Unter TO4.0 (clean install with med kit) without success I try to install a wifi card in pci3.
I can install and swap wifi cards without any problems at the pci1 and pci2 slots.
When I install a wifi card into pci3 it does not get recognized.
The new “Network Interface” setup in Foris shows only pci1 and pci2.
It does not matter which wifi card I’m using (5GHz or 2.4GHz).
Under TO3.X there where those ‘option path’ lines in /etc/config/wireless which could be edited to move a wifi card from pci1 or pci2 to pci3. Under TO4.0 this option is no longer availble.
Please advice - Thank you!
