MOX classic.
I wanted to test rescue mode 4, to see if I would be able, in case of any troubles, easily return to previous working state of OS. Therefore I exported schnapps of such working state of OS to root directory of USB flash drive (and renamed it to mox-medkit-latest.tar.gz - at first as link to exported schnapps stored in another directory, later as one stored directly in root USB directory). Unfortunately, neither of this two possibilities worked, even after repeated attempts (repeated for case when exported schnapps was stored directly in USB root directory).
I always waited for about half an hour to allow to complete the procedure after selecting rescue mode 4; MOX never did reboot ourselves as stated in documentation (maybe because of pertaining MOX reboot problem). After powering it off/on it rebooted in current state of OS (5.3.11 HBK).
Maybe I didn’t understand the documentation well or made some error during test procedure.
I suppose that while trying rescue mode 4, the procedure ignored mox-medkit-latest.tar.gz in USB root directory and used this in micro SD card… Is there any means to select between these? Or it is needed to rewrite mox-medkit-latest.tar.gz in micro SD card? and how to do it (in place, without removing it from MOX and do it in another Linux machine), if it is the case?
TIA for any hints/advice.
