I havenât been able to reproduce it yet. What âstatusâ does dig return when you see no address? SERVFAIL or NOERROR (or other)?
Possibly related: in the last couple of days I noticed that my Omnia-connected PC experiences recurring short periods when IPv6 doesnât work, but so far I havenât tracked the cause (it might not be Omnia-related at all; I had similar ISP problems already). And itâs latest 3.9, not 3.10 yet.
Is this a solution for the âvpn certificate generatingâ issue?. How do you implement the solution? Adding the code to the end of the /usr/bin/turris-cagen-status file? Thanks for making it clear.
constant flooding with message lines these
[106967.592390] sit: non-ECT from some remove IP with TOS=0x2
[106967.700057] sit: non-ECT from some remove IP with TOS=0x6
[106967.726341] sit: non-ECT from some remove IP with TOS=0x6
[106967.726353] sit: non-ECT from some remove IP with TOS=0x6
[106968.123551] sit: non-ECT from some remove IP with TOS=0x9
[106968.123565] sit: non-ECT from some remove IP with TOS=0x2
[106968.139221] sit: non-ECT from some remove IP with TOS=0x9
kresd does not always do what its told, from custom.conf in /etc/kresd
local forward_rule = policy.add(policy.suffix(policy.STUB(âinternaldns ipâ), policy.todnames({âmylocaldomainâ})))
policy.del(forward_rule.id)
table.insert(policy.rules, 1, forward_rule)
Sometime it seems to work, other time not. Have not been able to find the reason for this.
It returns SERVFAIL. I wonder if it is timing sensitive somehow, otherwise it wouldnât make sense that restarting kresd would get it to return the AAAA correctly. if I donât restart kresd it always returns SERVFAIL for this request.
SERVFAIL may mean many things, including bad DNSSEC records, but in many cases the reasons are transient and subsequent queries may succeed. Short IPv6 outages would explain that, but itâs hard to guess just from this. Iâll first see if I can reproduce something like this. I assume the problem doesnât really constrain your regular internet usage.
youâre right, itâs not a problem for routine internet use. Very few sites are ipv6 only like this one. Iâd be surprised if this site has bad DNSSEC records, because then restarting kresd would not fix that. The way I originally found this issue was via the test-ipv6.com test site, which started to return that DNS to ipv6 only sites didnât work anymore after I upgraded to 3.10, it uses this site as part of its tests.
Three things did not work properly the rest went smoothly.
Pakon does not do anything, but everything is started (same problems as @DIKKEHENK)
In foris, the tab for Wi-Fi is broken, get a page full of error messages. But it works in LuCI.
ddns-scripts is deprecated (2.7.3-1) and asked me to install the latest version, because some functions would not work. Have version 2.7.7-5 installed and it works.
Pakon doesnât work for me either. The icons next to the âfromâ and âtoâ fields arenât displaying correctly (maybe i am missing a font here on linux?) but most important i get a js alert âFailed to load dataâ and, of course, no data, just an endless spinner.
I am just getting Updater failed: Unknown error error mails from my Omnia Turris since about 3 days. So I did:
% [ -r /tmp/crl.pem ] || get-api-crl
% ls -l /tmp/crl.pem
-rw-r--r-- 1 root root 1080 May 13 21:45 /tmp/crl.pem
Although I think pkgupdate will do this anyway.
Still I get this on calling pkgupdate:
% pkgupdate
WARN:Script file:///usr/share/updater/localrepo/localrepo.lua not found, but ignoring its absence as requested
WARN:Request not satisfied to install package: luci-app-minidlna
WARN:Request not satisfied to install package: luci-app-mjpg-streamer
WARN:Request not satisfied to install package: luci-app-tinyproxy
WARN:Request not satisfied to install package: luci-app-transmission
WARN:Request not satisfied to install package: luci-i18n-minidlna-en
WARN:Request not satisfied to install package: luci-i18n-tinyproxy-en
WARN:Request not satisfied to install package: luci-i18n-transmission-en
WARN:Request not satisfied to install package: luci-i18n-minidlna-de
WARN:Request not satisfied to install package: luci-i18n-tinyproxy-de
WARN:Request not satisfied to install package: luci-i18n-transmission-de
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Requested package luci-i18n-wshaper-en that is not available.
Notifications are fixed in 3.10 release you just have to update to it.
But either way. Sorry for being rude but RTFM. It tells you what is wrong. Package luci-i18n-wshaper-en is not available. You have to remove it, otherwise update wonât continue. I looked to repository and wshaper is probably no longer available. Itâs pretty old package and was long time ago obsoleted by sqm so it was probably dropped.
Next time please do not assume that I did not read something, unless you can be sure of that. I certainly read the error message, but I did not know that pkgupdate is not capable to remove obsolete packages like any modern Linux distribution package manager, especially if it is an automatically installed one. Removed manually from /etc/updater/conf.d/opkg-auto.lua. I even looked for the package name in /etc/updater, but not recursively. Thanks for your help.
(Also learned that upgrading can cut off current connections, even without the reboot to activate a kernel update. I was not aware of that.)
