we just released Turris OS 3.10.3. Most of the stuff is really minor, the main reason for release is updated Unbound that includes workaround for some broken Microsoft DNS servers. So it mainly affects Turris 1.X users but there are few minor fixes for everybody. Full release notes are as follows:
nextcloud: update
pakon, storage: minor fixes
kernel, unbound: update and minor fixes
As always, if you encounter any issues, let us know.
INFO:Running post-install and post-rm scripts
Output from unbound.postinst:
+ [ -n ]
+ /usr/share/unbound/postinst
+ /etc/init.d/resolver restart
Command failed: Not found
[1530092262] unbound-control[25534:0] fatal error: could not send: Connection reset by peer
[1530092283] unbound-control[25809:0] fatal error: could not recv: Connection reset by peer
Unfortunately this happens to me every single time. I cannot bring the wifi-up, if I do the router always reboots after a period of time between a few seconds and a minute. The error is exactly the same as you posted. Tried 3.10.1, 3.10.2 and now 3.10.3 and they all trigger the same error. Any version older than that works flawlessly.
Can you update the wireguard package?
Somebody said it will be a goal for 3.10.
Some of us donât really care about Foris,Pakon,Nextcloud and all other stuff.
Details of our installation are:
OS: Turris Omnia (TO) 3.10.3
NUT version: 2.7.4-5
Installation method: from package
UPS device: EATON UPS 5SC 500i , 230V, 350W, 500VA, USB bought in jun 2018
If you connect to TO UPS via USB, the /dev/hidraw0 device will be created.
No any programs from NUT package is not running.
When I run:
/lib/nut/usbhid-ups -a qnapups
Network UPS Tools - Generic HID driver 0.41 (3.10-76-gd2caa7d) USB communication driver 0.33
kill: No such process
Using subdriver: MGE HID 1.39
device /dev /hidraw0 is deleted.
Now Iâm ordering to shut down UPS:
/lib/nut/usbhid-ups -a qnapups -k
Network UPS Tools - Generic HID driver 0.41 (3.10-76-gd2caa7d) USB communication driver 0.33 Can not claim USB device [0463: ffff]: No such file or directory
After update to 3.10.3 pakon stopped to work.
I have tried to tips already available in forum such as py script to create database,reinstall and restarts,but nothing helped.
This is what I get in console:
root@turris:~# pakon-show
File "/usr/bin/pakon-show", line 133, in
data=json.loads(response)
File "/usr/lib/python3.5/json/__init__.py", line 319, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.5/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.5/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
root@turris:~#
one question to the release info: Why is it in Community Office section? The RC post was in Software and the czech-notes is in Software[CZ]. Everytime i clicked a way the banner and then want so search for the notes to read again, i am looking into Software (as it is softwareâŚ).
Anyway, the update was smooth for me and Storage Page bug was fixed for me.
