I use to have no trouble with my LTE setup but now I don’t get why my connection is not stable, I can’t even download files that are more then 200mb !
I have a quectel EP06-E LTE card.
For some reason now I’m forced to make it works to:
1- disable LTE interface
2- Remove WWAN interface
3- change RAW-IP to Y
4- Add a new WWAN interface
5- Reenable LTE
And it works but after some time my connection completly drop and if I try the same thing again it doesn’t work at all and my LTE interface give an error like the network is unreachable.
I need to shutdown the mox, then wait 1 hour and repeat all I said before !
uqmi -d /dev/cdc-wdm0 --get-signal-info
"type": "lte",
"rssi": -66,
"rsrq": -19,
"rsrp": -101,
"snr": -60
I see no obvious error in the log.
If anyone has an idea, thanks by advance
