Hi.
I have Turris 1.1 with NAS and attached external HDD via front USB 3 port (USB 3 HDD). I formated the drive from Turris SSH to ext4 and mounted it and created new share, but copy speed to the drive is only 11 MB/s. To be honest, I expected much more…
Is there something wrong or is it normal speed? Can I somehow improve it?
There is probably something wrong with this turris or cables, because I just tested it at home on my another Turris 1.0 with only USB 2.0 and I am at the speed of ~35 MB/s writing which max of USB 2.0
I really doubt that something could be broken in Turris itself.
You said that you created share. OK. Which one? Samba? NFS?
We’re missing important informations. We dont have magic ball. I’m ready to help you, but please tell me these informations:
did you try it also from other PC?
did you try other protocol (rsync, ftp, NFS)?
HDD Is OK? No bad sectors?
samba version (try to upgrade it / setup it properly / play (tweak it) with settings)
Also do you use any enclosure? Did you buy it from Aliexpress / eBay? Chipset used in SATA -> USB 3.0 could be fake/faulty.
Just FYI - current speed is 70-95 MB/s (usually around 80 MB/s) for read and 50-60 MB/s (usually around 55 MB/s) for write of large files. Turris version 1.1 with today’s SW versions. Attached is Seagate Expansion Desktop, USB 3.0 - 2TB (STBV2000200) to the front USB 3.0 port…
