Hello!
Today we’re proud to announce you that we teamed up with the open source project Nextcloud to bring you a self-hosted private cloud. Their code can be found on Github.com.
Nextcloud on our routers gives you easy access to photos, documents, calendars and contacts and much more through easy access to your photos, documents, calendars and contacts and much more through easy to use interfaces for web and mobile devices.
The Turris MOX: Cloud can be ordered on the Indiegogo campaign for $115 + shipping.
It includes:
- Turris MOX A (Basic module) with 1 GB RAM
- Turris MOX F (4x USB 3.0 module), which is able to power two 2.5" drives by itself (unless you add other power hungry modules)
- Case, power supply, SD card with Turris OS
As part of Turris OS 4.0, there will be introduced a new feature in Storage plugin, which will bring you RAID setup and also ability to easily manage external drives and install Nextcloud in Foris.
More details can be found on our blog CZ.NIC, which @miska wrote and also there is press release from Nextcloud.
