Does Omnia Enterprise have SFP or SFP+ ports? There is only SFP in the specs document.
Now the question is whether CZ.NIC already has some production samples, or just prototypes as beforeā¦
https://mailing-turris.nic.cz/?m=11&p=view&pi=ViewBrowserPlugin&uid=7cb5a5ef36231e6e9d9e2794e9e7f770
Here the data sheet of the Omnia Enterprise NXP LS2080 ā¦
They are claiming 10G on the SFP ports, so Iād assume itās SFP+
Interestingā¦otoh, enterprise also means enterprise support and the whole shebang behind it?
While I like the features of the āenterpriseā omnia, I have a hunch its price point is going to be outside of my range, if only as I would need at least 2 SFP modules even for simple wired routing⦠(the Turris RTROM01-RTSF-10G, SFP+ Copper module, 10 Gbps, RJ45 costs 77.39, so 77.39*2 = 154.78 EUR plus shipping, on top of the base cost of the router). On the plus side my omnia seems well suited for my 100/40 link for the foreseeable future so letās see how/if SFP+ modules drop in priceā¦
The SG1 looks like a decent travel router though (sure dual core a53 @ 1 GHz is not going to allow routing/traffic shaping in the gigabit range, but while traveling that rarely seems required). I wonder what it will finally cost.
Technically, the SG1 has the same guts as a Mox, so Iād expect it to be similar to its price: 200-250ā¬
Enterprise omnia looks really interresting.
Massively overkill but high need to have factor.
Will be super interesting to see the final price tag.
Found this page: Subcribe to our Newsletters
The SG1 price tag is specified in the new letter as follows:
- Retail price starting at 130 USD
I guess that would be without VAT tax.
Not sure what might be the extra options (as suggested by the āprice starting atā)⦠Memory? Battery pack? Cat4 vs Cat6 LTE modem?
Hard to choose, I want both
Turris omnia Enterprise:
Where can i order one?
Is it possible to just order the pcb? (No need for the case as itās going to be installed in an electric cabinet (ventilated) anyway)
dedicated router/firewall and a separate AP.
Iām in!
probably need to win the lottery first though
Too early to order, I believe. (maybe way too early)
I believe it is the final design. Yet question is valid, whether production has already startedā¦
If Omnia Enterprie will has a SFP+ Itāll be nice piece of hardware. Also that portable SG1, but maybe at least 2,5GbE can be included. I stay tuned, because Iām interested in.
Yes, except that for six 1 Gbps copper ethernet ports you pay at least 6 * 20 = 120 EUR, for nicer 1-10 Gbps SFP+ modules even 77*6 = 462 EUR.
That is on top of what ever the base price of that unit is going to be. I think the āenterpriseā in the name was selected carefully, for true enterprise-grade gear that omnia 23 is going to be ācheapā for normal end-user all-in-one gear less so (even the current omnia is at the upper end of home gear). I am not doubting that it is going to be worth the money, just whether I will/can afford it, but that clearly is my own problem
I should start saving money from today.
Partially youāre right, but If they put CPU with 8x 10GbE support, so that will be step back to support only 1GbE. There are many variations, 2xSFP+ + 6x 10GbE wired connection, or only one SFP+ module for optical transceivers etcā¦
