Turris Omnia
By chance setting a up a router just now from scratch with flashing https://repo.turris.cz/omnia/medkit/omnia-medkit-latest.tar.gz
installationsteps 5 out of 10 working ok, then 6/10 (use automatic updates
) produces this error
- despite the previous connectivity test checked ok
Firmware update has failed due to a connection or installation error. You should check your cable connection before proceeding to the next step. But do not worry much about the update as the router will run the updater regularly.
then clicking next
2. (leading to /foris/wizard/main/step/7)
An unexpected error has occurred
We are sorry, but your request raised an unexpected error. More information about this error may be found below.
RPCError('Failed to wipe updater: Error during exec: No such file or directory',)
Turning off automatic updates is proceeding with the installation to step 8/10 and thus omitting step 7/10 apparently
Not a good start after more than 2 months TOS 3.10 been a RC for testing
