Turris Omnia 6.0 upgrade issue
Hello, I just wanted to have a quick check with you guys. After having the following issue with auto-upgrade as many people described here:
I had to disable the Automatic Update feature, as it automatically upgraded and bricked my Omnia again and again. I’ve noticed 6.0.1 is out. I want to check with anyone who had that issue as well, if when enabling the auto-update it will use 6.0.1 and if the problem is not present in 6.0.1.
Thanks a lot for any comments.
some info would be helpful. like, which version of the omnia (1.0 or 2020), which branch (hbs, hbt,…) and if anything non-standard is installed. and what is the last version that works.
for i have an omnia 2020, and the only bugs i encounter on HBS on 6.0.1 is that the firewall logs are broken.
on hbk 6.0.1, there was a small update that broke wifi connection…
MIGHT it be you come from TOS5.X and want to upgrade to 6.0?
the things i´d recommend : use another browser to connect to the router locally, check the “interfaces” section, for there will be a one time fix-up iirc, reboot the omnia at least once … after that, everything should be up and running again.
People are still reporting issues as you can see here in the forums, so I decided to disable auto-update and wait for 6.0.2, hopefully it will be already a stable release.
I can see another issue reports popping up every few moments, like DNS resolving etc. These 6.x releases are really bad…
I’m on Turris Omnia:
reForis version 1.1.2
Turris OS version 5.4.4 (HBS branch)
Kernel version 4.14.294
so this is sad, I’ll probably also wait for some later version unless someone says something positive
So I updated from 5.5.5 to 6.0.1 and other than having to reboot once manually after the update things just continued working as before. That said, I only exercise a small subset of my omnia’s capabilities (SQM, PAKON, adblock, dynamic dns, 2.4&5 GHz WiFI, specifically no VLANs) but still giving that OpenWrt does not really support updates across major versions I think this worked reasonably well (that is I expected more bumps and issues even for pretty boring configurations like mine). But at the same time I understand that I was lucky and that those affected by bigger issues are understandably less impressed.
Since I upgraded to Turris OS 6.0, my Nextcloud doesnt work claiming that upgrade between multiple versions is not supported (from 20.x to 22.x). How to solve it without losing any data - upgrade to 21.x first I guess, but how?
