The update from 3.10 to 3.10.1 went very weird on my Omnia:
My setting is that updates have to be approved (for some time, it’s not new setting).
There came update of 2 packages only first (libcurl and updater-ng), which I approved, they finished, and soon afterwards there was another update of many other packages (kernel, kernel modules,and some more).
When I approved that 2nd update in Foris yesterday, it showed update is running… and kept like that for long. Way too long. I expected it should ask for restart after update (kernel and modules were updated), but it did not.
Today, more than 24 hours afterwards, Foris still showed it as running. It seemed too much for me, so I restarted Omnia.
Now it shows it is on 3.10.1, but there was no notice about sucessful update, no e-mail, nothing.
I listed schnapps and it looks like this:
134 | pre | 2018-06-10 16:40:09 +0800 | Automatic pre-update snapshot
135 | post | 2018-06-10 16:40:57 +0800 | Automatic post-update snapshot
136 | pre | 2018-06-10 16:46:17 +0800 | Automatic pre-update snapshot
The syslog from Omnia is sent to my Linux server, so I can see there related events:
Jun 10 16:40:09 turris updater[8560]: updater.lua:100 (Globals): Queue install of updater-ng/turris/60.2.4-2
Jun 10 16:40:09 turris updater[8560]: src/pkgupdate/main.c:273 (main): Executing preupdate hooks…
Jun 10 16:40:09 turris updater[8560]: src/lib/util.c:160 (exec_dir_callback): Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:#012Snapshot number 134 created
Jun 10 16:40:09 turris updater[8560]: src/lib/util.c:161 (exec_dir_callback): End of subprogram output
Jun 10 16:40:09 turris updater[8560]: src/lib/util.c:164 (exec_dir_callback): Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:#012Mount is denied because the NTFS volume is already exclusively opened.#012The volume may be already mounted, or another software may use it which#012could be identified for example by the help of the ‘fuser’ command.
Jun 10 16:40:09 turris updater[8560]: src/lib/util.c:165 (exec_dir_callback): End of subprogram output
(By the way, I have no NTFS volume. I really don’t know what that weird message means.)
Then there is later:
Jun 10 16:40:57 turris updater[8560]: src/lib/util.c:160 (exec_dir_callback): Subprogram output: /etc/updater/hook_postupdate/05_schnapps.sh:#012Snapshot number 135 created
Jun 10 16:40:57 turris updater[8560]: src/lib/util.c:161 (exec_dir_callback): End of subprogram output
Jun 10 16:40:57 turris updater[8560]: src/lib/util.c:164 (exec_dir_callback): Subprogram output: /etc/updater/hook_postupdate/05_schnapps.sh:#012Mount is denied because the NTFS volume is already exclusively opened.#012The volume may be already mounted, or another software may use it which#012could be identified for example by the help of the ‘fuser’ command.
The snapshots 134 and 135 seem to correspond to that small 1st update, the snapshot 136 seems to be done right at the start of the 2nd (bigger) update:
> Jun 10 16:46:17 turris updater[11256]: src/pkgupdate/main.c:273 (main): Executing preupdate hooks...
> Jun 10 16:46:17 turris kernel: [566388.147019] sit: non-ECT from 172.21.255.128 with TOS=0xe
> Jun 10 16:46:17 turris updater[11256]: src/lib/util.c:160 (exec_dir_callback): Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:#012Snapshot number 136 created
> Jun 10 16:46:17 turris updater[11256]: src/lib/util.c:161 (exec_dir_callback): End of subprogram output
> Jun 10 16:46:17 turris updater[11256]: src/lib/util.c:164 (exec_dir_callback): Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:#012Mount is denied because the NTFS volume is already exclusively opened.#012The volume may be already mounted, or another software may use it which#012could be identified for example by the help of the 'fuser' command.
> Jun 10 16:46:17 turris updater[11256]: src/lib/util.c:165 (exec_dir_callback): End of subprogram output
> Jun 10 16:46:17 turris updater[11256]: transaction.lua:68 (fun): Unpacking download packages
> Jun 10 16:46:35 turris updater[11256]: transaction.lua:138 (fun): Checking for file collisions between packages
> Jun 10 16:46:35 turris updater[11256]: transaction.lua:156 (fun): Running pre-install scripts and merging packages to root file system
> Jun 10 16:46:41 turris updater[11256]: backend.lua:838 (pkg_merge_files): Config file /etc/config/user_notify modified by the user. Backing up the new one into /etc/config/user_notify-opkg
> Jun 10 16:46:43 turris updater[11256]: backend.lua:838 (pkg_merge_files): Config file /etc/config/luci modified by the user. Backing up the new one into /etc/config/luci-opkg
> Jun 10 16:46:46 turris updater[11256]: backend.lua:838 (pkg_merge_files): Config file /etc/config/foris modified by the user. Backing up the new one into /etc/config/foris-opkg
> Jun 10 16:46:50 turris updater[11256]: backend.lua:838 (pkg_merge_files): Config file /etc/config/luci_statistics modified by the user. Backing up the new one into /etc/config/luci_statistics-opkg
> Jun 10 16:46:59 turris updater[11256]: backend.lua:838 (pkg_merge_files): Config file /etc/config/storage modified by the user. Backing up the new one into /etc/config/storage-opkg
> Jun 10 16:47:01 turris /usr/sbin/cron[2809]: (*system*) RELOAD (/etc/cron.d/schnapps)
> Jun 10 16:47:01 turris /usr/sbin/cron[2809]: (*system*) RELOAD (/etc/cron.d/server-uplink.cron)
> Jun 10 16:47:01 turris /usr/sbin/cron[2809]: (*system*) RELOAD (/etc/cron.d/fstrim)
> Jun 10 16:47:01 turris /usr/sbin/cron[2809]: (*system*) RELOAD (/etc/cron.d/updater)
> Jun 10 16:47:01 turris /usr/sbin/cron[2809]: (*system*) BAD FILE MODE (/etc/cron.d/user_notify.cron)
> Jun 10 16:47:03 turris ddns-scripts[779]: rackspace: PID '779' terminated by 'SIGTERM' at 2018-06-10 16:47:03
> Jun 10 16:47:03 turris ddns-scripts[780]: henet_endpoint: PID '780' terminated by 'SIGTERM' at 2018-06-10 16:47:03
> Jun 10 16:47:03 turris updater[11256]: backend.lua:838 (pkg_merge_files): Config file /etc/config/ddns modified by the user. Backing up the new one into /etc/config/ddns-opkg
> Jun 10 16:47:06 turris updater[11256]: transaction.lua:199 (fun): Running post-install and post-rm scripts
> Jun 10 16:47:06 turris modprobe: ip_tables is already loaded
> Jun 10 16:47:06 turris modprobe: x_tables is already loaded
> Jun 10 16:47:06 turris modprobe: nf_conntrack is already loaded
> Jun 10 16:47:06 turris modprobe: nf_conntrack_rtcache is already loaded
> Jun 10 16:47:06 turris modprobe: nf_defrag_ipv4 is already loaded
> Jun 10 16:47:06 turris modprobe: nf_conntrack_ipv4 is already loaded
> Jun 10 16:47:06 turris modprobe: nf_nat is already loaded
> Jun 10 16:47:06 turris modprobe: nf_nat_redirect is already loaded
> Jun 10 16:47:06 turris modprobe: nf_nat_ipv4 is already loaded
> Jun 10 16:47:06 turris modprobe: nf_conntrack_ftp is already loaded
> Jun 10 16:47:06 turris modprobe: nf_nat_ftp is already loaded
> Jun 10 16:47:06 turris insmod: module is already loaded - usb-common
> Jun 10 16:47:06 turris insmod: module is already loaded - usbcore
> Jun 10 16:47:06 turris insmod: module is already loaded - uhci-hcd
> Jun 10 16:47:06 turris insmod: module is already loaded - xhci-hcd
> Jun 10 16:47:06 turris insmod: module is already loaded - xhci-pci
> Jun 10 16:47:06 turris insmod: module is already loaded - xhci-plat-hcd
> Jun 10 16:47:06 turris insmod: module is already loaded - ath10k_core
> Jun 10 16:47:06 turris insmod: module is already loaded - ath10k_pci
> Jun 10 16:47:06 turris insmod: module is already loaded - ath9k
> Jun 10 16:47:07 turris modprobe: usbserial is already loaded
> Jun 10 16:47:07 turris modprobe: usb_wwan is already loaded
> Jun 10 16:47:07 turris modprobe: qcserial is already loaded
> Jun 10 16:47:07 turris modprobe: thermal_sys is already loaded
> Jun 10 16:47:07 turris modprobe: armada_thermal is already loaded
> Jun 10 16:47:07 turris modprobe: failed to find a module named mmc_core
> Jun 10 16:47:07 turris modprobe: failed to find a module named mmc_block
> Jun 10 16:47:07 turris insmod: module is already loaded - mvsdio
> Jun 10 16:47:07 turris insmod: module is already loaded - ledtrig-gpio
> Jun 10 16:47:07 turris insmod: module is already loaded - ledtrig-heartbeat
> Jun 10 16:47:07 turris insmod: module is already loaded - ledtrig-morse
> Jun 10 16:47:07 turris modprobe: xt_tcpudp is already loaded
> Jun 10 16:47:07 turris modprobe: iptable_filter is already loaded
> Jun 10 16:47:07 turris modprobe: iptable_mangle is already loaded
> Jun 10 16:47:07 turris modprobe: xt_limit is already loaded
> Jun 10 16:47:07 turris modprobe: xt_mac is already loaded
> Jun 10 16:47:07 turris modprobe: xt_multiport is already loaded
> Jun 10 16:47:07 turris modprobe: xt_comment is already loaded
> Jun 10 16:47:07 turris modprobe: xt_id is already loaded
> Jun 10 16:47:07 turris modprobe: xt_LOG is already loaded
> Jun 10 16:47:07 turris modprobe: nf_log_common is already loaded
> Jun 10 16:47:07 turris modprobe: nf_log_ipv4 is already loaded
> Jun 10 16:47:07 turris modprobe: xt_TCPMSS is already loaded
> Jun 10 16:47:07 turris modprobe: ipt_REJECT is already loaded
> Jun 10 16:47:07 turris modprobe: nf_reject_ipv4 is already loaded
> Jun 10 16:47:07 turris modprobe: xt_time is already loaded
> Jun 10 16:47:07 turris modprobe: xt_mark is already loaded
> Jun 10 16:47:07 turris insmod: module is already loaded - xt_LED
> Jun 10 16:47:07 turris insmod: module is already loaded - ledtrig-oneshot
> Jun 10 16:47:07 turris insmod: module is already loaded - ledtrig-transient
> Jun 10 16:47:07 turris insmod: module is already loaded - ledtrig-usbdev
> Jun 10 16:47:07 turris modprobe: xt_nat is already loaded
> Jun 10 16:47:07 turris modprobe: iptable_nat is already loaded
> Jun 10 16:47:07 turris modprobe: ipt_MASQUERADE is already loaded
> Jun 10 16:47:07 turris modprobe: nf_nat_masquerade_ipv4 is already loaded
> Jun 10 16:47:07 turris modprobe: xt_REDIRECT is already loaded
> Jun 10 16:47:07 turris modprobe: xt_state is already loaded
> Jun 10 16:47:07 turris modprobe: iptable_raw is already loaded
> Jun 10 16:47:07 turris modprobe: xt_CT is already loaded
> Jun 10 16:47:07 turris modprobe: xt_conntrack is already loaded
> Jun 10 16:47:08 turris insmod: module is already loaded - ebtables
> Jun 10 16:47:08 turris insmod: module is already loaded - ebtable_broute
> Jun 10 16:47:08 turris insmod: module is already loaded - ebtable_filter
> Jun 10 16:47:08 turris insmod: module is already loaded - ebtable_nat
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_802_3
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_among
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_limit
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_mark_m
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_pkttype
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_stp
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_vlan
> Jun 10 16:47:08 turris insmod: module is already loaded - ebt_redirect
> Jun 10 16:47:08 turris modprobe: ebtable_broute is already loaded
> Jun 10 16:47:08 turris modprobe: ebtable_filter is already loaded
> Jun 10 16:47:08 turris modprobe: ebtable_nat is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_802_3 is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_among is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_limit is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_mark_m is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_pkttype is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_stp is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_vlan is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_mark is already loaded
> Jun 10 16:47:08 turris modprobe: ebt_redirect is already loaded
> Jun 10 16:47:08 turris modprobe: crc-ccitt is already loaded
> Jun 10 16:47:08 turris modprobe: ppp_async is already loaded
> Jun 10 16:47:08 turris insmod: module is already loaded - pppoe
> Jun 10 16:47:09 turris modprobe: nf_defrag_ipv6 is already loaded
> Jun 10 16:47:09 turris modprobe: nf_conntrack_ipv6 is already loaded
> Jun 10 16:47:09 turris modprobe: ip6_tables is already loaded
> Jun 10 16:47:09 turris insmod: module is already loaded - ip6table_filter
> Jun 10 16:47:09 turris insmod: module is already loaded - ip6table_mangle
> Jun 10 16:47:09 turris insmod: module is already loaded - ip6table_raw
> Jun 10 16:47:09 turris insmod: module is already loaded - nf_log_ipv6
> Jun 10 16:47:09 turris insmod: module is already loaded - ip6t_REJECT
> Jun 10 16:47:09 turris insmod: module is already loaded - nf_reject_ipv6
> Jun 10 16:47:10 turris modprobe: xt_connbytes is already loaded
> Jun 10 16:47:10 turris modprobe: xt_connlimit is already loaded
> Jun 10 16:47:10 turris modprobe: xt_connmark is already loaded
> Jun 10 16:47:10 turris modprobe: xt_helper is already loaded
> Jun 10 16:47:10 turris modprobe: xt_recent is already loaded
> Jun 10 16:47:10 turris modprobe: xt_dscp is already loaded
> Jun 10 16:47:10 turris modprobe: xt_DSCP is already loaded
> Jun 10 16:47:10 turris modprobe: xt_length is already loaded
> Jun 10 16:47:10 turris modprobe: xt_statistic is already loaded
> Jun 10 16:47:10 turris modprobe: xt_tcpmss is already loaded
> Jun 10 16:47:10 turris modprobe: xt_CLASSIFY is already loaded
> Jun 10 16:47:10 turris modprobe: ipt_ECN is already loaded
> Jun 10 16:47:10 turris modprobe: xt_ecn is already loaded
> Jun 10 16:47:10 turris modprobe: xt_hl is already loaded
> Jun 10 16:47:10 turris modprobe: xt_HL is already loaded
> Jun 10 16:47:11 turris insmod: module is already loaded - ifb
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_ingress
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_hfsc
> Jun 10 16:47:11 turris insmod: module is already loaded - cls_fw
> Jun 10 16:47:11 turris insmod: module is already loaded - cls_route
> Jun 10 16:47:11 turris insmod: module is already loaded - cls_flow
> Jun 10 16:47:11 turris insmod: module is already loaded - cls_tcindex
> Jun 10 16:47:11 turris insmod: module is already loaded - cls_u32
> Jun 10 16:47:11 turris insmod: module is already loaded - em_u32
> Jun 10 16:47:11 turris insmod: module is already loaded - act_mirred
> Jun 10 16:47:11 turris insmod: module is already loaded - act_skbedit
> Jun 10 16:47:11 turris insmod: module is already loaded - act_bpf
> Jun 10 16:47:11 turris insmod: module is already loaded - act_csum
> Jun 10 16:47:11 turris insmod: module is already loaded - act_gact
> Jun 10 16:47:11 turris insmod: module is already loaded - act_ipt
> Jun 10 16:47:11 turris insmod: module is already loaded - act_nat
> Jun 10 16:47:11 turris insmod: module is already loaded - act_pedit
> Jun 10 16:47:11 turris insmod: module is already loaded - act_police
> Jun 10 16:47:11 turris insmod: module is already loaded - act_vlan
> Jun 10 16:47:11 turris insmod: module is already loaded - cls_basic
> Jun 10 16:47:11 turris insmod: module is already loaded - em_cmp
> Jun 10 16:47:11 turris insmod: module is already loaded - em_meta
> Jun 10 16:47:11 turris insmod: module is already loaded - em_nbyte
> Jun 10 16:47:11 turris insmod: module is already loaded - em_text
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_codel
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_dsmark
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_fq
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_gred
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_htb
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_netem
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_pie
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_prio
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_red
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_sfq
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_tbf
> Jun 10 16:47:11 turris insmod: module is already loaded - sch_teql
> Jun 10 16:47:11 turris : Input channel closed
> Jun 10 16:47:11 turris : Module communication error: Broken message recieved
> Jun 10 16:47:11 turris : nc_session_send_reply: Invalid <rpc> message to answer.
> Jun 10 16:47:14 turris insmod: module is already loaded - nfnetlink
> Jun 10 16:47:14 turris modprobe: nf_conntrack_netlink is already loaded
> Jun 10 16:47:24 turris insmod: module is already loaded - soundcore
> Jun 10 16:47:24 turris insmod: module is already loaded - snd
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-hwdep
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-seq-device
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-rawmidi
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-timer
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-pcm
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-mixer-oss
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-pcm-oss
> Jun 10 16:47:24 turris insmod: module is already loaded - snd-compress
> Jun 10 16:47:28 turris insmod: module is already loaded - tun
> Jun 10 16:47:40 turris insmod: module is already loaded - fscache
> Jun 10 16:47:40 turris insmod: module is already loaded - dns_resolver
> Jun 10 16:47:40 turris insmod: module is already loaded - fcrypt
> Jun 10 16:47:40 turris insmod: module is already loaded - crypto_null
> Jun 10 16:47:40 turris insmod: module is already loaded - aead
> Jun 10 16:47:40 turris insmod: module is already loaded - pcbc
> Jun 10 16:47:40 turris insmod: module is already loaded - rxkad
> Jun 10 16:47:40 turris insmod: module is already loaded - af-rxrpc
> Jun 10 16:47:40 turris insmod: module is already loaded - kafs
> Jun 10 16:47:40 turris insmod: module is already loaded - autofs4
> Jun 10 16:47:40 turris modprobe: failed to find a module named xor
> Jun 10 16:47:40 turris modprobe: failed to find a module named raid6_pq
> Jun 10 16:47:40 turris modprobe: failed to find a module named zlib_deflate
> Jun 10 16:47:40 turris modprobe: failed to find a module named zlib_inflate
> Jun 10 16:47:40 turris modprobe: failed to find a module named lzo_compress
> Jun 10 16:47:40 turris modprobe: failed to find a module named lzo_decompress
> Jun 10 16:47:41 turris modprobe: libcrc32c is already loaded
> Jun 10 16:47:41 turris insmod: module is already loaded - sha256_generic
> Jun 10 16:47:41 turris insmod: module is already loaded - ecb
> Jun 10 16:47:41 turris insmod: module is already loaded - des_generic
> Jun 10 16:47:41 turris insmod: module is already loaded - md4
> Jun 10 16:47:41 turris insmod: module is already loaded - md5
> Jun 10 16:47:41 turris insmod: module is already loaded - hmac
> Jun 10 16:47:41 turris insmod: module is already loaded - cifs
> Jun 10 16:47:41 turris insmod: module is already loaded - configfs
> Jun 10 16:47:41 turris insmod: module is already loaded - cramfs
> Jun 10 16:47:41 turris insmod: module is already loaded - exfat
> Jun 10 16:47:41 turris modprobe: failed to find a module named crc16
> Jun 10 16:47:41 turris insmod: module is already loaded - f2fs
> Jun 10 16:47:41 turris insmod: module is already loaded - hfs
> Jun 10 16:47:41 turris insmod: module is already loaded - nls_utf8
> Jun 10 16:47:41 turris insmod: module is already loaded - hfsplus
> Jun 10 16:47:41 turris insmod: module is already loaded - isofs
> Jun 10 16:47:41 turris insmod: module is already loaded - jfs
> Jun 10 16:47:41 turris insmod: module is already loaded - minix
> Jun 10 16:47:41 turris insmod: module is already loaded - fat
> Jun 10 16:47:41 turris insmod: module is already loaded - vfat
> Jun 10 16:47:41 turris insmod: module is already loaded - msdos
> Jun 10 16:47:41 turris insmod: module is already loaded - grace
> Jun 10 16:47:41 turris insmod: module is already loaded - sunrpc
> Jun 10 16:47:41 turris insmod: module is already loaded - lockd
> Jun 10 16:47:41 turris insmod: module is already loaded - nfs
> Jun 10 16:47:41 turris insmod: module is already loaded - nfsv3
> Jun 10 16:47:41 turris modprobe: oid-registry is already loaded
> Jun 10 16:47:41 turris insmod: module is already loaded - auth_rpcgss
> Jun 10 16:47:41 turris insmod: module is already loaded - nfsv4
> Jun 10 16:47:41 turris insmod: module is already loaded - nfs_layout_nfsv41_files
> Jun 10 16:47:41 turris insmod: module is already loaded - nfsd
> Jun 10 16:47:41 turris insmod: module is already loaded - ntfs
> Jun 10 16:47:41 turris modprobe: crc-itu-t is already loaded
> Jun 10 16:47:41 turris insmod: module is already loaded - udf
> Jun 10 16:47:41 turris insmod: module is already loaded - xfs
> Jun 10 16:47:41 turris insmod: module is already loaded - nls_cp1250
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp1251
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp437
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp775
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp850
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp852
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp862
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp864
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp866
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp932
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_iso8859-1
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_iso8859-13
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_iso8859-15
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_iso8859-2
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_iso8859-6
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_cp1255
> Jun 10 16:47:42 turris insmod: module is already loaded - nls_koi8-r
> Jun 10 16:47:42 turris insmod: module is already loaded - md-mod
> Jun 10 16:47:42 turris insmod: module is already loaded - linear
> Jun 10 16:47:42 turris insmod: module is already loaded - multipath
> Jun 10 16:47:42 turris insmod: module is already loaded - raid0
> Jun 10 16:47:42 turris insmod: module is already loaded - raid1
> Jun 10 16:47:42 turris insmod: module is already loaded - raid10
> Jun 10 16:47:42 turris insmod: module is already loaded - async_tx
> Jun 10 16:47:42 turris insmod: module is already loaded - async_memcpy
> Jun 10 16:47:42 turris insmod: module is already loaded - async_xor
> Jun 10 16:47:42 turris insmod: module is already loaded - async_pq
> Jun 10 16:47:42 turris insmod: module is already loaded - async_raid6_recov
> Jun 10 16:47:42 turris insmod: module is already loaded - raid456
> Jun 10 16:47:42 turris insmod: module is already loaded - usb-storage
> Jun 10 16:47:42 turris modprobe: ums-alauda is already loaded
> Jun 10 16:47:42 turris modprobe: ums-cypress is already loaded
> Jun 10 16:47:42 turris modprobe: ums-datafab is already loaded
> Jun 10 16:47:42 turris modprobe: ums-freecom is already loaded
> Jun 10 16:47:42 turris modprobe: ums-isd200 is already loaded
> Jun 10 16:47:42 turris modprobe: ums-jumpshot is already loaded
> Jun 10 16:47:42 turris modprobe: ums-karma is already loaded
> Jun 10 16:47:42 turris modprobe: ums-sddr09 is already loaded
> Jun 10 16:47:42 turris modprobe: ums-sddr55 is already loaded
> Jun 10 16:47:42 turris modprobe: ums-usbat is already loaded
> Jun 10 16:47:42 turris insmod: module is already loaded - ehci-hcd
> Jun 10 16:47:42 turris insmod: module is already loaded - ehci-platform
> Jun 10 16:47:42 turris insmod: module is already loaded - ehci-orion
> Jun 10 16:47:42 turris modprobe: failed to find a module named uas
> Jun 10 16:47:42 turris insmod: module is already loaded - ahci_platform
> Jun 10 16:47:42 turris insmod: module is already loaded - marvell-cesa
> Jun 10 16:47:43 turris insmod: module is already loaded - dm-mod
> Jun 10 16:47:43 turris insmod: module is already loaded - dm-log
> Jun 10 16:47:43 turris insmod: module is already loaded - dm-region-hash
> Jun 10 16:47:43 turris insmod: module is already loaded - dm-mirror
> Jun 10 16:47:43 turris insmod: module is already loaded - dm-crypt
> Jun 10 16:47:43 turris insmod: module is already loaded - fuse
> Jun 10 16:47:46 turris insmod: module is already loaded - authenc
> Jun 10 16:47:46 turris insmod: module is already loaded - cryptodev
> Jun 10 16:47:46 turris insmod: module is already loaded - af_alg
> Jun 10 16:47:46 turris insmod: module is already loaded - algif_hash
> Jun 10 16:47:46 turris insmod: module is already loaded - algif_skcipher
> Jun 10 16:47:46 turris insmod: module is already loaded - cbc
> Jun 10 16:47:46 turris insmod: module is already loaded - drbg
> Jun 10 16:47:46 turris insmod: module is already loaded - jitterentropy_rng
> Jun 10 16:47:47 turris insmod: module is already loaded - seqiv
> Jun 10 16:47:47 turris insmod: module is already loaded - ctr
> Jun 10 16:47:47 turris insmod: module is already loaded - gf128mul
> Jun 10 16:47:47 turris insmod: module is already loaded - xts
> Jun 10 16:47:47 turris insmod: module is already loaded - cmac
> Jun 10 16:47:47 turris insmod: module is already loaded - sha1_generic
> Jun 10 16:47:47 turris insmod: module is already loaded - sha512_generic
> Jun 10 16:47:47 turris insmod: module is already loaded - ccm
> Jun 10 16:47:47 turris insmod: module is already loaded - atm
> Jun 10 16:47:47 turris insmod: module is already loaded - br2684
> Jun 10 16:47:47 turris insmod: module is already loaded - pppoatm
> Jun 10 16:47:47 turris modprobe: ppp_mppe is already loaded
> Jun 10 16:47:47 turris insmod: module is already loaded - ip_tunnel
> Jun 10 16:47:47 turris insmod: module is already loaded - gre
> Jun 10 16:47:47 turris insmod: module is already loaded - ip_gre
> Jun 10 16:47:47 turris insmod: module is already loaded - tunnel6
> Jun 10 16:47:47 turris insmod: module is already loaded - ip6_tunnel
> Jun 10 16:47:47 turris insmod: module is already loaded - tunnel4
> Jun 10 16:47:47 turris insmod: module is already loaded - sit
> Jun 10 16:47:47 turris modprobe: ts_kmp is already loaded
> Jun 10 16:47:47 turris modprobe: ts_bm is already loaded
> Jun 10 16:47:47 turris modprobe: ts_fsm is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_broadcast is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_amanda is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_amanda is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_proto_gre is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_proto_gre is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_h323 is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_h323 is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_pptp is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_pptp is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_sip is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_sip is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_snmp is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_snmp_basic is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_tftp is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_tftp is already loaded
> Jun 10 16:47:47 turris modprobe: nf_conntrack_irc is already loaded
> Jun 10 16:47:47 turris modprobe: nf_nat_irc is already loaded
> Jun 10 16:47:47 turris insmod: module is already loaded - mii
> Jun 10 16:47:47 turris modprobe: usbnet is already loaded
> Jun 10 16:47:47 turris modprobe: cdc_ether is already loaded
> Jun 10 16:47:47 turris modprobe: rndis_host is already loaded
> Jun 10 16:47:47 turris modprobe: cdc-wdm is already loaded
> Jun 10 16:47:47 turris modprobe: qmi_wwan is already loaded
> Jun 10 16:47:47 turris modprobe: option is already loaded
> Jun 10 16:47:49 turris ddns-scripts[23476]: henet_endpoint: PID '23476' started at 2018-06-10 16:47
> Jun 10 16:47:49 turris ddns-scripts[23475]: rackspace: PID '23475' started at 2018-06-10 16:47
> Jun 10 16:47:49 turris ddns-scripts[23475]: rackspace: Starting main loop at 2018-06-10 16:47
> Jun 10 16:47:49 turris ddns-scripts[23476]: henet_endpoint: Starting main loop at 2018-06-10 16:47
That seems to be about the time when updater stopped doing reasonable things (since then, just casual cron events, like nethist_stats.lua or /usr/bin/rainbow_button_sync.sh)
- Before I restarted Omnia, I quickly did following:
root@turris:~# ps | grep updater
601 root 11012 S python /usr/bin/updater-supervisor -d --rand-sleep
6292 root 11012 S python /usr/bin/updater-supervisor -d --rand-sleep
11256 root 61420 S pkgupdate --batch --state-log --task-log=/usr/share/updater/updater-log --ask-approval=/usr/share/update
13743 root 11000 S python /usr/bin/updater-supervisor -d --rand-sleep
18717 root 11012 S python /usr/bin/updater-supervisor -d --rand-sleep
20817 root 11012 S python /usr/bin/updater-supervisor -d --rand-sleep
23475 root 1352 S {dynamic_dns_upd} /bin/sh /usr/lib/ddns/dynamic_dns_updater.sh -v 0 -S rackspace – start
23476 root 1348 S {dynamic_dns_upd} /bin/sh /usr/lib/ddns/dynamic_dns_updater.sh -v 0 -S henet_endpoint – start
23973 root 10992 S python /usr/bin/updater-supervisor -d --rand-sleep
24640 root 11000 S python /usr/bin/updater-supervisor -d --rand-sleep
27246 root 1112 S grep updater
28890 root 10992 S python /usr/bin/updater-supervisor -d --rand-sleep
root@turris:~# updater.sh
updater.sh is obsoleted. Please use pkgupdate directly instead.
root@turris:~# INFO:Detected existing journal. Trying to recover it.
line not found
line not found
line not found
line not found
DIE:
[string “backend”]:1172: [string “backend”]:1163: Failed to lock the lock file //var/lock/opkg.lock: Resource temporarily unavailable
root@turris:~# reboot
It seems that updater just hanged badly. I am not sure whether it finished its job. The /usr/share/updater/updater-log shows updated packages, manual run of pkgupdate does not show anything to update, so maybe that updater hanged just after it, before setting the notification… but well, I am not really sure. It seems updater ran really messy, how can I trust it???
I am tempted to restore snapshot 135 and try again… although I am afraid it might end up the same, or even worse.
Any suggestions from Turris team what to do with it now?
