does the WLE1216VX work with the Omnia?? Or has anyone a tip for me where i should look next?
I installed the driver ath10k-firmware-qca9984-ct and also the “alternative” drivers for the WLE900VX (which still sits in the Omnia and is currently my only wifi)
lspci-v does not show the card at all only the WLE900VX.
EDIT: I also installed the newest medkit and running now on Turris OS 5.1.1 (Kernel: 4.14.195)
Please correct me if i’m wrong: lspci -v shows me everything which is connected to the PCI-System right? Even if there are driver issues for example right?
00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Device tree node: /sys/firmware/devicetree/base/soc/pcie/pcie@1,0
Flags: fast devsel
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: None
Memory behind bridge: None
Prefetchable memory behind bridge: 00000000-000fffff [size=1M]
Capabilities: [40] Express Root Port (Slot+), MSI 00
lspci: Unable to load libkmod resources: error -12
00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Device tree node: /sys/firmware/devicetree/base/soc/pcie/pcie@2,0
Flags: fast devsel
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Device tree node: /sys/firmware/devicetree/base/soc/pcie/pcie@3,0
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: e0000000-e02fffff [size=3M]
03:00.0 Network controller: Qualcomm Atheros QCA986x/988x 802.11ac Wireless Netw ork Adapter
Flags: bus master, fast devsel, latency 0, IRQ 78
Memory at e0000000 (64-bit, non-prefetchable) [size=2M]
Expansion ROM at e0200000 [disabled] [size=64K]
Capabilities: [40] Power Management version 2
Capabilities: [50] MSI: Enable+ Count=1/8 Maskable+ 64bit-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
Kernel driver in use: ath10k_pci
i can’t see the card here.
Maybe it arrived already broken?
The patch is for the source code, that if you want to compile it.
I think you need to copy all 3 files from the Files folder. The module “ath10-ct” too.
However those files were compiled for a specific kernel, and they may not work on the latest kernel.
I have just found (after 4 LED reset) that choosing alternative driver in reForis will add driver only for 988x, so you you have to find drivers via LuCI…
