can someone please tell me which WiFi cards are now supported in the Turris Omnia? I have the original set up and would like to upgrade the 2.4GHz and 5GHz card to the latest standards and speeds.
Thank you!!
Thank you!!
This thread, I suppose?
Latest stable standard for Turris Omnia (both hard- and software) is what is already installed on your router.
802.11ax (WiFi6) is not yet available for openwrt (for more information see the thread provided by @vcunat).
If you would like to use 802.11ac WAVE2 you should follow these steps:
edit: If you want to reuse 3x3 WiFi-card as 802.11n-device (as descriped above), you need to order one additional diplexer from Turris staff (tech.support@turris.cz). If you choose to reuse smaller WiFi-card, no additional diplexer is needed. In both cases an additional antenna and pigtail (U.FL<->U.FL) cable is needed.
