I installed transmission-daemon-mbedtls 2.94-11.9 and the enabled it in /etc/config/transmission
I then enabled the service, tweaked the config to point on /srv/ and started it.
I can see in /var/log/messages
2020-04-13 18:46:42 info procd[]: Instance transmission::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
but I have no information on why it does crash.
I have tried to start it manually as root with the same command and the daemon starts properly.
I have tried to comment the seccomp and jail lines in the init script, but nothing change.
There is zero info on why the instance is crashing.
The PROCD_DEBUG=1 result to this:
{ "name": "transmission" }
{ "name": "transmission", "script": "\/etc\/init.d\/transmission", "instances": { "instance1": { "command": [ "\/usr\/bin\/transmission-daemon", "-f", "-g", "\/srv\/transmission" ], "user": "transmission", "nice": 10, "stderr": true, "respawn": [ "3600", "5", "5" ], "seccomp": "\/etc\/seccomp\/transmission-daemon.json", "limits": { "core": "0 0", "as": "1033990000 1033990000" }, "jail": { "name": "transmission", "log": true, "mount": { "\/srv\/transmission\/settings.json": "0", "\/srv\/transmission\/resume": "1", "\/srv\/transmission\/torrents": "1", "\/srv\/transmission\/blocklists": "1", "\/srv\/transmission\/stats.json": "1", "\/srv\/transmission\/done": "1" } } } }, "triggers": [ ], "data": { } }
seccomp config looks like this:
"whitelist": [
"accept4",
"access",
"arm_fadvise64_64",
"bind",
"brk",
"clock_gettime",
"clone",
"close",
"connect",
"epoll_create1",
"epoll_ctl",
"epoll_pwait",
"exit",
"exit_group",
"fadvise64",
"fallocate",
"fcntl",
"fcntl64",
"fstat",
"fstat64",
"fsync",
"futex",
"getdents64",
"getpeername",
"getpid",
"getsockname",
"getsockopt",
"ioctl",
"listen",
"_llseek",
"lseek",
"madvise",
"membarrier",
"mkdir",
"mmap",
"mmap2",
"mprotect",
"munmap",
"nanosleep",
"_newselect",
"open",
"pipe",
"pipe2",
"poll",
"pread64",
"prlimit64",
"pwrite64",
"read",
"readlink",
"readv",
"recvfrom",
"rename",
"rmdir",
"rt_sigaction",
"rt_sigprocmask",
"rt_sigreturn",
"select",
"sendto",
"setsockopt",
"shutdown",
"sigreturn",
"socket",
"stat",
"stat64",
"umask",
"uname",
"unlink",
"write",
"writev"
"policy": 1
