Ssh configuration not fully baked?
Hi there,
I have been trying to setup an omnia without much success: the router eventually installed and updated itself after a couple of factory resets but I see nothing listening on port 22 despite configuring the “avanced” root password. I tried to run a couple of custom commands to debug this:
/usr/sbin/sshd -d
/etc/ssh/sshd_config: No such file or directory
ls -al /etc/ssh
drwx------ 1 root root 344 Aug 21 16:19 .
drwxr-xr-x 1 root root 1760 Aug 21 16:07 …
-rw-r–r-- 1 root root 553185 Aug 14 19:22 moduli
-rw------- 1 root root 1553 Aug 14 19:22 ssh_config
-rw------- 1 root root 668 Aug 21 16:19 ssh_host_dsa_key
-rw-r–r-- 1 root root 601 Aug 21 16:19 ssh_host_dsa_key.pub
-rw------- 1 root root 227 Aug 21 16:18 ssh_host_ecdsa_key
-rw-r–r-- 1 root root 173 Aug 21 16:18 ssh_host_ecdsa_key.pub
-rw------- 1 root root 399 Aug 21 15:40 ssh_host_ed25519_key
-rw-r–r-- 1 root root 93 Aug 21 15:40 ssh_host_ed25519_key.pub
-rw------- 1 root root 1675 Aug 21 16:17 ssh_host_rsa_key
-rw-r–r-- 1 root root 393 Aug 21 16:17 ssh_host_rsa_key.pub
How come that configuration file was not installed ? Is there a way to force it to be installed ?
Any help would be most welcome :slight_smile:
Why do you think that command is a good way to run the ssh server? It has standard init scripts, etc.
There’s clickable table in <address>/cgi-bin/luci/admin/system/startup
because it does not work and I have been trying to find out why:
/etc/init.d/sshd start
Command failed (Code: 256)
and because, obviously, if you do not have an sshd_config file, nothing sane will make sshd start
I see that there is an sshd process running: /usr/sbin/sshd -f /var/etc/ssh/sshd_config
and the /var/etc/ssh/sshd_config file contains this:
cat “/var/etc/ssh/sshd_config”
auto-generated config file from /etc/config/sshd
PermitRootLogin yes
AuthorizedKeysFile .ssh/authorized_keys
Subsystem sftp /usr/lib/sftp-server
and that sshd is indeed listening on port 22:
sshd 19696 root 3u IPv4 41571 0t0 TCP *:ssh (LISTEN)
sshd 19696 root 4u IPv6 41573 0t0 TCP *:ssh (LISTEN)
I guess the firewall does not open port 22 by default ?
I didn’t touch ssh config IIRC, I don’t have that file and it just works (I checked all that over ssh).
If you did factory reset. You should set the system password first [ guide: https://doc.turris.cz/doc/en/howto/ssh ] [ foris: http://192.168.1.1/foris/config/main/system-password/ ] . After that you should be able to use ssh(as root) from local network.
Bwaaah :confused:
This was caused by my local ssh_config file which was setup to forward all ssh connections through an external ssh gateway which obviously had no business accessing 192.168.1.1
Dumb me.
thank you for your help
