I was away last week but my GF had no internet complaint which means it was working very well.
Yesterday I almost needed one hour in the morning to get it back to a normal running operation. No wifi could connect to the internet, most wired connection had issue too except one. My work PC, could not connect and it is sharing a switch with my personal pc which was working like a charm.
I have been switching cable, unpluging stuff like the usb on the turris… After many reset it went back to working ok. I don’t know the root causse.
In the evening I had to reset again. This morning once again.
I see that something updated early on the 21st but it worked well the whole day.
I don’t know how to troubleshoot more.
normally this nOOb is looking at the syslog ( in luci ) to see what is actually happening? See what goes wrong?
OK will do next time it goes down, because right now system logs shoes only since last reboot and it works…
Today I have plugging back a ext4 usb to try to setup a dlna.
Now my wifi does not connect to the internet. Luckily wired is fine.
I cannot reboot atm.
Here is the log.
Mar 4 14:05:49 turris kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Mar 4 14:05:49 turris kernel: [ 0.000000] Linux version 4.14.221 (packaging@turris.cz) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 6bf5bfc)) #0 SMP Thu Feb 18 01:22:47 2021
Mar 4 14:05:49 turris kernel: [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
Mar 4 14:05:49 turris kernel: [ 0.000000] Machine model: CZ.NIC Turris Mox Board
Mar 4 14:05:49 turris kernel: [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options ‘’)
Mar 4 14:05:49 turris kernel: [ 0.000000] bootconsole [ar3700_uart0] enabled
Mar 4 14:05:49 turris kernel: [ 0.000000] On node 0 totalpages: 131072
Mar 4 14:05:49 turris kernel: [ 0.000000] DMA zone: 2048 pages used for memmap
Mar 4 14:05:49 turris kernel: [ 0.000000] DMA zone: 0 pages reserved
Mar 4 14:05:49 turris kernel: [ 0.000000] DMA zone: 131072 pages, LIFO batch:31
Mar 4 14:05:49 turris syslog-ng[3598]: syslog-ng starting up; version=‘3.30.1’
Mar 4 14:05:49 turris kernel: [ 0.000000] psci: probing for conduit method from DT.
Mar 4 14:05:49 turris kernel: [ 0.000000] psci: PSCIv1.1 detected in firmware.
Mar 4 14:05:49 turris kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Mar 4 14:05:49 turris kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Mar 4 14:05:49 turris kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Mar 4 14:05:49 turris kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x494 with crng_init=0
Mar 4 14:05:49 turris kernel: [ 0.000000] percpu: Embedded 16 pages/cpu s26648 r8192 d30696 u65536
Mar 4 14:05:49 turris kernel: [ 0.000000] pcpu-alloc: s26648 r8192 d30696 u65536 alloc=164096
Mar 4 14:05:49 turris kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1
Mar 4 14:05:49 turris kernel: [ 0.000000] Detected VIPT I-cache on CPU0
Mar 4 14:05:49 turris kernel: [ 0.000000] Speculative Store Bypass Disable mitigation not required
Mar 4 14:05:49 turris kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
Mar 4 14:05:49 turris kernel: [ 0.000000] Kernel command line: earlyprintk console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 mangled_fs=btrfs root=PARTUUID=19835a86-01 rootflags=commit=5,subvol=@ rootwait rw cfg80211.freg=
Mar 4 14:05:49 turris kernel: [ 0.000000] PID hash table entries: 2048 (order: 2, 16384 bytes)
Mar 4 14:05:49 turris kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
Mar 4 14:05:49 turris kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes)
Mar 4 14:05:49 turris kernel: [ 0.000000] Memory: 496376K/524288K available (7358K kernel code, 468K rwdata, 1920K rodata, 320K init, 304K bss, 27912K reserved, 0K cma-reserved)
Mar 4 14:05:49 turris kernel: [ 0.000000] Virtual kernel memory layout:
Mar 4 14:05:49 turris kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Mar 4 14:05:49 turris kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Mar 4 14:05:49 turris kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff80087b0000 ( 7360 KB)
Mar 4 14:05:49 turris kernel: [ 0.000000] .rodata : 0xffffff80087b0000 - 0xffffff80089a0000 ( 1984 KB)
Mar 4 14:05:49 turris kernel: [ 0.000000] .init : 0xffffff80089a0000 - 0xffffff80089f0000 ( 320 KB)
Mar 4 14:05:49 turris kernel: [ 0.000000] .data : 0xffffff80089f0000 - 0xffffff8008a65008 ( 469 KB)
Mar 4 14:05:49 turris kernel: [ 0.000000] .bss : 0xffffff8008a65008 - 0xffffff8008ab11b0 ( 305 KB)
Mar 4 14:05:49 turris kernel: [ 0.000000] fixed : 0xffffffbefe7fb000 - 0xffffffbefec00000 ( 4116 KB)
Mar 4 14:05:49 turris kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Mar 4 14:05:49 turris kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Mar 4 14:05:49 turris kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf00800000 ( 8 MB actual)
Mar 4 14:05:49 turris kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc020000000 ( 512 MB)
Mar 4 14:05:49 turris kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Mar 4 14:05:49 turris kernel: [ 0.000000] Hierarchical RCU implementation.
Mar 4 14:05:49 turris kernel: [ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
Mar 4 14:05:49 turris kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Mar 4 14:05:49 turris kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Mar 4 14:05:49 turris kernel: [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
Mar 4 14:05:49 turris kernel: [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
Mar 4 14:05:49 turris kernel: [ 0.000000] GICv3: no VLPI support, no direct LPI support
Mar 4 14:05:49 turris kernel: [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000d1d40000
Mar 4 14:05:49 turris kernel: [ 0.000000] arch_timer: cp15 timer(s) running at 12.50MHz (phys).
Mar 4 14:05:49 turris kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049cda, max_idle_ns: 440795202628 ns
Mar 4 14:05:49 turris kernel: [ 0.000004] sched_clock: 56 bits at 12MHz, resolution 80ns, wraps every 4398046511080ns
Mar 4 14:05:49 turris kernel: [ 0.008430] Console: colour dummy device 80x25
Mar 4 14:05:49 turris kernel: [ 0.012945] Calibrating delay loop (skipped), value calculated using timer frequency… 25.00 BogoMIPS (lpj=125000)
Mar 4 14:05:49 turris kernel: [ 0.023589] pid_max: default: 32768 minimum: 301
Mar 4 14:05:49 turris kernel: [ 0.028437] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mar 4 14:05:49 turris kernel: [ 0.035177] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mar 4 14:05:49 turris kernel: [ 0.043420] ASID allocator initialised with 32768 entries
Mar 4 14:05:49 turris kernel: [ 0.049002] Hierarchical SRCU implementation.
Mar 4 14:05:49 turris kernel: [ 0.053876] smp: Bringing up secondary CPUs …
Mar 4 14:05:49 turris kernel: [ 0.058838] Detected VIPT I-cache on CPU1
Mar 4 14:05:49 turris kernel: [ 0.058869] GICv3: CPU1: found redistributor 1 region 0:0x00000000d1d60000
Mar 4 14:05:49 turris kernel: [ 0.058900] CPU1: Booted secondary processor [410fd034]
Mar 4 14:05:49 turris kernel: [ 0.058989] smp: Brought up 1 node, 2 CPUs
Mar 4 14:05:49 turris kernel: [ 0.079696] SMP: Total of 2 processors activated.
Mar 4 14:05:49 turris kernel: [ 0.084543] CPU features: detected: GIC system register CPU interface
Mar 4 14:05:49 turris kernel: [ 0.091164] CPU features: detected: 32-bit EL0 Support
Mar 4 14:05:49 turris kernel: [ 0.096464] CPU: All CPU(s) started at EL2
Mar 4 14:05:49 turris kernel: [ 0.100675] alternatives: patching kernel code
Mar 4 14:05:49 turris kernel: [ 0.105937] devtmpfs: initialized
Mar 4 14:05:49 turris kernel: [ 0.111584] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Mar 4 14:05:49 turris kernel: [ 0.121686] futex hash table entries: 512 (order: 4, 65536 bytes)
Mar 4 14:05:49 turris kernel: [ 0.128016] xor: measuring software checksum speed
Mar 4 14:05:49 turris kernel: [ 0.232912] 8regs : 1918.800 MB/sec
Mar 4 14:05:49 turris kernel: [ 0.332946] 8regs_prefetch: 1710.400 MB/sec
Mar 4 14:05:49 turris kernel: [ 0.432979] 32regs : 2358.800 MB/sec
Mar 4 14:05:49 turris kernel: [ 0.533012] 32regs_prefetch: 1984.400 MB/sec
Mar 4 14:05:49 turris kernel: [ 0.537679] xor: using function: 32regs (2358.800 MB/sec)
Mar 4 14:05:49 turris kernel: [ 0.543244] pinctrl core: initialized pinctrl subsystem
Mar 4 14:05:49 turris kernel: [ 0.549329] NET: Registered protocol family 16
Mar 4 14:05:49 turris kernel: [ 0.554897] cpuidle: using governor ladder
Mar 4 14:05:49 turris kernel: [ 0.559187] vdso: 2 pages (1 code @ ffffff80087b5000, 1 data @ ffffff80089f4000)
Mar 4 14:05:49 turris kernel: [ 0.566758] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Mar 4 14:05:49 turris kernel: [ 0.573967] DMA: preallocated 256 KiB pool for atomic allocations
Mar 4 14:05:49 turris kernel: [ 0.581506] d0012000.serial: ttyMV0 at MMIO 0xd0012000 (irq = 9, base_baud = 0) is a mvebu-uart
Mar 4 14:05:49 turris kernel: [ 0.590450] console [ttyMV0] enabled
Mar 4 14:05:49 turris kernel: [ 0.597755] bootconsole [ar3700_uart0] disabled
Mar 4 14:05:49 turris kernel: [ 0.787352] raid6: int64x1 gen() 320 MB/s
Mar 4 14:05:49 turris kernel: [ 0.957342] raid6: int64x1 xor() 317 MB/s
Mar 4 14:05:49 turris kernel: [ 1.127387] raid6: int64x2 gen() 520 MB/s
Mar 4 14:05:49 turris kernel: [ 1.297469] raid6: int64x2 xor() 450 MB/s
Mar 4 14:05:49 turris kernel: [ 1.467590] raid6: int64x4 gen() 780 MB/s
Mar 4 14:05:49 turris kernel: [ 1.637642] raid6: int64x4 xor() 551 MB/s
Mar 4 14:05:49 turris kernel: [ 1.807748] raid6: int64x8 gen() 938 MB/s
Mar 4 14:05:49 turris kernel: [ 1.977795] raid6: int64x8 xor() 563 MB/s
Mar 4 14:05:49 turris kernel: [ 2.147880] raid6: neonx1 gen() 593 MB/s
Mar 4 14:05:49 turris kernel: [ 2.317945] raid6: neonx1 xor() 625 MB/s
Mar 4 14:05:49 turris kernel: [ 2.487999] raid6: neonx2 gen() 985 MB/s
Mar 4 14:05:49 turris kernel: [ 2.658086] raid6: neonx2 xor() 946 MB/s
Mar 4 14:05:49 turris kernel: [ 2.828164] raid6: neonx4 gen() 1311 MB/s
Mar 4 14:05:49 turris kernel: [ 2.998210] raid6: neonx4 xor() 1171 MB/s
Mar 4 14:05:49 turris kernel: [ 3.168280] raid6: neonx8 gen() 1300 MB/s
Mar 4 14:05:49 turris kernel: [ 3.338380] raid6: neonx8 xor() 1132 MB/s
Mar 4 14:05:49 turris kernel: [ 3.342612] raid6: using algorithm neonx4 gen() 1311 MB/s
Mar 4 14:05:49 turris kernel: [ 3.348007] raid6: … xor() 1171 MB/s, rmw enabled
Mar 4 14:05:49 turris kernel: [ 3.353048] raid6: using neon recovery algorithm
Mar 4 14:05:49 turris kernel: [ 3.358902] SCSI subsystem initialized
Mar 4 14:05:49 turris kernel: [ 3.363182] libata version 3.00 loaded.
Mar 4 14:05:49 turris kernel: [ 3.363384] usbcore: registered new interface driver usbfs
Mar 4 14:05:49 turris kernel: [ 3.368732] usbcore: registered new interface driver hub
Mar 4 14:05:49 turris kernel: [ 3.374257] usbcore: registered new device driver usb
Mar 4 14:05:49 turris kernel: [ 3.380069] pxa2xx-i2c d0011000.i2c: could not find pctldev for node /soc/internal-regs@d0000000/pinctrl@13800/i2c1-pins, deferring probe
Mar 4 14:05:49 turris kernel: [ 3.394364] clocksource: Switched to clocksource arch_sys_counter
Mar 4 14:05:49 turris kernel: [ 3.407393] NET: Registered protocol family 2
Mar 4 14:05:49 turris kernel: [ 3.412003] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Mar 4 14:05:49 turris kernel: [ 3.419351] TCP bind hash table entries: 4096 (order: 4, 65536 bytes)
Mar 4 14:05:49 turris kernel: [ 3.425991] TCP: Hash tables configured (established 4096 bind 4096)
Mar 4 14:05:49 turris kernel: [ 3.432234] UDP hash table entries: 256 (order: 1, 8192 bytes)
Mar 4 14:05:49 turris kernel: [ 3.438263] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Mar 4 14:05:49 turris kernel: [ 3.444964] NET: Registered protocol family 1
Mar 4 14:05:49 turris kernel: [ 3.449233] PCI: CLS 0 bytes, default 128
Mar 4 14:05:49 turris kernel: [ 3.449855] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Mar 4 14:05:49 turris kernel: [ 3.462117] Crashlog allocated RAM at address 0x3f00000
Mar 4 14:05:49 turris kernel: [ 3.468096] workingset: timestamp_bits=46 max_order=17 bucket_order=0
Mar 4 14:05:49 turris kernel: [ 3.479104] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mar 4 14:05:49 turris kernel: [ 3.485090] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) © 2001-2006 Red Hat, Inc.
Mar 4 14:05:49 turris kernel: [ 3.497451] io scheduler noop registered
Mar 4 14:05:49 turris kernel: [ 3.501066] io scheduler deadline registered (default)
Mar 4 14:05:49 turris kernel: [ 3.609883] OF: PCI: host bridge /soc/pcie@d0070000 ranges:
Mar 4 14:05:49 turris kernel: [ 3.615500] OF: PCI: MEM 0xe8000000…0xe8ffffff -> 0xe8000000
Mar 4 14:05:49 turris kernel: [ 3.621324] OF: PCI: IO 0xe9000000…0xe900ffff -> 0xe9000000
Mar 4 14:05:49 turris kernel: [ 4.124370] advk-pcie d0070000.pcie: link up
Mar 4 14:05:49 turris kernel: [ 4.128616] advk-pcie d0070000.pcie: PCI host bridge to bus 0000:00
Mar 4 14:05:49 turris kernel: [ 4.135288] pci_bus 0000:00: root bus resource [bus 00-ff]
Mar 4 14:05:49 turris kernel: [ 4.140782] pci_bus 0000:00: root bus resource [mem 0xe8000000-0xe8ffffff]
Mar 4 14:05:49 turris kernel: [ 4.147715] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0xe9000000-0xe900ffff])
Mar 4 14:05:49 turris kernel: [ 4.157748] pci 0000:00:00.0: [168c:003c] type 00 class 0x028000
Mar 4 14:05:49 turris kernel: [ 4.157835] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Mar 4 14:05:49 turris kernel: [ 4.157926] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Mar 4 14:05:49 turris kernel: [ 4.158101] pci 0000:00:00.0: supports D1 D2
Mar 4 14:05:49 turris kernel: [ 4.158258] pci 0000:00:00.0: BAR 0: assigned [mem 0xe8000000-0xe81fffff 64bit]
Mar 4 14:05:49 turris kernel: [ 4.165859] pci 0000:00:00.0: BAR 6: assigned [mem 0xe8200000-0xe820ffff pref]
Mar 4 14:05:49 turris kernel: [ 4.174536] mv_xor d0060900.xor: Marvell shared XOR driver
Mar 4 14:05:49 turris kernel: [ 4.234945] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Mar 4 14:05:49 turris kernel: [ 4.304941] mv_xor d0060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Mar 4 14:05:49 turris kernel: [ 4.312785] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Mar 4 14:05:49 turris kernel: [ 4.321357] cacheinfo: Unable to detect cache hierarchy for CPU 0
Mar 4 14:05:49 turris kernel: [ 4.331341] loop: module loaded
Mar 4 14:05:49 turris kernel: [ 4.340827] random: fast init done
Mar 4 14:05:49 turris kernel: [ 4.349321] m25p80 spi0.0: w25q64dw (8192 Kbytes)
Mar 4 14:05:49 turris kernel: [ 4.354067] 5 fixed-partitions partitions found on MTD device spi0.0
Mar 4 14:05:49 turris kernel: [ 4.360513] Creating 5 MTD partitions on “spi0.0”:
Mar 4 14:05:49 turris kernel: [ 4.365349] 0x000000000000-0x000000020000 : “secure-firmware”
Mar 4 14:05:49 turris kernel: [ 4.371973] 0x000000020000-0x000000180000 : “u-boot”
Mar 4 14:05:49 turris kernel: [ 4.377357] 0x000000180000-0x000000190000 : “u-boot-env”
Mar 4 14:05:49 turris kernel: [ 4.383054] 0x000000190000-0x0000007f0000 : “Rescue system”
Mar 4 14:05:49 turris kernel: [ 4.389509] 0x0000007f0000-0x000000800000 : “dtb”
Mar 4 14:05:49 turris kernel: [ 4.395177] moxtet spi0.1: Found SD Turris Mox CPU module
Mar 4 14:05:49 turris kernel: [ 4.400769] moxtet spi0.1: PCIe module found
Mar 4 14:05:49 turris kernel: [ 4.404849] moxtet spi0.1: Topaz Switch module found
Mar 4 14:05:49 turris kernel: [ 4.410684] libphy: Fixed MDIO Bus: probed
Mar 4 14:05:49 turris kernel: [ 4.415437] libphy: orion_mdio_bus: probed
Mar 4 14:05:49 turris kernel: [ 4.420667] mv88e6085 d0032004.mdio-mii:02: switch 0x3400 detected: Marvell 88E6141, revision 0
Mar 4 14:05:49 turris kernel: [ 4.440632] libphy: /soc/internal-regs@d0000000/mdio@32004/switch0@2/mdio: probed
Mar 4 14:05:49 turris kernel: [ 4.462957] mvneta d0030000.ethernet eth0: Using device tree mac address d8:58:d7:00:bc:78
Mar 4 14:05:49 turris kernel: [ 4.472854] mvneta d0040000.ethernet eth1: Using device tree mac address d8:58:d7:00:bc:79
Mar 4 14:05:49 turris kernel: [ 4.481396] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Mar 4 14:05:49 turris kernel: [ 4.487811] ehci-pci: EHCI PCI platform driver
Mar 4 14:05:49 turris kernel: [ 4.492796] ehci-platform: EHCI generic platform driver
Mar 4 14:05:49 turris kernel: [ 4.497962] ehci-orion: EHCI orion driver
Mar 4 14:05:49 turris kernel: [ 4.502413] orion-ehci d005e000.usb: EHCI Host Controller
Mar 4 14:05:49 turris kernel: [ 4.507666] orion-ehci d005e000.usb: new USB bus registered, assigned bus number 1
Mar 4 14:05:49 turris kernel: [ 4.515745] orion-ehci d005e000.usb: irq 13, io mem 0xd005e000
Mar 4 14:05:49 turris kernel: [ 4.554365] orion-ehci d005e000.usb: USB 2.0 started, EHCI 1.00
Mar 4 14:05:49 turris kernel: [ 4.560961] hub 1-0:1.0: USB hub found
Mar 4 14:05:49 turris kernel: [ 4.564618] hub 1-0:1.0: 1 port detected
Mar 4 14:05:49 turris kernel: [ 4.569824] usbcore: registered new interface driver usb-storage
Mar 4 14:05:49 turris kernel: [ 4.576252] i2c /dev entries driver
Mar 4 14:05:49 turris kernel: [ 4.580377] armada_37xx_wdt d0008300.watchdog: Initial timeout 120 sec
Mar 4 14:05:49 turris kernel: [ 4.587365] sdhci: Secure Digital Host Controller Interface driver
Mar 4 14:05:49 turris kernel: [ 4.593763] sdhci: Copyright© Pierre Ossman
Mar 4 14:05:49 turris kernel: [ 4.598062] sdhci-pltfm: SDHCI platform and OF driver helper
Mar 4 14:05:49 turris kernel: [ 4.604268] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
Mar 4 14:05:49 turris kernel: [ 4.610349] xenon-sdhci d00d8000.sdhci: Got CD GPIO
Mar 4 14:05:49 turris kernel: [ 4.616956] NET: Registered protocol family 10
Mar 4 14:05:49 turris kernel: [ 4.622279] Segment Routing with IPv6
Mar 4 14:05:49 turris kernel: [ 4.625787] NET: Registered protocol family 17
Mar 4 14:05:49 turris kernel: [ 4.630245] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Mar 4 14:05:49 turris kernel: [ 4.644200] 8021q: 802.1Q VLAN Support v1.8
Mar 4 14:05:49 turris kernel: [ 4.650202] Btrfs loaded, crc32c=crc32c-arm64-ce
Mar 4 14:05:49 turris kernel: [ 4.659028] rtc-ds1307 0-006f: registered as rtc0
Mar 4 14:05:49 turris kernel: [ 4.663592] i2c i2c-0: PXA I2C adapter
Mar 4 14:05:49 turris kernel: [ 4.668247] mv88e6085 d0032004.mdio-mii:02: switch 0x3400 detected: Marvell 88E6141, revision 0
Mar 4 14:05:49 turris kernel: [ 4.687989] libphy: /soc/internal-regs@d0000000/mdio@32004/switch0@2/mdio: probed
Mar 4 14:05:49 turris kernel: [ 4.704897] DSA: switch 0 0 parsed
Mar 4 14:05:49 turris kernel: [ 4.708426] DSA: tree 0 parsed
Mar 4 14:05:49 turris kernel: [ 5.416319] mv88e6085 d0032004.mdio-mii:02 lan1 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:11] driver [Marvell 88E6390]
Mar 4 14:05:49 turris kernel: [ 5.536322] mv88e6085 d0032004.mdio-mii:02 lan2 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:12] driver [Marvell 88E6390]
Mar 4 14:05:49 turris kernel: [ 5.656322] mv88e6085 d0032004.mdio-mii:02 lan3 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:13] driver [Marvell 88E6390]
Mar 4 14:05:49 turris kernel: [ 5.776321] mv88e6085 d0032004.mdio-mii:02 lan4 (uninitialized): PHY [!soc!internal-regs@d0000000!mdio@32004!switch0@2!mdio:14] driver [Marvell 88E6390]
Mar 4 14:05:49 turris kernel: [ 5.793502] xhci-hcd d0058000.usb: xHCI Host Controller
Mar 4 14:05:49 turris kernel: [ 5.798686] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 2
Mar 4 14:05:49 turris kernel: [ 5.806691] xhci-hcd d0058000.usb: hcc params 0x0a000998 hci version 0x100 quirks 0x0000000000010010
Mar 4 14:05:49 turris kernel: [ 5.816013] xhci-hcd d0058000.usb: irq 12, io mem 0xd0058000
Mar 4 14:05:49 turris kernel: [ 5.822295] hub 2-0:1.0: USB hub found
Mar 4 14:05:49 turris kernel: [ 5.825865] hub 2-0:1.0: 1 port detected
Mar 4 14:05:49 turris kernel: [ 5.829979] xhci-hcd d0058000.usb: xHCI Host Controller
Mar 4 14:05:49 turris kernel: [ 5.835462] xhci-hcd d0058000.usb: new USB bus registered, assigned bus number 3
Mar 4 14:05:49 turris kernel: [ 5.842830] xhci-hcd d0058000.usb: Host supports USB 3.0 SuperSpeed
Mar 4 14:05:49 turris kernel: [ 5.849622] usb usb3: We don’t know the algorithms for LPM for this host, disabling LPM.
Mar 4 14:05:49 turris kernel: [ 5.858475] hub 3-0:1.0: USB hub found
Mar 4 14:05:49 turris kernel: [ 5.862201] hub 3-0:1.0: 1 port detected
Mar 4 14:05:49 turris kernel: [ 5.866740] xenon-sdhci d00d0000.sdhci: allocated mmc-pwrseq
Mar 4 14:05:49 turris kernel: [ 5.944376] mmc0: SDHCI controller on d00d0000.sdhci [d00d0000.sdhci] using ADMA
Mar 4 14:05:49 turris kernel: [ 5.952476] xenon-sdhci d00d8000.sdhci: Got CD GPIO
Mar 4 14:05:49 turris kernel: [ 5.997605] sdio_read_cccr card report SDIO_UHS_DDR50
Mar 4 14:05:49 turris kernel: [ 6.002655] sdio_read_cccr card report SDIO_UHS_SDR50
Mar 4 14:05:49 turris kernel: [ 6.007624] sdio_read_cccr card report SDIO_UHS_SDR104
Mar 4 14:05:49 turris kernel: [ 6.014554] mmc1: SDHCI controller on d00d8000.sdhci [d00d8000.sdhci] using ADMA
Mar 4 14:05:49 turris kernel: [ 6.023048] armada-37xx-rwtm-mailbox d00b0000.mailbox: Trust Status: 00000000
Mar 4 14:05:49 turris kernel: [ 6.093050] Turris Mox serial number 0000000D3000335E
Mar 4 14:05:49 turris kernel: [ 6.098020] board version 22
Mar 4 14:05:49 turris kernel: [ 6.101960] burned RAM size 512 MiB
Mar 4 14:05:49 turris kernel: [ 6.363115] rtc-ds1307 0-006f: setting system clock to 2021-03-04 13:05:20 UTC (1614863120)
Mar 4 14:05:49 turris kernel: [ 6.363171] random: crng init done
Mar 4 14:05:49 turris kernel: [ 6.443178] usb 2-1: new high-speed USB device number 2 using xhci-hcd
Mar 4 14:05:49 turris kernel: [ 6.754134] Waiting for root device PARTUUID=19835a86-01…
Mar 4 14:05:49 turris kernel: [ 6.764607] xenon-sdhci d00d0000.sdhci: Timing issue might occur in DDR mode
Mar 4 14:05:49 turris kernel: [ 6.776609] mmc0: new ultra high speed DDR50 SDIO card at address 0001
Mar 4 14:05:49 turris kernel: [ 6.796990] mmc1: new high speed SDHC card at address aaaa
Mar 4 14:05:49 turris kernel: [ 6.803380] mmcblk1: mmc1:aaaa SA16G 14.8 GiB
Mar 4 14:05:49 turris kernel: [ 6.810584] mmcblk1: p1
Mar 4 14:05:49 turris kernel: [ 6.821299] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Mar 4 14:05:49 turris kernel: [ 6.828727] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 1th superblock
Mar 4 14:05:49 turris kernel: [ 6.837882] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Mar 4 14:05:49 turris kernel: [ 6.845423] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 2th superblock
Mar 4 14:05:49 turris kernel: [ 6.853389] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Mar 4 14:05:49 turris kernel: [ 6.860891] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 1th superblock
Mar 4 14:05:49 turris kernel: [ 6.868656] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
Mar 4 14:05:49 turris kernel: [ 6.875954] F2FS-fs (mmcblk1p1): Can’t find valid F2FS filesystem in 2th superblock
Mar 4 14:05:49 turris kernel: [ 6.886091] BTRFS: device label turris devid 1 transid 2574 /dev/root
Mar 4 14:05:49 turris kernel: [ 6.894081] BTRFS info (device mmcblk1p1): disk space caching is enabled
Mar 4 14:05:49 turris kernel: [ 6.900983] BTRFS info (device mmcblk1p1): has skinny extents
Mar 4 14:05:49 turris kernel: [ 6.927387] BTRFS info (device mmcblk1p1): enabling ssd optimizations
Mar 4 14:05:49 turris kernel: [ 6.936395] usb-storage 2-1:1.0: USB Mass Storage device detected
Mar 4 14:05:49 turris kernel: [ 6.943420] scsi host0: usb-storage 2-1:1.0
Mar 4 14:05:49 turris kernel: [ 6.950717] VFS: Mounted root (btrfs filesystem) on device 0:12.
Mar 4 14:05:49 turris kernel: [ 6.959251] devtmpfs: mounted
Mar 4 14:05:49 turris kernel: [ 6.962626] Freeing unused kernel memory: 320K
Mar 4 14:05:49 turris kernel: 7.117838] init: Console is alive
Mar 4 14:05:49 turris kernel: 7.121347] init: - watchdog -
Mar 4 14:05:49 turris kernel: [ 7.955449] scsi 0:0:0:0: Direct-Access USB Mass Storage Device 1.00 PQ: 0 ANSI: 0
Mar 4 14:05:49 turris kernel: [ 7.978291] sd 0:0:0:0: [sda] Attached SCSI removable disk
Mar 4 14:05:49 turris kernel: 8.006159] kmodloader: loading kernel modules from /etc/modules-boot.d/
Mar 4 14:05:49 turris kernel: [ 8.026358] exFAT: Version 1.2.9
Mar 4 14:05:49 turris kernel: [ 8.048073] SGI XFS with ACLs, security attributes, no debug enabled
Mar 4 14:05:49 turris kernel: [ 8.061746] usbcore: registered new interface driver uas
Mar 4 14:05:49 turris kernel: 8.067477] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Mar 4 14:05:49 turris kernel: 8.085042] init: - preinit -
Mar 4 14:05:49 turris kernel: 11.558833] mount_root: mounting /dev/root
Mar 4 14:05:49 turris kernel: [ 11.565556] BTRFS info (device mmcblk1p1): disk space caching is enabled
Mar 4 14:05:49 turris kernel: 11.575156] mount_root: loading kmods from internal overlay
Mar 4 14:05:49 turris kernel: 11.618655] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Mar 4 14:05:49 turris kernel: 11.627703] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Mar 4 14:05:49 turris kernel: 12.123329] block: attempting to load /etc/config/fstab
Mar 4 14:05:49 turris kernel: 12.133890] block: extroot: not configured
Mar 4 14:05:49 turris kernel: 12.739754] procd: - early -
Mar 4 14:05:49 turris kernel: 12.742865] procd: - watchdog -
Mar 4 14:05:49 turris kernel: 13.415440] procd: - watchdog -
Mar 4 14:05:49 turris kernel: 13.419062] procd: - ubus -
Mar 4 14:05:49 turris kernel: 13.473294] procd: - init -
Mar 4 14:05:49 turris kernel: 13.632563] kmodloader: loading kernel modules from /etc/modules.d/*
Mar 4 14:05:49 turris kernel: [ 13.659257] zram: Added device: zram0
Mar 4 14:05:49 turris kernel: [ 13.691825] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
Mar 4 14:05:49 turris kernel: [ 13.708250] Key type dns_resolver registered
Mar 4 14:05:49 turris kernel: [ 13.723911] Key type cifs.idmap registered
Mar 4 14:05:49 turris kernel: [ 13.746261] RPC: Registered named UNIX socket transport module.
Mar 4 14:05:49 turris kernel: [ 13.752449] RPC: Registered udp transport module.
Mar 4 14:05:49 turris kernel: [ 13.757103] RPC: Registered tcp transport module.
Mar 4 14:05:49 turris kernel: [ 13.762187] RPC: Registered tcp NFSv4.1 backchannel transport module.
Mar 4 14:05:49 turris kernel: [ 13.774555] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Mar 4 14:05:49 turris kernel: [ 13.822612] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Mar 4 14:05:49 turris kernel: [ 13.857117] Installing knfsd (copyright © 1996 okir@monad.swb.de).
Mar 4 14:05:49 turris kernel: [ 13.872326] NFS: Registering the id_resolver key type
Mar 4 14:05:49 turris kernel: [ 13.877405] Key type id_resolver registered
Mar 4 14:05:49 turris kernel: [ 13.881722] Key type id_legacy registered
Mar 4 14:05:49 turris kernel: [ 13.895521] ip6_tables: © 2000-2006 Netfilter Core Team
Mar 4 14:05:49 turris kernel: [ 13.908313] Netfilter messages via NETLINK v0.30.
Mar 4 14:05:49 turris kernel: [ 13.915794] ip_set: protocol 6
Mar 4 14:05:49 turris kernel: [ 13.949965] Loading modules backported from Linux version v4.19.161-0-gdaefdc9eb24b
Mar 4 14:05:49 turris kernel: [ 13.958020] Backport generated by backports.git v4.19.161-1-0-g4bb568fe
Mar 4 14:05:49 turris kernel: [ 14.009545] hidraw: raw HID events driver © Jiri Kosina
Mar 4 14:05:49 turris kernel: [ 14.018734] Mirror/redirect action on
Mar 4 14:05:49 turris kernel: [ 14.032740] u32 classifier
Mar 4 14:05:49 turris kernel: [ 14.035642] input device check on
Mar 4 14:05:49 turris kernel: [ 14.039083] Actions configured
Mar 4 14:05:49 turris kernel: [ 14.050994] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
Mar 4 14:05:49 turris kernel: [ 14.057648] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
Mar 4 14:05:49 turris kernel: [ 14.099775] fuse init (API version 7.26)
Mar 4 14:05:49 turris kernel: [ 14.136491] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x3c.
Mar 4 14:05:49 turris kernel: [ 14.147151] ath10k_pci 0000:00:00.0: enabling device (0000 -> 0002)
Mar 4 14:05:49 turris kernel: [ 14.153979] ath10k_pci 0000:00:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
Mar 4 14:05:49 turris kernel: [ 14.387786] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/fwcfg-pci-0000:00:00.0.txt failed with error -2
Mar 4 14:05:49 turris kernel: [ 14.398810] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.155293] firmware ath10k!fwcfg-pci-0000:00:00.0.txt: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.164325] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.175470] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.196779] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.206382] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.217097] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.239117] firmware ath10k!cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.248186] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-5.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.259515] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.274322] firmware ath10k!QCA988X!hw2.0!ct-firmware-5.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.284203] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/ct-firmware-2.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.295263] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.316309] firmware ath10k!QCA988X!hw2.0!ct-firmware-2.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.326311] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-6.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.337529] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.352875] firmware ath10k!QCA988X!hw2.0!firmware-6.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.362205] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-5.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.373343] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.388177] firmware ath10k!QCA988X!hw2.0!firmware-5.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.397783] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-4.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.409004] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.424090] firmware ath10k!QCA988X!hw2.0!firmware-4.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.433357] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/firmware-3.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.444528] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.465875] firmware ath10k!QCA988X!hw2.0!firmware-3.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.488946] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
Mar 4 14:05:49 turris kernel: [ 15.498446] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
Mar 4 14:05:49 turris kernel: [ 15.511925] ath10k_pci 0000:00:00.0: firmware ver 10.1-ct-8x-__fW-022-538f0906 api 2 features wmi-10.x,has-wmi-mgmt-tx,mfp,txstatus-noack,wmi-10.x-CT,ratemask-CT,txrate-CT,get-temp-CT,tx-rc-CT,cust-stats-CT,retry-gt2-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT crc32 e1c91a74
Mar 4 14:05:49 turris kernel: [ 15.565601] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
Mar 4 14:05:49 turris kernel: [ 15.576267] ath10k_pci 0000:00:00.0: Falling back to user helper
Mar 4 14:05:49 turris kernel: [ 15.591474] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
Mar 4 14:05:49 turris kernel: [ 15.602712] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
Mar 4 14:05:49 turris kernel: [ 16.534519] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Mar 4 14:05:49 turris kernel: [ 16.551613] ath10k_pci 0000:00:00.0: wmi print ‘P 128 V 8 T 410’
Mar 4 14:05:49 turris kernel: [ 16.558027] ath10k_pci 0000:00:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
Mar 4 14:05:49 turris kernel: [ 16.566225] ath10k_pci 0000:00:00.0: wmi print ‘alloc rem: 20984 iram: 25656’
Mar 4 14:05:49 turris kernel: [ 16.632834] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 2 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
Mar 4 14:05:49 turris kernel: [ 16.646038] ath10k_pci 0000:00:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
Mar 4 14:05:49 turris kernel: [ 16.772588] ath: EEPROM regdomain: 0x0
Mar 4 14:05:49 turris kernel: [ 16.772602] ath: EEPROM indicates default country code should be used
Mar 4 14:05:49 turris kernel: [ 16.772607] ath: doing EEPROM country->regdmn map search
Mar 4 14:05:49 turris kernel: [ 16.772617] ath: country maps to regdmn code: 0x3a
Mar 4 14:05:49 turris kernel: [ 16.772624] ath: Country alpha2 being used: US
Mar 4 14:05:49 turris kernel: [ 16.772629] ath: Regpair used: 0x3a
Mar 4 14:05:49 turris kernel: [ 16.812324] Bluetooth: Core ver 2.22
Mar 4 14:05:49 turris kernel: [ 16.816168] NET: Registered protocol family 31
Mar 4 14:05:49 turris kernel: [ 16.820601] Bluetooth: HCI device and connection manager initialized
Mar 4 14:05:49 turris kernel: [ 16.827326] Bluetooth: HCI socket layer initialized
Mar 4 14:05:49 turris kernel: [ 16.832140] Bluetooth: L2CAP socket layer initialized
Mar 4 14:05:49 turris kernel: [ 16.837708] Bluetooth: SCO socket layer initialized
Mar 4 14:05:49 turris kernel: [ 16.844440] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Mar 4 14:05:49 turris kernel: [ 16.849690] Bluetooth: BNEP filters: protocol multicast
Mar 4 14:05:49 turris kernel: [ 16.855383] Bluetooth: BNEP socket layer initialized
Mar 4 14:05:49 turris kernel: [ 16.862028] Bridge firewalling registered
Mar 4 14:05:49 turris kernel: [ 16.873213] Bluetooth: vendor=0x2df, device=0x9142, class=255, fn=2
Mar 4 14:05:49 turris kernel: [ 18.526177] Bluetooth: FW download over, size 623240 bytes
Mar 4 14:05:49 turris kernel: [ 18.774687] sdio platform data not available
Mar 4 14:05:49 turris kernel: [ 18.783286] usbcore: registered new interface driver btusb
Mar 4 14:05:49 turris kernel: [ 18.806393] Ebtables v2.0 registered
Mar 4 14:05:49 turris kernel: [ 18.811595] Bluetooth: HCI UART driver ver 2.3
Mar 4 14:05:49 turris kernel: [ 18.816073] Bluetooth: HCI UART protocol H4 registered
Mar 4 14:05:49 turris kernel: [ 18.821345] Bluetooth: HCI UART protocol BCSP registered
Mar 4 14:05:49 turris kernel: [ 18.826942] Bluetooth: HCI UART protocol ATH3K registered
Mar 4 14:05:49 turris kernel: [ 18.834425] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Mar 4 14:05:49 turris kernel: [ 18.840406] Bluetooth: HIDP socket layer initialized
Mar 4 14:05:49 turris kernel: [ 18.850397] ip_tables: © 2000-2006 Netfilter Core Team
Mar 4 14:05:49 turris kernel: [ 18.905637] nf_conntrack version 0.5.0 (4096 buckets, 16384 max)
Mar 4 14:05:49 turris kernel: [ 18.916546] ctnetlink v0.93: registering with nfnetlink.
Mar 4 14:05:49 turris kernel: [ 18.982355] Bluetooth: RFCOMM TTY layer initialized
Mar 4 14:05:49 turris kernel: [ 18.987381] Bluetooth: RFCOMM socket layer initialized
Mar 4 14:05:49 turris kernel: [ 18.992647] Bluetooth: RFCOMM ver 1.11
Mar 4 14:05:49 turris kernel: [ 19.000289] usbcore: registered new interface driver ums-alauda
Mar 4 14:05:49 turris kernel: [ 19.007217] usbcore: registered new interface driver ums-cypress
Mar 4 14:05:49 turris kernel: [ 19.014250] usbcore: registered new interface driver ums-datafab
Mar 4 14:05:49 turris kernel: [ 19.021185] usbcore: registered new interface driver ums-freecom
Mar 4 14:05:49 turris kernel: [ 19.027507] mwifiex_sdio mmc0:0001:1: WLAN is not the winner! Skip FW dnld
Mar 4 14:05:49 turris kernel: [ 19.035609] usbcore: registered new interface driver ums-isd200
Mar 4 14:05:49 turris kernel: [ 19.043315] usbcore: registered new interface driver ums-jumpshot
Mar 4 14:05:49 turris kernel: [ 19.050461] usbcore: registered new interface driver ums-karma
Mar 4 14:05:49 turris kernel: [ 19.057765] usbcore: registered new interface driver ums-sddr09
Mar 4 14:05:49 turris kernel: [ 19.064981] usbcore: registered new interface driver ums-sddr55
Mar 4 14:05:49 turris kernel: [ 19.072155] usbcore: registered new interface driver ums-usbat
Mar 4 14:05:49 turris kernel: [ 19.112369] xt_time: kernel timezone is -0000
Mar 4 14:05:49 turris kernel: [ 19.137818] PPP generic driver version 2.4.2
Mar 4 14:05:49 turris kernel: [ 19.144768] NET: Registered protocol family 24
Mar 4 14:05:49 turris kernel: 19.166276] kmodloader: done loading kernel modules from /etc/modules.d/*
Mar 4 14:05:49 turris kernel: [ 19.394555] mwifiex_sdio mmc0:0001:1: WLAN FW is active
Mar 4 14:05:49 turris kernel: [ 19.440688] mwifiex_sdio mmc0:0001:1: Unknown api_id: 3
Mar 4 14:05:49 turris kernel: [ 19.446154] mwifiex_sdio mmc0:0001:1: Unknown api_id: 4
Mar 4 14:05:49 turris kernel: [ 19.451302] mwifiex_sdio mmc0:0001:1: Unknown GET_HW_SPEC TLV type: 0x217
Mar 4 14:05:49 turris kernel: [ 19.477606] mwifiex_sdio mmc0:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p197)
Mar 4 14:05:49 turris kernel: [ 19.485992] mwifiex_sdio mmc0:0001:1: driver_version = mwifiex 1.0 (16.68.1.p197)
Mar 4 14:05:49 turris kernel: [ 20.356706] zram0: detected capacity change from 0 to 253755392
Mar 4 14:05:49 turris kernel: [ 20.387684] Adding 247804k swap on /dev/zram0. Priority:-2 extents:1 across:247804k SS
Mar 4 14:05:49 turris kernel: [ 22.668289] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Mar 4 14:05:49 turris kernel: [ 22.703225] mvneta d0040000.ethernet eth1: configuring for 802.3z/1000base-x link mode
Mar 4 14:05:49 turris kernel: [ 22.713088] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Mar 4 14:05:49 turris kernel: [ 22.729893] mv88e6085 d0032004.mdio-mii:02 lan1: configuring for phy/ link mode
Mar 4 14:05:49 turris kernel: [ 22.748540] br-lan: port 1(lan1) entered blocking state
Mar 4 14:05:49 turris kernel: [ 22.753995] br-lan: port 1(lan1) entered disabled state
Mar 4 14:05:49 turris kernel: [ 22.768505] device lan1 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 22.773039] device eth1 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 22.812624] mv88e6085 d0032004.mdio-mii:02 lan2: configuring for phy/ link mode
Mar 4 14:05:49 turris kernel: [ 22.829102] br-lan: port 2(lan2) entered blocking state
Mar 4 14:05:49 turris kernel: [ 22.834520] br-lan: port 2(lan2) entered disabled state
Mar 4 14:05:49 turris kernel: [ 22.850925] device lan2 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 22.886408] mv88e6085 d0032004.mdio-mii:02 lan3: configuring for phy/ link mode
Mar 4 14:05:49 turris kernel: [ 22.902342] br-lan: port 3(lan3) entered blocking state
Mar 4 14:05:49 turris kernel: [ 22.907798] br-lan: port 3(lan3) entered disabled state
Mar 4 14:05:49 turris kernel: [ 22.922585] device lan3 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 22.924498] mvneta d0040000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Mar 4 14:05:49 turris kernel: [ 22.958008] mv88e6085 d0032004.mdio-mii:02 lan4: configuring for phy/ link mode
Mar 4 14:05:49 turris kernel: [ 22.973323] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Mar 4 14:05:49 turris kernel: [ 22.989206] br-lan: port 4(lan4) entered blocking state
Mar 4 14:05:49 turris kernel: [ 22.994599] br-lan: port 4(lan4) entered disabled state
Mar 4 14:05:49 turris kernel: [ 23.008757] device lan4 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 23.154710] mvneta d0030000.ethernet eth0: PHY [d0032004.mdio-mii:01] driver [Marvell 88E1510]
Mar 4 14:05:49 turris kernel: [ 23.163621] mvneta d0030000.ethernet eth0: configuring for phy/rgmii-id link mode
Mar 4 14:05:49 turris kernel: [ 23.172462] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Mar 4 14:05:49 turris kernel: [ 23.185127] IPv6: ADDRCONF(NETDEV_UP): eth0.100: link is not ready
Mar 4 14:05:49 turris kernel: [ 23.710171] ath: EEPROM regdomain: 0x82d4
Mar 4 14:05:49 turris kernel: [ 23.714171] ath: EEPROM indicates we should expect a country code
Mar 4 14:05:49 turris kernel: [ 23.720565] ath: doing EEPROM country->regdmn map search
Mar 4 14:05:49 turris kernel: [ 23.725980] ath: country maps to regdmn code: 0x37
Mar 4 14:05:49 turris kernel: [ 23.730906] ath: Country alpha2 being used: ES
Mar 4 14:05:49 turris kernel: [ 23.735342] ath: Regpair used: 0x37
Mar 4 14:05:49 turris kernel: [ 23.739303] ath: regdomain 0x82d4 dynamically updated by user
Mar 4 14:05:49 turris kernel: [ 24.631350] mv88e6085 d0032004.mdio-mii:02 lan1: Link is Up - 100Mbps/Full - flow control off
Mar 4 14:05:49 turris kernel: [ 24.798981] mv88e6085 d0032004.mdio-mii:02 lan4: Link is Up - 100Mbps/Full - flow control rx/tx
Mar 4 14:05:49 turris kernel: [ 25.422663] ath10k_pci 0000:00:00.0: 10.1 wmi init: vdevs: 16 peers: 127 tid: 256
Mar 4 14:05:49 turris kernel: [ 25.439938] ath10k_pci 0000:00:00.0: wmi print ‘P 128 V 8 T 410’
Mar 4 14:05:49 turris kernel: [ 25.446135] ath10k_pci 0000:00:00.0: wmi print ‘msdu-desc: 1424 sw-crypt: 0 ct-sta: 0’
Mar 4 14:05:49 turris kernel: [ 25.454381] ath10k_pci 0000:00:00.0: wmi print ‘alloc rem: 20984 iram: 25656’
Mar 4 14:05:49 turris kernel: [ 25.522731] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Mar 4 14:05:49 turris kernel: [ 25.538150] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mar 4 14:05:49 turris kernel: [ 25.548214] br-lan: port 1(lan1) entered blocking state
Mar 4 14:05:49 turris kernel: [ 25.553655] br-lan: port 1(lan1) entered forwarding state
Mar 4 14:05:49 turris kernel: [ 25.559499] br-lan: port 4(lan4) entered blocking state
Mar 4 14:05:49 turris kernel: [ 25.564999] br-lan: port 4(lan4) entered forwarding state
Mar 4 14:05:49 turris kernel: [ 25.610578] mwifiex_sdio mmc0:0001:1: CMD_RESP: cmd 0x20 error, result=0x1
Mar 4 14:05:49 turris kernel: [ 25.628919] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mar 4 14:05:49 turris kernel: [ 25.644480] br-lan: port 5(wlan0) entered blocking state
Mar 4 14:05:49 turris kernel: [ 25.649673] br-lan: port 5(wlan0) entered disabled state
Mar 4 14:05:49 turris kernel: [ 25.655644] device wlan0 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 25.970856] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mar 4 14:05:49 turris kernel: [ 25.977776] br-lan: port 5(wlan0) entered blocking state
Mar 4 14:05:49 turris kernel: [ 25.983141] br-lan: port 5(wlan0) entered forwarding state
Mar 4 14:05:49 turris kernel: [ 26.039894] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Mar 4 14:05:49 turris kernel: [ 26.060705] br-lan: port 6(wlan1) entered blocking state
Mar 4 14:05:49 turris kernel: [ 26.066120] br-lan: port 6(wlan1) entered disabled state
Mar 4 14:05:49 turris kernel: [ 26.072063] device wlan1 entered promiscuous mode
Mar 4 14:05:49 turris kernel: [ 26.076826] br-lan: port 6(wlan1) entered blocking state
Mar 4 14:05:49 turris kernel: [ 26.082370] br-lan: port 6(wlan1) entered forwarding state
Mar 4 14:05:49 turris kernel: [ 26.196402] mv88e6085 d0032004.mdio-mii:02 lan3: Link is Up - 1Gbps/Full - flow control rx/tx
Mar 4 14:05:49 turris kernel: [ 26.207246] br-lan: port 3(lan3) entered blocking state
Mar 4 14:05:49 turris kernel: [ 26.212529] br-lan: port 3(lan3) entered forwarding state
Mar 4 14:05:49 turris kernel: [ 26.554953] br-lan: port 6(wlan1) entered disabled state
Mar 4 14:05:49 turris kernel: [ 27.475691] mvneta d0030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Mar 4 14:05:49 turris kernel: [ 27.491525] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mar 4 14:05:49 turris kernel: [ 27.526526] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.100: link becomes ready
Mar 4 14:05:49 turris kernel: [ 33.552489] pppoe-wan: renamed from ppp0
Mar 4 14:05:50 turris kernel: [ 36.510274] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Mar 4 14:05:50 turris kernel: [ 36.517168] br-lan: port 6(wlan1) entered blocking state
Mar 4 14:05:50 turris kernel: [ 36.522606] br-lan: port 6(wlan1) entered forwarding state
Mar 4 13:05:50 turris hostapd: wlan1: interface state HT_SCAN->ENABLED
Mar 4 13:05:50 turris hostapd: wlan1: AP-ENABLED
Mar 4 13:05:51 turris pppd[5106]: CHAP authentication succeeded: CHAP authentication success
Mar 4 13:05:51 turris pppd[5106]: peer from calling number 00:00:5E:00:01:0A authorized
Mar 4 13:05:51 turris netifd: Network device ‘wlan1’ link is up
Mar 4 13:05:51 turris pppd[5106]: local IP address 47.61.132.241
Mar 4 13:05:51 turris pppd[5106]: remote IP address 87.235.0.10
Mar 4 13:05:51 turris pppd[5106]: primary DNS address 212.166.132.117
Mar 4 13:05:51 turris pppd[5106]: secondary DNS address 212.166.132.104
Mar 4 13:05:51 turris netifd: Network device ‘pppoe-wan’ link is up
Mar 4 13:05:51 turris netifd: Interface ‘wan’ is now up
Mar 4 13:05:51 turris crond[5464]: (CRON) STARTUP (1.5.5)
Mar 4 13:05:51 turris crond[5464]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 73% if used.)
Mar 4 13:05:51 turris crond[5464]: (CRON) INFO (running with inotify support)
Mar 4 13:05:52 turris smartd[5542]: smartd 7.0 2018-12-30 r4883 [aarch64-linux-4.14.221] (localbuild)
Mar 4 13:05:52 turris smartd[5542]: Copyright © 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Mar 4 13:05:52 turris smartd[5542]: Opened configuration file /etc/smartd.conf
Mar 4 13:05:52 turris smartd[5542]: Configuration file /etc/smartd.conf parsed.
Mar 4 13:05:52 turris smartd[5542]: Device: /dev/hdb, open() failed: No such device
Mar 4 13:05:52 turris smartd[5542]: Device: /dev/hdb, not available
Mar 4 13:05:52 turris smartd[5542]: Monitoring 0 ATA/SATA, 0 SCSI/SAS and 0 NVMe devices
Mar 4 13:05:52 turris smartd[5564]: smartd has fork()ed into background mode. New PID=5564.
Mar 4 13:05:52 turris procd: /etc/rc.d/S96led: setting up led OFFRED
Mar 4 13:05:52 turris turris: Router Turris successfully started.
Mar 4 13:05:53 turris procd: /etc/rc.d/S99start-indicator: setting up led OFFRED
Mar 4 13:05:53 turris procd: - init complete -
Mar 4 13:05:58 turris kresd[6417]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Mar 4 13:05:58 turris kresd[6417]: [ta_update] refreshing TA for .
Mar 4 13:05:59 turris kresd[6417]: [ta_update] next refresh for . in 24 hours
Mar 4 13:05:59 turris hostapd: wlan1: STA e8:6f:38:ba:17:ff IEEE 802.11: associated
Mar 4 13:06:00 turris hostapd: wlan1: AP-STA-CONNECTED e8:6f:38:ba:17:ff
Mar 4 13:06:00 turris hostapd: wlan1: STA e8:6f:38:ba:17:ff RADIUS: starting accounting session 07B278912A2E612C
Mar 4 13:06:00 turris hostapd: wlan1: STA e8:6f:38:ba:17:ff WPA: pairwise key handshake completed (RSN)
Mar 4 13:06:07 turris firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Mar 4 13:06:08 turris kresd[6716]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Mar 4 13:06:08 turris kresd[6716]: [ta_update] refreshing TA for .
Mar 4 13:06:08 turris kresd[6716]: [ta_update] next refresh for . in 24 hours
Mar 4 13:06:21 turris pppd[5106]: IPV6CP: timeout sending Config-Requests
Mar 4 13:06:22 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f IEEE 802.11: authenticated
Mar 4 13:06:22 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f IEEE 802.11: associated (aid 3)
Mar 4 13:06:22 turris hostapd: wlan0: AP-STA-CONNECTED ea:d4:ed:e4:d5:9f
Mar 4 13:06:22 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f RADIUS: starting accounting session 200A97B5F63AB96D
Mar 4 13:06:22 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f WPA: pairwise key handshake completed (RSN)
Mar 4 13:06:58 turris updater[7473]: repository.lua.lua:50 (Globals): Target Turris OS: 5.1.9
Mar 4 13:06:59 turris hostapd: wlan0: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:06:59 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad IEEE 802.11: associated
Mar 4 13:06:59 turris hostapd: wlan1: AP-STA-CONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:06:59 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad RADIUS: starting accounting session B69E864391084CB5
Mar 4 13:06:59 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad WPA: pairwise key handshake completed (RSN)
Mar 4 13:08:09 turris hostapd: wlan1: interface state ENABLED->DISABLED
Mar 4 13:08:09 turris hostapd: wlan1: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:08:09 turris hostapd: wlan1: AP-STA-DISCONNECTED e8:6f:38:ba:17:ff
Mar 4 13:08:09 turris hostapd: wlan1: AP-DISABLED
Mar 4 13:08:09 turris hostapd: wlan1: CTRL-EVENT-TERMINATING
Mar 4 13:08:09 turris hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Mar 4 14:08:09 turris kernel: [ 175.064877] device wlan1 left promiscuous mode
Mar 4 14:08:09 turris kernel: [ 175.069756] br-lan: port 6(wlan1) entered disabled state
Mar 4 14:08:09 turris kernel: [ 175.125388] mwifiex_sdio mmc0:0001:1: EVENT: BT coex wlan param update
Mar 4 13:08:09 turris netifd: Network device ‘wlan1’ link is down
Mar 4 13:08:09 turris mac80211: Failed command: iw phy phy1 set antenna 0xffffffff 0xffffffff
Mar 4 14:08:09 turris kernel: [ 175.509008] mwifiex_sdio mmc0:0001:1: CMD_RESP: cmd 0x20 error, result=0x1
Mar 4 13:08:09 turris netifd: radio1 (7827): command failed: Not supported (-95)
Mar 4 13:08:09 turris mac80211: Failed command: iw phy phy1 set antenna_gain 0
Mar 4 13:08:10 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad IEEE 802.11: authenticated
Mar 4 13:08:10 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad IEEE 802.11: associated (aid 1)
Mar 4 13:08:10 turris hostapd: wlan0: AP-STA-CONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:08:10 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad RADIUS: starting accounting session 8A8DC4C8E2169A0E
Mar 4 13:08:10 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad WPA: pairwise key handshake completed (RSN)
Mar 4 13:08:10 turris hostapd: Configuration file: /var/run/hostapd-phy1.conf
Mar 4 14:08:10 turris kernel: [ 175.714552] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Mar 4 14:08:10 turris kernel: [ 175.723211] br-lan: port 6(wlan1) entered blocking state
Mar 4 14:08:10 turris kernel: [ 175.728598] br-lan: port 6(wlan1) entered disabled state
Mar 4 14:08:10 turris kernel: [ 175.734562] device wlan1 entered promiscuous mode
Mar 4 14:08:10 turris kernel: [ 175.739748] br-lan: port 6(wlan1) entered blocking state
Mar 4 14:08:10 turris kernel: [ 175.745193] br-lan: port 6(wlan1) entered forwarding state
Mar 4 13:08:10 turris hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Mar 4 13:08:10 turris hostapd: ACS: Automatic channel selection started, this may take a bit
Mar 4 13:08:10 turris hostapd: wlan1: interface state COUNTRY_UPDATE->ACS
Mar 4 13:08:10 turris hostapd: wlan1: ACS-STARTED
Mar 4 14:08:10 turris kernel: [ 176.146104] br-lan: port 6(wlan1) entered disabled state
Mar 4 13:08:17 turris hostapd: wlan1: ACS-COMPLETED freq=2462 channel=11
Mar 4 13:08:17 turris hostapd: Using interface wlan1 with hwaddr d0:c5:d3:34:0d:ab and ssid “Turris”
Mar 4 14:08:17 turris kernel: [ 183.324870] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Mar 4 14:08:17 turris kernel: [ 183.331615] br-lan: port 6(wlan1) entered blocking state
Mar 4 14:08:17 turris kernel: [ 183.337033] br-lan: port 6(wlan1) entered forwarding state
Mar 4 13:08:17 turris hostapd: wlan1: interface state ACS->ENABLED
Mar 4 13:08:17 turris hostapd: wlan1: AP-ENABLED
Mar 4 13:08:17 turris netifd: Network device ‘wlan1’ link is up
Mar 4 13:08:24 turris hostapd: wlan1: STA e8:6f:38:ba:17:ff IEEE 802.11: associated
Mar 4 13:08:25 turris hostapd: wlan1: AP-STA-CONNECTED e8:6f:38:ba:17:ff
Mar 4 13:08:25 turris hostapd: wlan1: STA e8:6f:38:ba:17:ff RADIUS: starting accounting session A218A5B54AD6BA77
Mar 4 13:08:25 turris hostapd: wlan1: STA e8:6f:38:ba:17:ff WPA: pairwise key handshake completed (RSN)
Mar 4 13:08:35 turris hostapd: wlan0: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:08:35 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad IEEE 802.11: associated
Mar 4 13:08:35 turris hostapd: wlan1: AP-STA-CONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:08:35 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad RADIUS: starting accounting session 1A609551F5CDDEB0
Mar 4 13:08:35 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad WPA: pairwise key handshake completed (RSN)
Mar 4 13:08:36 turris hostapd: wlan1: STA 00:00:00:00:00:00 IEEE 802.11: disassociated
Mar 4 13:09:14 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad IEEE 802.11: disassociated
Mar 4 13:09:14 turris hostapd: wlan1: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:09:14 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad IEEE 802.11: authenticated
Mar 4 13:09:14 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad IEEE 802.11: associated (aid 1)
Mar 4 13:09:14 turris hostapd: wlan0: AP-STA-CONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:09:14 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad RADIUS: starting accounting session 7ED3806478209C8F
Mar 4 13:09:14 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad WPA: pairwise key handshake completed (RSN)
Mar 4 13:09:23 turris hostapd: wlan0: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:10:01 turris crond[8249]: (root) CMD (/usr/bin/notifier)
Mar 4 13:10:02 turris crond[8248]: (root) CMDOUT (Working on message: 1614863235-7539)
Mar 4 13:10:02 turris crond[8248]: (root) CMDOUT (There is no message to send.)
Mar 4 13:10:53 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad IEEE 802.11: associated
Mar 4 13:10:53 turris hostapd: wlan1: AP-STA-CONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:10:53 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad RADIUS: starting accounting session B6A345693663018A
Mar 4 13:10:53 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad WPA: pairwise key handshake completed (RSN)
Mar 4 13:12:01 turris crond[8389]: (root) CMD (/usr/sbin/logrotate -s /tmp/logrotate.state /etc/logrotate.conf)
Mar 4 13:15:01 turris crond[8559]: (root) CMD (/usr/bin/notifier)
Mar 4 13:15:01 turris crond[8558]: (root) CMDOUT (Working on message: 1614863235-7539)
Mar 4 13:15:01 turris crond[8558]: (root) CMDOUT (There is no message to send.)
Mar 4 13:17:28 turris hostapd: wlan0: AP-STA-DISCONNECTED ea:d4:ed:e4:d5:9f
Mar 4 13:17:34 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f IEEE 802.11: authenticated
Mar 4 13:17:34 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f IEEE 802.11: associated (aid 1)
Mar 4 13:17:34 turris hostapd: wlan0: AP-STA-CONNECTED ea:d4:ed:e4:d5:9f
Mar 4 13:17:34 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f RADIUS: starting accounting session E91D39E3E5407A0A
Mar 4 13:17:34 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f WPA: pairwise key handshake completed (RSN)
Mar 4 13:20:01 turris crond[8993]: (root) CMD (/usr/bin/notifier)
Mar 4 13:20:01 turris crond[8992]: (root) CMDOUT (Working on message: 1614863235-7539)
Mar 4 13:20:01 turris crond[8992]: (root) CMDOUT (There is no message to send.)
Mar 4 13:25:01 turris crond[9317]: (root) CMD (/usr/bin/notifier)
Mar 4 13:25:01 turris crond[9316]: (root) CMDOUT (Working on message: 1614863235-7539)
Mar 4 13:25:01 turris crond[9316]: (root) CMDOUT (There is no message to send.)
Mar 4 13:28:46 turris hostapd: wlan0: AP-STA-DISCONNECTED ea:d4:ed:e4:d5:9f
Mar 4 13:28:50 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f IEEE 802.11: authenticated
Mar 4 13:28:50 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f IEEE 802.11: associated (aid 1)
Mar 4 13:28:50 turris hostapd: wlan0: AP-STA-CONNECTED ea:d4:ed:e4:d5:9f
Mar 4 13:28:50 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f RADIUS: starting accounting session 147BA042ABB18BB2
Mar 4 13:28:50 turris hostapd: wlan0: STA ea:d4:ed:e4:d5:9f WPA: pairwise key handshake completed (RSN)
Mar 4 13:30:01 turris crond[9948]: (root) CMD (/usr/bin/notifier)
Mar 4 13:30:01 turris crond[9949]: (root) CMD (/usr/bin/get-api-crl)
Mar 4 13:30:01 turris crond[9947]: (root) CMDOUT ( % Total % Received % Xferd Average Speed Time Time Time Current)
Mar 4 13:30:01 turris crond[9947]: (root) CMDOUT ( Dload Upload Total Spent Left Speed)
Mar 4 13:30:01 turris crond[9946]: (root) CMDOUT (There is no message to send.)
Mar 4 13:30:01 turris crond[9947]: (root) CMDOUT ( 0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0 0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0100 1080 100 1080 0 0 2762 0 --:–:-- --:–:-- --:–:-- 3068)
Mar 4 13:31:31 turris hostapd: wlan1: STA 7c:d6:61:f0:0e:ad IEEE 802.11: disassociated
Mar 4 13:31:31 turris hostapd: wlan1: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:31:32 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad IEEE 802.11: authenticated
Mar 4 13:31:32 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad IEEE 802.11: associated (aid 3)
Mar 4 13:31:32 turris hostapd: wlan0: AP-STA-CONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:31:32 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad RADIUS: starting accounting session 14E90D2FE705BFE0
Mar 4 13:31:32 turris hostapd: wlan0: STA 7c:d6:61:f0:0e:ad WPA: pairwise key handshake completed (RSN)
Mar 4 13:35:01 turris crond[11057]: (root) CMD (/usr/bin/notifier)
Mar 4 13:35:01 turris crond[11056]: (root) CMDOUT (There is no message to send.)
Mar 4 13:39:14 turris hostapd: wlan0: AP-STA-DISCONNECTED 7c:d6:61:f0:0e:ad
Mar 4 13:40:01 turris crond[12203]: (root) CMD (/usr/bin/notifier)
Mar 4 13:40:02 turris crond[12202]: (root) CMDOUT (There is no message to send.)
In Forris there is a basic connection test. It shows OK ipV4 and NOT OK ipv6.
Edit: Wifi is back, I disconnected dlna, and several reboot later it worked. I still don’t know what’s wrong. Ipv4/6 stills shows the same.
DHCP is now filled with machines (normal), it was blank before.
