Ahoj,
porad mam problemy se spoustou socat procesu. Na Tmobile DSL se dost casto vyzerou vsechna spojeni, pak padne resolve na DNS a pak jde cely net do kytek. Zasek na 1-5 minut pri online hrani, kdy si nepingnete nic.
Viz:
Situace po 2 tydnech asi takovahle:
17509 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
18453 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
19271 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
21309 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
21335 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
21518 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
23188 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
25065 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
25072 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
28405 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
28490 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
28742 root 1108 S grep socat
29629 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
29741 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
31754 root 2844 S socat STDIO OPENSSL:api.turris.cz:5679,cafile=/etc/ssl/ucollect-server.pem,cipher=HIGH:!LOW:!MEDIUM:!SSLv2:!aNULL:!eNULL:!DES:!3DES:!AES128:!CAMELLIA128,method
root@turris:~# uptime
15:40:29 up 21 days, 18:02, load average: 0.00, 0.01, 0.00
Nejake tipy co s tim?
