I have got connected OpenWrt device on my turris_vpn.
I need to add static routes towards this VPN host for networks which are behind this tunnel.
Host in the tunnel has static address 192.168.100.18
Which is reachable from the router / also from the local network.
But route towards networks 192.168.6.0/24 ,192.168.5.0/24, 192.168.7.0/24 is going by default to the provider, not towards the tunnel.
This is my static routes config.
/etc/config/network
config route
option target ‘192.168.6.0’
option gateway ‘192.168.100.18’
option interface ‘vpn_turris’
config route
option target ‘192.168.5.0’
config route
option target ‘192.168.7.0’
But it is missing in routing table:
root@Turris:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 10.152.220.1 0.0.0.0 UG 0 0 0 eth1
10.152.220.0 * 255.255.255.0 U 0 0 0 eth1
10.152.220.1 * 255.255.255.255 UH 0 0 0 eth1
192.168.10.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.100.0 192.168.100.2 255.255.255.0 UG 0 0 0 tun_turris
192.168.100.2 * 255.255.255.255 UH 0 0 0 tun_turris
Routing table and ifconfig from remote host
tun_turris Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:192.168.100.18 P-t-P:192.168.100.17 Mask:255.255.255.255
inet6 addr: fe80::9530:ef29:f7c6:92f0/64 Scope:Link
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
RX packets:3979 errors:0 dropped:0 overruns:0 frame:0
TX packets:4707 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:364420 (355.8 KiB) TX bytes:929326 (907.5 KiB)
default 192.168.6.66 0.0.0.0 UG 0 0 0 br-lan
192.168.6.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.10.0 192.168.100.17 255.255.255.0 UG 0 0 0 tun_turris
192.168.100.1 192.168.100.17 255.255.255.255 UGH 0 0 0 tun_turris
192.168.100.17 * 255.255.255.255 UH 0 0 0 tun_turris
What should be wrong?
