# suricata -T
13/3/2017 – 14:17:50 - - Running suricata under test mode
13/3/2017 – 14:17:50 - - Including configuration file /tmp/suricata-rules/suricata-include.yaml.
13/3/2017 – 14:17:50 - - This is Suricata version 3.2 RELEASE
13/3/2017 – 14:18:07 - - Configuration provided was successfully loaded. Exiting.
You can see what options are available by just running “suricata -?”. I would recommend adding some verbosity flags, like “suricata -T -vv”. I got a long list of things when I did that.
That should tell you where things are failing. Since the init script is just a shell script, you can also try “sh -x /etc/init.d/suricata start”
There are some variables set in /etc/config/suricata, but I didn’t mess with any of them.
