-webapps/turris/1-5
INFO:Queue install of foris-l10n-cs/turris/98.17-3.6-1
INFO:Queue install of foris-diagnostics-plugin-l10n-cs/turris/10.4-3.6-1
INFO:Queue install of userlists-l10n-cs/turris/1.0.7-1
INFO:Queue install of nuci/turris/161-1
INFO:Queue install of nuci-nethist/turris/161-1
INFO:Queue install of turris-version/turris/3.11
INFO:Queue install of lighttpd-mod-openssl/turris/1.4.50-3
INFO:Queue install of kmod-nfnetlink/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-conntrack-netlink/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of vim-full/turris/8.1-1
INFO:Queue install of luci-app-commands/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-base-en/turris/git-18.328.59464-9636605-10
INFO:Queue install of luci-i18n-commands-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-base-cs/turris/git-18.328.59464-9636605-10
INFO:Queue install of luci-i18n-commands-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-nfnetlink-log/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-nflog/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nfnetlink-nfacct/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-ipset/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of ucollect-lib/turris/127
INFO:Queue install of kmod-nf-nat6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-nat6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-tproxy/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of ucollect-config/turris/127
INFO:Queue install of ucollect-prog/turris/127
INFO:Queue install of python3-libatsha204/turris/28-3.6-1
INFO:Queue install of nikola/turris/43-3.6-2
INFO:Queue install of kmod-tun/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of foris-controller-openvpn-module/turris/0.5-3.6-1
INFO:Queue install of foris-openvpn-plugin/turris/16.3-3.6-1
INFO:Queue install of foris-openvpn-plugin-l10n-cs/turris/16.3-3.6-1
INFO:Queue install of kmod-atm/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-pppoa/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-pcompress/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-hash/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-null/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-aead/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-manager/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-ecb/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-sha1/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-mppe/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-iptunnel/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-gre/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-iptunnel6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ip6-tunnel/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-iptunnel4/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-sit/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-textsearch/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nf-nathelper-extra/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-mii/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-net/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-net-cdc-ether/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-net-rndis/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-wdm/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-net-qmi-wwan/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-serial/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-serial-wwan/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-serial-option/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of ddns-scripts/turris/2.7.8-7
INFO:Queue install of luci-proto-3g/turris/git-18.328.59464-9636605-1
INFO:Queue install of python3-cachetools/turris/2.0.1-3.6-2
INFO:Queue install of kmod-nfnetlink-queue/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ipt-nfqueue/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of pakon/turris/1.2-16
INFO:Queue install of foris-controller-pakon-module/turris/0.2-3.6-1
INFO:Queue install of foris-pakon-plugin/turris/2.4.4-3.6-0
INFO:Queue install of foris-controller-data_collect-module/turris/1.0-3.6-3
INFO:Queue install of foris-data_collect-plugin/turris/1.1-3.6-1
INFO:Queue install of foris-client-bin/turris/0.8-3.6-1
INFO:Queue install of gnupg/turris/1.4.23-1
INFO:Queue install of ssbackups/turris/2.0-3.6-1
INFO:Queue install of foris-controller-ssbackups-module/turris/0.5-3.6-1
INFO:Queue install of foris-ssbackups-plugin/turris/8.3.1-3.6-2
INFO:Queue install of foris-ssbackups-plugin-l10n-cs/turris/8.3.1-3.6-2
INFO:Queue install of nuci-tls/turris/161-1
INFO:Queue install of kmod-scsi-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ata-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-ata-ahci/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-fscache/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-dnsresolver/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-fcrypt/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-pcbc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-rxrpc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-afs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-autofs4/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-xor/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-raid6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-zlib/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-lzo/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-crc32c/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-crc32c/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-btrfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-sha256/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-des/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-md4/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-md5/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-hmac/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-cifs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-configfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-cramfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-exfat/turris/4.4.165+git-20151121-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-exportfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-crc16/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-ext4/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-f2fs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-hfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-utf8/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-hfsplus/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-isofs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-jfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-minix/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-vfat/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-msdos/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-nfs-common/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-nfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-oid-registry/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-nfs-common-v4/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-nfsd/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-ntfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-lib-crc-itu-t/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-udf/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-xfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp1250/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp1251/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp437/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp775/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp850/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp852/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp862/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp864/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp866/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-cp932/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-iso8859-1/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-iso8859-13/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-iso8859-15/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-iso8859-2/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-iso8859-6/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-iso8859-8/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-nls-koi8r/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-mod/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-linear/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-multipath/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-raid0/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-raid1/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-raid10/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-md-raid456/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-storage/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-storage-extras/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb2-fsl/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb2/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-usb-storage-uas/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-fs-reiserfs/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of libcomerr/turris/1.44.3-1
INFO:Queue install of libss/turris/1.44.3-1
INFO:Queue install of libext2fs/turris/1.44.3-1
INFO:Queue install of e2fsprogs/turris/1.44.3-1
INFO:Queue install of resize2fs/turris/1.44.3-1
INFO:Queue install of foris-controller-storage-module/turris/0.2.3-3.6-0
INFO:Queue install of foris-storage-plugin/turris/1.2-3.6-2
INFO:Queue install of kmod-dm/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of mdadm/turris/4.0-4
INFO:Queue install of kmod-fuse/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of libfuse/turris/2.9.8-1
INFO:Queue install of fuse-utils/turris/2.9.8-1
INFO:Queue install of badblocks/turris/1.44.3-1
INFO:Queue install of luci-app-hd-idle/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-sound-core/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of libffmpeg/turris/4.0.2-0
INFO:Queue install of minidlna/turris/1.2.1-3
INFO:Queue install of luci-app-minidlna/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-samba/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-hd-idle-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-minidlna-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-samba-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-hd-idle-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-minidlna-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-samba-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-crypto-authenc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-cryptodev/turris/4.4.165+1.8-mpc85xx-2
INFO:Queue install of kmod-crypto-user/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-cbc/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-wq/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-rng/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-iv/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-seqiv/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-ctr/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-gf128/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-xts/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-cmac/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-sha512/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-ccm/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-crypto-deflate/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of kmod-veth/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of gnupg-utils/turris/1.4.23-1
INFO:Queue install of python3-pyserial/turris/2.7-3.6-2
INFO:Queue install of netmetr/turris/1.4-3.6-2
INFO:Queue install of foris-controller-netmetr-module/turris/0.4.1-3.6-1
INFO:Queue install of foris-netmetr-plugin/turris/4.4.1-3.6-1
INFO:Queue install of foris-netmetr-plugin-l10n-cs/turris/4.4.1-3.6-1
INFO:Queue install of luci-app-ahcp/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-mjpg-streamer/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-statistics/turris/git-18.328.59464-9636605-4
INFO:Queue install of luci-app-tinyproxy/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-transmission/turris/git-18.328.59464-9636605-2
INFO:Queue install of luci-app-upnp/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-wol/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-proto-openconnect/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-proto-relay/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-ahcp-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-firewall-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-statistics-en/turris/git-18.328.59464-9636605-4
INFO:Queue install of luci-i18n-tinyproxy-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-transmission-en/turris/git-18.328.59464-9636605-2
INFO:Queue install of luci-i18n-upnp-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-wol-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-ahcp-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-firewall-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-statistics-cs/turris/git-18.328.59464-9636605-4
INFO:Queue install of luci-i18n-tinyproxy-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-transmission-cs/turris/git-18.328.59464-9636605-2
INFO:Queue install of luci-i18n-upnp-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-wol-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-usb-printer/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of luci-app-ntpc/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-ntpc-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-ntpc-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-p910nd/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-p910nd-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-p910nd-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-spi-dev/turris/4.4.165+1-1-8da83cc2897da7a453071dbe9bfb6bff-1
INFO:Queue install of spidev-test/turris/4.4.165-4.4.165
INFO:Queue install of schnapps/turris/1.6-1
INFO:Queue install of turris-btrfs/turris/1.5-4
INFO:Queue install of luci-app-openvpn/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-openvpn-cs/turris/git-18.328.59464-9636605-1
INFO:Queue install of knot-libs/turris/2.7.3-1
INFO:Queue install of knot-host/turris/2.7.3-1
INFO:Queue install of ddns-scripts_nsupdate/turris/2.7.8-7
INFO:Queue removal of python-pyserial
INFO:Queue removal of user_notify_locales
INFO:Queue removal of foris-tls-plugin-l10n-cs
INFO:Queue removal of foris-wizard
INFO:Queue removal of python-bottle-i18n
INFO:Queue removal of python-ncclient
INFO:Queue removal of python-websocket-server
INFO:Queue removal of foris-client
INFO:Queue removal of python-ubus
INFO:Queue removal of foris-schema
INFO:Queue removal of python-jsonschema
INFO:Queue removal of python-pbkdf2
INFO:Queue removal of python-libatsha204
INFO:Queue removal of python-flup
INFO:Queue removal of python-prctl
INFO:Queue removal of python-functools32
INFO:Queue removal of updater-ng-py2-supervisor
INFO:Queue removal of python-uci
WARN:Config file /etc/passwd modified by the user. Backing up the new one into /etc/passwd-opkg
WARN:Config file /etc/sysupgrade.conf modified by the user. Backing up the new one into /etc/sysupgrade.conf-opkg
WARN:Config file /etc/config/system modified by the user. Backing up the new one into /etc/config/system-opkg
WARN:Config file /etc/shadow modified by the user. Backing up the new one into /etc/shadow-opkg
WARN:Config file /etc/shells modified by the user. Backing up the new one into /etc/shells-opkg
WARN:Config file /etc/inittab modified by the user. Backing up the new one into /etc/inittab-opkg
WARN:Config file /etc/group modified by the user. Backing up the new one into /etc/group-opkg
WARN:Config file /etc/config/resolver modified by the user. Backing up the new one into /etc/config/resolver-opkg
WARN:Config file /etc/config/firewall modified by the user. Backing up the new one into /etc/config/firewall-opkg
WARN:Config file /etc/config/sshd modified by the user. Backing up the new one into /etc/config/sshd-opkg
WARN:Config file /etc/config/user_notify modified by the user. Backing up the new one into /etc/config/user_notify-opkg
WARN:Collision with existing path. Moving /etc/config/ucitrack to /usr/share/updater/collided/etc/config
WARN:Config file /etc/config/luci modified by the user. Backing up the new one into /etc/config/luci-opkg
WARN:Config file /etc/config/foris modified by the user. Backing up the new one into /etc/config/foris-opkg
Output from ucollect-config.preinst:
cat: can't open '2': No such file or directory
WARN:Collision with existing path. Moving /etc/ddns/services_ipv6 to /usr/share/updater/collided/etc/ddns
WARN:Collision with existing path. Moving /etc/ddns/services to /usr/share/updater/collided/etc/ddns
WARN:Config file /etc/config/ddns modified by the user. Backing up the new one into /etc/config/ddns-opkg
WARN:Config file /etc/config/pakon modified by the user. Backing up the new one into /etc/config/pakon-opkg
WARN:Config file /etc/config/ssbackups modified by the user. Backing up the new one into /etc/config/ssbackups-opkg
WARN:Config file /etc/config/netmetr modified by the user. Backing up the new one into /etc/config/netmetr-opkg
Output from resolver-conf.postinst:
rm: can't remove '/var/run/resolver.pid': No such file or directory
Output from unbound.postinst:
+ '[' -n ]
+ /usr/share/unbound/postinst
+ /etc/init.d/resolver restart
+ sleep 20
Output from firewall.postinst:
Warning: Section 'turris_wan_6in4_rule' does not specify a protocol, assuming TCP+UDP
* Flushing IPv4 filter table
* Flushing IPv4 nat table
* Flushing IPv4 mangle table
* Flushing IPv4 raw table
* Flushing IPv6 filter table
* Flushing IPv6 nat table
* Flushing IPv6 mangle table
* Flushing IPv6 raw table
* Flushing conntrack table ...
* Populating IPv4 filter table
* Rule 'Allow-DHCP-Renew'
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Rule #7
* Rule #8
* Rule 'HTTPS'
* Rule 'Tokens'
* Rule 'guest dns rule'
* Rule 'guest dhcp rule'
* Rule 'vpn_turris_rule'
* Rule 'Maki-mobil_deny22-06'
* Redirect 'repeater'
* Forward 'lan' -> 'wan'
* Forward 'guest_turris' -> 'wan'
* Forward 'vpn_turris' -> 'lan'
* Forward 'lan' -> 'vpn_turris'
* Zone 'lan'
* Zone 'wan'
* Zone 'guest_turris'
* Zone 'vpn_turris'
* Populating IPv4 nat table
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv4 mangle table
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv4 raw table
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 filter table
* Rule 'Allow-DHCPv6'
* Rule 'Allow-MLD'
* Rule 'Allow-ICMPv6-Input'
* Rule 'Allow-ICMPv6-Forward'
* Rule #7
* Rule #8
* Rule 'HTTPS'
* Rule 'Tokens'
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 nat table
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_lan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_lan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_guest_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_guest_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_vpn_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_vpn_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_rule'
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 mangle table
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 raw table
* Zone 'lan'
* Zone 'wan'
* Zone 'vpn_turris'
* Set tcp_ecn to off
* Set tcp_syncookies to on
* Set tcp_window_scaling to on
* Running script '/etc/firewall.user'
* Running script '/usr/share/firewall/turris'
* Running script '/etc/firewall.d/with_reload/firewall.include.sh'
iptables: No chain/target/match by that name.
ip6tables: No chain/target/match by that name.
* Running script '/etc/firewall.d/without_reload/firewall.include.sh'
* Running script '/usr/share/miniupnpd/firewall.include'
Output from switch-branch.postinst:
+ '[' deploy '=' deploy ]
+ VBRANCH=
+ sed -i '/\(turris\|omnia\)_nightly_/d;s#\(https://repo\.turris\.cz/\(turris\|omnia\)\)[^/]*/#\1/#' /etc/opkg/distfeeds.conf
+ uci set 'updater.override=override'
+ VBRANCH=
+ uci set 'updater.override.branch='
+ uci commit updater.override.branch
+ true
+ exit 0
Output from opkg.postinst:
+ VBRANCH=
+ VBRANCH=
+ true
+ exit 0
Output from updater-ng-opkg.postinst:
+ '[' -f /etc/updater/conf.d/opkg-auto.lua ]
+ UPDATER_CONFIG=/etc/updater/conf.d/opkg-auto.lua
+ sed -n 's/^Package.*content *= *"file:\/\/\([^"]*\)".*/\1/p' /etc/updater/conf.d/opkg-auto.lua
+ read PKG
+ localrepo clean --repo auto
+ sed -i '/^Package.*content/d' /etc/updater/conf.d/opkg-auto.lua
+ rm -rf /usr/share/updater/local-pkgs
Output from haveged.postinst:
haveged: listening socket at 3
Output from oneshot.postinst:
+ SCRIPT_DIR=/usr/share/oneshot/scripts
+ COMPLETED_DIR=/usr/share/oneshot/completed
+ mkdir -p /usr/share/oneshot/completed
+ ls /usr/share/oneshot/scripts
+ sort
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0000-opkg-uri ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0001-opkg-no-testing ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0002-opkg-https ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0003-reset-updater-pkgs ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0004-set-root-passwd ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0005-slash-opkg ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0006-samba-norestart ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0007-ssh-enable ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0008-lighttpd-start-sooner ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0009-fix-old-banner ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0009-samba-norestart-again ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0010-disable-old-feed ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0011-no-directories-in-opkg-list ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0011-stable-new-removal ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0013-unbound-dont-enable-dnsmasq ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0014-turris-btrfs ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0015-wifi-path-fix ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0016-dhcpv6-unicast-disable ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0017-lighttpd-conf-fix ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0018-datacollect-userlist ]
+ echo 'Running one-shot script 0018-datacollect-userlist'
+ logger -t oneshot -p user.info
+ /usr/share/oneshot/scripts/0018-datacollect-userlist
+ touch /usr/share/oneshot/completed/0018-datacollect-userlist
+ echo 'Script 0018-datacollect-userlist complete'
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/012-omnia-wan-led ]
+ read SCRIPT
Output from foris-ws.postinst:
+ '[' -n ]
+ /etc/init.d/foris-ws enable
ln: /etc/rc.d/K1foris-ws: File exists
+ /etc/init.d/foris-ws restart
Output from foris-common.postinst:
+ '[' -n ]
+ /etc/init.d/lighttpd enable
+ /etc/init.d/lighttpd restart
Output from foris-config.postinst:
+ '[' -n ]
Output from foris-controller.postinst:
+ '[' -n ]
+ /etc/init.d/foris-controller enable
+ /etc/init.d/foris-controller restart
Output from foris-controller-diagnostics-module.postinst:
+ '[' -n ]
Output from foris-diagnostics-plugin.postinst:
+ '[' -n ]
Output from turris-webapps.postinst:
+ '[' -n ]
Output from foris-l10n-cs.postinst:
+ '[' -n ]
Output from foris-diagnostics-plugin-l10n-cs.postinst:
+ '[' -n ]
Output from nuci.postinst:
100 65 100 65 0 0 384 0 --:--:-- --:--:-- --:--:-- 411
Output from foris-controller-openvpn-module.postinst:
+ '[' -n ]
Output from foris-openvpn-plugin.postinst:
+ '[' -n ]
Output from foris-openvpn-plugin-l10n-cs.postinst:
+ '[' -n ]
grep: /proc/1008/cmdline: No such file or directory
So I tried to stopped and deactivated DDNS during the update. The update then proceeded on its own …
Output from pakon.postinst:
Output from foris-controller-pakon-module.postinst:
+ '[' -n ]
Output from foris-pakon-plugin.postinst:
+ '[' -n ]
Output from foris-controller-data_collect-module.postinst:
+ '[' -n ]
Output from foris-data_collect-plugin.postinst:
+ '[' -n ]
Output from foris-controller-ssbackups-module.postinst:
+ '[' -n ]
Output from foris-ssbackups-plugin.postinst:
+ '[' -n ]
Output from foris-ssbackups-plugin-l10n-cs.postinst:
+ '[' -n ]
grep: /proc/8560/cmdline: No such file or directory
Output from nuci-tls.postinst:
ln: /etc/rc.d/K1nuci-tls: File exists
Output from foris-controller-storage-module.postinst:
+ '[' -z ]
+ /etc/init.d/srv enable
+ mkdir -p /srv
Output from foris-storage-plugin.postinst:
+ '[' -n ]
Output from foris-controller-netmetr-module.postinst:
+ '[' -z ]
+ netmetr
==== rmbt eb279c46f-dirty ====
connecting...
connected with 3 flow(s) for dl; 3 flow(s) for ul
pretest downlink start... (min 1s)
pretest downlink end.
rtt_tcp_payload start... (11 times)
rtt_tcp_payload end.
downlink test start... (5s)
downlink test end.
pretest uplink start... (min 1s)
pretest uplink end.
uplink test start... (5s)
uplink test end.
disconnecting.
dl_throughput_mbps = 23.410903
ul_throughput_mbps = 35.809081
Exiting.
Output from foris-netmetr-plugin.postinst:
+ '[' -n ]
Output from foris-netmetr-plugin-l10n-cs.postinst:
+ '[' -n ]
Output from foris-tls-plugin-l10n-cs.postrm:
+ '[' -n ]
Output from foris-wizard.postrm:
+ '[' -n ]
WARN:Restart your device to apply all changes.
INFO:Executing reboot_required hooks...
INFO:Executed: /etc/updater/hook_reboot_required/50-create-notification.sh
INFO:Executing postupdate hooks...
INFO:Subprogram output: /etc/updater/hook_postupdate/05_schnapps.sh:
Snapshot number 153 created
ERROR:Subprogram output: /etc/updater/hook_postupdate/05_schnapps.sh:
Warning, could not drop caches
ERROR:End of subprogram output
INFO:Subprogram output: /etc/updater/hook_postupdate/10_kernel-install:
/boot/zImage /boot/tefi/zImage differ: char 5, line 1
INFO:Executed: /etc/updater/hook_postupdate/99_approvals_cleanup
INFO:Executed: /etc/updater/hook_postupdate/update_alternatives.sh
Everything seems to be all right.
Updated to 3.11 using a medkit to start from scratch.
Two observations:
- Luci seems really slow. Opening page takes 5-6 sec. After that some pages show “collecting data” for another 5-6 additional seconds. This used to be fast!!!
Foris on the other feels/is quick(er). - uPnP doesn’t seems to work, at least it doesn’t show which IP’s are using uPnP. (There are no active redirects). All tough i know for sure uPnP is used.
I have a couple of posts above about UPnP.
Make sure the three packages, minidlna, miniupnpc and miniupnpd are installed and then make sure they are all “enabled” under “System” “Startup”.
The busybox version is apparently less capable than the stand-alone package/daemon. I am used to run local ntp server for the network clients an seeing
config timeserver 'ntp'
option enable_server '1'
one would reckon that provides a local server. Yet restaring system
is not yielding a local ntp server listening at udp port 123. So what is this option for then respectively how to provide a local ntp server other than sysntpd
for which I could not trace any config options?
I hope that does not rate as being another exotic case… considering that apparently one or another user been impacted as well.
On a side note NTP is recommending not to point to single NTP upstream servers, for a variety of reasons, but to server pools rather.
Having put the below config system
starts without any validation error but are those options actually parsed/applied or rather not as it happens with option enable_server '1'
Summary
option enabled '1'
option interface_listen '192.168.112.12'
option interface_ignore 'wildcard'
list restrict 'default kod notrap nomodify nopeer limited'
list restrict 'source notrap nomodify noquery'
list restrict '127.0.0.1'
option interval '600'
list pool '0.europe.pool.ntp.org iburst'
list pool '0.debian.pool.ntp.org iburst'
list pool '0.openwrt.pool.ntp.org iburst'
list pool '0.asia.pool.ntp.org iburst'
list pool '0.north-america.pool.ntp.org iburst'
list pool '1.europe.pool.ntp.org iburst'
list pool '1.debian.pool.ntp.org iburst'
list pool '1.openwrt.pool.ntp.org iburst'
list pool '1.asia.pool.ntp.org iburst'
list pool '1.north-america.pool.ntp.org iburst'
list pool '2.europe.pool.ntp.org iburst'
list pool '2.debian.pool.ntp.org iburst'
list pool '2.openwrt.pool.ntp.org iburst'
list pool '2.asia.pool.ntp.org iburst'
list pool '2.north-america.pool.ntp.org iburst'
option driftfile '/var/lib/ntp/ntp.drift'
list filegen_loopstats_file_loopstats_type_day '1'
list filegen_peerstats_file_peerstats_type_day '1'
list filegen_clockstats_file_clockstats_type_day '1'
Thanks, I got cloudflare working again by following your steps on gitlab. I just replaced “restart of router” with “restart resolver service”.
