ftmx
July 1, 2019, 4:06pm
1
I am experiencing daily (at least ) 5GHz wifi drops and/or spontaneous router reboots. And when it is working, both wireless and wired clients get disconnected and have to reconnect very frequently: guess what it does to games?!.
I am using PPPoE (50M/10M), setup with four wired tagged VLAN’s and on a LAN port with a dumb switch connected, and a half a dozen AP’s spread across lan and _turris_guest . At any given moment of time there are at least five devices using the router.
Are there any hints on how to stabilize the thing?
did you take a look at cat /sys/kernel/debug/crashlog
after such reboot, see if there is a crashlog?
about the Wlan connectivity drops - there are some factors to consider - the config for the AP’s a/o potentially environment (signal pollution , incl. USB3 interference if any attached to the router)
Also depending on the country the router to operate in 5GHz will do some DFS scanning in accordance with the country’s legislation, that if the channel is set to auto. During such scans the AP is not accessible to clients. I am not sure about how frequent such DFS scans are executed.
Did you try to:
set different frequencies other than auto?
different channel width 20/40/80 Mhz?
802.11w on | off
802.11r on | off
ftmx
July 5, 2019, 11:31pm
3
Yes, I am aware of all of those (except for the crashlog thing that I will keep in mind next time) and tried them. No USB devices attached, no auto/DFS channels, running in an env with ambient temperature of 18C, no lxc and stuff, etc. Just a pure router. The point here is that a r7800 with OpenWRT in the same location, identically configured , and under the same exact load is rock solid. A Turris Omnia with v3.11.5 cannot even survive for 12 hours: I have around a half a dozen devices active at any point of time with over 50 in total. And if it does survive longer, then wired devices start loosing connections every several seconds and I need to reboot the router myself.
My guess is that a TO unit and/or v3.11.5 firmware is/are just getting tired too quickly, while an r7800 keeps chugging along without any hiccups. Maybe it is working for others with less load, but not in my case.
Now I just need to see if the unit is a lemon…
all pertaining network components - netifd
| hostapd
| wpad
- are known as outdated/buggy in TOS3.x, probably also the drivers for the Wlan cards. This will change with the upcoming TOS4.x|5.x.
If still happens then the node in question may suffer from some hardware issue instead.
ftmx
July 10, 2019, 9:51pm
5
So far, I am not impressed with OpenWRT 19.07 on a Turris Omnia either: 5GHz goes down hourly…
On a positive note no spontaneous reboots you reported initially?
about the 5Ghz it may bear down to the candela driver not being utilized in the TO
OpenWrt uses since version 18.06 Candela Tech Wi-Fi drivers for ath10k. In Turris OS 3.x, we are using ath10k, but we wanted to have in Turris OS 4.x/5.x the same Wi-Fi driver as OpenWrt has by default. If you have time you can read about it on...
there are issue reported with a high number of clients
http://lists.infradead.org/pipermail/openwrt-devel/2019-July/017937.html
though the r7800 features the same Wlan chipset but uses the candela driver instead if I am not mistaken? and suffers it in its own right
Installing and Using OpenWrt
Network and Wireless Configuration
QCA9984/9994 for now is absolutely stable with CT driver and classic firmware, if you want stability in OpenWrt — i think it's better, because drivers is finely tuned a years on OpenWrt. But i have an Xiaomi R3P with same MTN7615 and it works as...
http://lists.infradead.org/pipermail/openwrt-devel/2019-June/017781.html
Well, 3.11.5 solved a lot of strange anomalies here, no clue why. Including the wonky 5G ?
And my TO is standard. The only thing i keep finding dodgy is the pakon part, the rest is all working ( again ).
i knew i should have written this… as since 24 hours the whole 5 G is down. The only thing i changed was switching the 5 G channel from 52 to 100.
hmm,ok. apperantly the ( current ) 5G problem seems to be related to the channel/auto selection? Since now i have set the channel manual ( 48 ) and 5G is up and running. Channel 52 means 5G is disabled. Interesting.
Jimi
August 10, 2019, 4:44am
10
Maybe, Auto seems totally unusable. Set it to Channel 36 … it’s still quite a mess. It’s crashing within 30minutes. And have regular drop-outs. So something is really not working as it should.
Summary
[52950.380266] ------------[ cut here ]------------
[52950.380339] WARNING: CPU: 0 PID: 0 at /home/beast/beast/workspace/omnia-stable/build_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/linux-mvebu/compat-wireless-2017-01-31/drivers/net/wireless/ath/ath10k/htt_rx.c:1006 ath10k_htt_t2h_msg_handler+0x14fc/0x17ac ath10k_core
[52950.380343] Modules linked in: qcserial option iptable_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_log nfnetlink nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast nf_conntrack mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
[52950.380685] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.182-a890a5a94ebb621f8f1720c24d12fef1-0 #1
[52950.380689] Hardware name: Marvell Armada 380/385 (Device Tree)
[52950.380692] Backtrace:
[52950.380702] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
[52950.380706] r6:00000000 r5:60000113 r4:c0776ea8 r3:00000000
[52950.380717] [] (show_stack) from [] (dump_stack+0x98/0xac)
[52950.380724] [] (dump_stack) from [] (warn_slowpath_common+0x8c/0xbc)
[52950.380727] r6:000003ee r5:bf736e78 r4:00000000 r3:00000006
[52950.380737] [] (warn_slowpath_common) from [] (warn_slowpath_null+0x24/0x2c)
[52950.380740] r8:5d895bfb r7:0000cb31 r6:00000018 r5:ed7715e0 r4:d4d93480
[52950.380771] [] (warn_slowpath_null) from [] (ath10k_htt_t2h_msg_handler+0x14fc/0x17ac [ath10k_core])
[52950.380807] [] (ath10k_htt_t2h_msg_handler [ath10k_core]) from [] (ath10k_htt_txrx_compl_task+0xc7c/0x12a8 [ath10k_core])
[52950.380810] r10:ed7715e0 r9:c0765d60 r8:00000000 r7:c076c368 r6:00000009 r5:c076c368
[52950.380819] r4:d4d93000
[52950.380847] [] (ath10k_htt_txrx_compl_task [ath10k_core]) from [] (ath10k_pci_napi_poll+0x50/0x108 [ath10k_pci])
[52950.380850] r10:005056a8 r9:00000000 r8:c0765df8 r7:00000040 r6:ed771820 r5:ed7715e0
[52950.380858] r4:ed775220
[52950.380874] [] (ath10k_pci_napi_poll [ath10k_pci]) from [] (net_rx_action+0x13c/0x308)
[52950.380877] r9:c0766100 r8:c0765df8 r7:0000012c r6:00000040 r5:00000001 r4:ed775220
[52950.380891] [] (net_rx_action) from [] (__do_softirq+0x114/0x260)
[52950.380894] r10:00000000 r9:00000003 r8:00000100 r7:c0764000 r6:40000003 r5:c0766080
[52950.380902] r4:c076608c
[52950.380908] [] (__do_softirq) from [] (irq_exit+0x80/0xb8)
[52950.380911] r10:c0765f70 r9:f0803100 r8:ee808000 r7:00000001 r6:00000000 r5:00000000
[52950.380919] r4:c075f0e8
[52950.380927] [] (irq_exit) from [] (__handle_domain_irq+0x68/0xb8)
[52950.380930] r4:c075f0e8 r3:f0802100
[52950.380937] [] (__handle_domain_irq) from [] (gic_handle_irq+0x50/0x94)
[52950.380940] r8:c0765f00 r7:f080210c r6:c076703c r5:c07772fc r4:f0802100 r3:c0765f00
[52950.380951] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)
[52950.380955] Exception stack(0xc0765f00 to 0xc0765f48)
[52950.380961] 5f00: 00000001 00000000 c0765f60 c000b520 c0764000 c0766498 c0766450 00000000
[52950.380967] 5f20: 00000000 c0761218 c0765f70 c0765f5c c0765f60 c0765f50 c001943c c0019440
[52950.380970] 5f40: 60000013 ffffffff
[52950.380973] r9:c0761218 r8:00000000 r7:c0765f34 r6:ffffffff r5:60000013 r4:c0019440
[52950.380990] [] (arch_cpu_idle) from [] (default_idle_call+0x28/0x34)
[52950.380996] [] (default_idle_call) from [] (cpu_startup_entry+0x158/0x238)
[52950.381003] [] (cpu_startup_entry) from [] (rest_init+0x80/0x84)
[52950.381005] r7:c07663c0
[52950.381012] [] (rest_init) from [] (start_kernel+0x468/0x474)
[52950.381017] [] (start_kernel) from [<0000807c>] (0x807c)
[52950.381020] —[ end trace 0e96ece16adfc162 ]—
[64278.090125] BTRFS info (device mmcblk0p1): quota is enabled
[107475.175849] BTRFS info (device mmcblk0p1): quota is enabled
[149039.480508] ------------[ cut here ]------------
[149039.480582] WARNING: CPU: 0 PID: 0 at /home/beast/beast/workspace/omnia-stable/build_dir/target-arm_cortex-a9+vfpv3_musl-1.1.15_eabi/linux-mvebu/compat-wireless-2017-01-31/drivers/net/wireless/ath/ath10k/htt_rx.c:1010 ath10k_htt_t2h_msg_handler+0x152c/0x17ac ath10k_core
[149039.480586] Modules linked in: qcserial option iptable_nat ath9k usb_wwan rndis_host qmi_wwan pppoe nf_nat_pptp nf_nat_ipv4 nf_nat_amanda nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_ipv6 nf_conntrack_ipv4 nf_conntrack_amanda ipt_REJECT ipt_MASQUERADE ftdi_sio ebtable_nat ebtable_filter ebtable_broute cdc_ether ath9k_common armada_thermal xt_time xt_tcpudp xt_tcpmss xt_statistic xt_state xt_recent xt_nat xt_multiport xt_mark xt_mac xt_limit xt_length xt_id xt_hl xt_helper xt_ecn xt_dscp xt_conntrack xt_connmark xt_connlimit xt_connbytes xt_comment xt_TCPMSS xt_REDIRECT xt_NFQUEUE xt_LOG xt_HL xt_DSCP xt_CT xt_CLASSIFY wireguard usbserial usbnet ums_usbat ums_sddr55 ums_sddr09 ums_karma ums_jumpshot ums_isd200 ums_freecom ums_datafab ums_cypress ums_alauda ts_kmp ts_fsm ts_bm thermal_sys pppox ppp_mppe ppp_async nfnetlink_queue nfnetlink_log nfnetlink nf_reject_ipv4 nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_redirect nf_nat_proto_gre nf_nat_masquerade_ipv4 nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat nf_log_ipv4 nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_rtcache nf_conntrack_proto_gre nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast nf_conntrack mvsdio iptable_raw iptable_mangle iptable_filter ipt_ECN ip_tables hwmon ebtables ebt_vlan ebt_stp ebt_redirect ebt_pkttype ebt_mark_m ebt_mark ebt_limit ebt_among ebt_802_3 crc_ccitt cdc_wdm ath9k_hw fuse sch_teql sch_tbf sch_sfq sch_red sch_prio sch_pie sch_netem sch_htb sch_gred sch_fq sch_dsmark sch_codel em_text em_nbyte em_meta em_cmp cls_basic act_vlan act_police act_pedit act_nat act_ipt act_gact act_csum act_bpf act_skbedit act_mirred em_u32 cls_u32 cls_tcindex cls_flow cls_route cls_fw sch_hfsc sch_ingress ath10k_pci ath10k_core ath mac80211 cfg80211 compat ledtrig_usbdev ledtrig_oneshot xt_LED ledtrig_morse ledtrig_heartbeat ledtrig_gpio cryptodev ip6t_REJECT nf_reject_ipv6 nf_log_ipv6 nf_log_common ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables pppoatm ppp_generic slhc nfsd nfsv3 msdos ip_gre gre ifb ip6_udp_tunnel udp_tunnel sit ip6_tunnel tunnel6 tunnel4 ip_tunnel veth tun snd_compress snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_rawmidi snd_seq_device snd_hwdep snd input_core soundcore rxkad vfat fat udf crc_itu_t ntfs nfs_layout_nfsv41_files nfsv4 nfs auth_rpcgss oid_registry lockd sunrpc grace minix isofs hfsplus hfs cramfs configfs cifs autofs4 kafs af_rxrpc dns_resolver dm_crypt dm_mirror dm_region_hash dm_log dm_mod br2684 atm multipath fscache raid456 async_raid6_recov async_pq async_xor async_memcpy async_tx raid10 raid1 raid0 linear md_mod nls_utf8 nls_koi8_r nls_cp1255 nls_iso8859_6 nls_iso8859_2 nls_iso8859_15 nls_iso8859_13 nls_iso8859_1 nls_cp932 nls_cp866 nls_cp864 nls_cp862 nls_cp852 nls_cp850 nls_cp775 nls_cp437 nls_cp1251 nls_cp1250 xts algif_skcipher algif_hash af_alg sha512_generic sha256_generic sha1_generic seqiv jitterentropy_rng drbg pcbc md5 md4 marvell_cesa hmac gf128mul fcrypt ecb des_generic ctr cmac ccm cbc authenc xhci_plat_hcd xhci_pci xhci_hcd uhci_hcd ledtrig_transient ahci_platform uas xfs libcrc32c jfs f2fs exfat mii aead crypto_null
[149039.480927] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 4.4.182-a890a5a94ebb621f8f1720c24d12fef1-0 #1
[149039.480932] Hardware name: Marvell Armada 380/385 (Device Tree)
[149039.480935] Backtrace:
[149039.480946] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
[149039.480949] r6:00000000 r5:60000113 r4:c0776ea8 r3:00000000
[149039.480960] [] (show_stack) from [] (dump_stack+0x98/0xac)
[149039.480968] [] (dump_stack) from [] (warn_slowpath_common+0x8c/0xbc)
[149039.480971] r6:000003f2 r5:bf736ea8 r4:00000000 r3:00000006
[149039.480981] [] (warn_slowpath_common) from [] (warn_slowpath_null+0x24/0x2c)
[149039.480984] r8:e39952d1 r7:0000383d r6:00000018 r5:ed7715e0 r4:cc3879c0
[149039.481014] [] (warn_slowpath_null) from [] (ath10k_htt_t2h_msg_handler+0x152c/0x17ac [ath10k_core])
[149039.481048] [] (ath10k_htt_t2h_msg_handler [ath10k_core]) from [] (ath10k_htt_txrx_compl_task+0xc7c/0x12a8 [ath10k_core])
[149039.481051] r10:ed7715e0 r9:c0765d60 r8:00000000 r7:c076c368 r6:00000009 r5:c076c368
[149039.481060] r4:ebf67840
[149039.481088] [] (ath10k_htt_txrx_compl_task [ath10k_core]) from [] (ath10k_pci_napi_poll+0x50/0x108 [ath10k_pci])
[149039.481091] r10:00e2f657 r9:00000000 r8:c0765df8 r7:00000040 r6:ed771820 r5:ed7715e0
[149039.481099] r4:ed775220
[149039.481116] [] (ath10k_pci_napi_poll [ath10k_pci]) from [] (net_rx_action+0x13c/0x308)
[149039.481119] r9:c0766100 r8:c0765df8 r7:0000012c r6:00000040 r5:00000001 r4:ed775220
[149039.481133] [] (net_rx_action) from [] (__do_softirq+0x114/0x260)
[149039.481136] r10:00000000 r9:00000003 r8:00000100 r7:c0764000 r6:40000003 r5:c0766080
[149039.481144] r4:c076608c
[149039.481150] [] (__do_softirq) from [] (irq_exit+0x80/0xb8)
[149039.481153] r10:c0765f70 r9:f0803100 r8:ee808000 r7:00000001 r6:00000000 r5:00000000
[149039.481161] r4:c075f0e8
[149039.481168] [] (irq_exit) from [] (__handle_domain_irq+0x68/0xb8)
[149039.481171] r4:c075f0e8 r3:f0802100
[149039.481179] [] (__handle_domain_irq) from [] (gic_handle_irq+0x50/0x94)
[149039.481181] r8:c0765f00 r7:f080210c r6:c076703c r5:c07772fc r4:f0802100 r3:c0765f00
[149039.481193] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)
[149039.481197] Exception stack(0xc0765f00 to 0xc0765f48)
[149039.481203] 5f00: 00000001 00000000 c0765f60 c000b520 c0764000 c0766498 c0766450 00000000
[149039.481209] 5f20: 00000000 c0761218 c0765f70 c0765f5c c0765f60 c0765f50 c001943c c0019440
[149039.481213] 5f40: 60000013 ffffffff
[149039.481215] r9:c0761218 r8:00000000 r7:c0765f34 r6:ffffffff r5:60000013 r4:c0019440
[149039.481232] [] (arch_cpu_idle) from [] (default_idle_call+0x28/0x34)
[149039.481239] [] (default_idle_call) from [] (cpu_startup_entry+0x158/0x238)
[149039.481244] [] (cpu_startup_entry) from [] (rest_init+0x80/0x84)
[149039.481247] r7:c07663c0
[149039.481254] [] (rest_init) from [] (start_kernel+0x468/0x474)
[149039.481259] [] (start_kernel) from [<0000807c>] (0x807c)
[149039.481262] —[ end trace 0e96ece16adfc163 ]—
My experience is that the 5G card is not configuring based on region correctly caused the 5G to be in disabled stage. Suggestion is to go to Forris UI and change your region accordinglingly, then go to WiFi setting and ensure that the choose a fixed bandwidth & fixed channel according to your local law. In my case I have to manually set it to 20Mhz bandwidth with channel 149 as 40Mhz & 80Mhz are not allowed based on my region but in the configuration still shows those bandwidth.
Once set, the WiFi back to normal, give it a try.
Jimi
August 11, 2019, 5:09am
12
Sadly not in my case. It’s set to Sweden and this should just work. Something is really wrong with the ath drivers. I guess I’ll just need to wait out for 4.0 OS…
yep, same issues here. The way i keep it working now is to put the region to World, use ch 48. That keeps the 5 G stable.
