TO 3.8.2 - DNSSEC problems
TO 3.8.2 still has problems with DNSSEC with DNS forwarding enablet e.g. TO can’t resolve download-installer.cdn.mozilla.net of Mozila download servers…
If I remember your situation, it would probably be remedied by knot-resolver >= 1.4.0, but that update didn’t make it into 3.8.2, apparently.
updated knot-resolver 1.4.0 should be in release 3.8.4. We have decided to separate it from dnsmasq security update which will be in 3.8.3
Although I updated to 3.8.4 I still face the issue with *.cdn.mozilla.net.
Can someone confirm that 3.8.4 or rather know-resolver >= 1.4.0 solved the issue?
Thanks.
Upcoming 3.8.5 should solve it, because all changes, which were planned for 3.8.4 was postponed due to KRACK vulnerability.
Thank you Pepe for the swift reply!
You may e.g. disable forwarding for now.
