The updater hangs and will not continue. Rolling back to two days ago results in the same “error”. This is the latest output:
/etc/init.d/lighttpd restart
Output from foris-diagnostics-plugin-l10n-de.postinst:
[ -n ]
Output from luci-i18n-base-en.postinst:
/usr/lib/opkg/info//luci-i18n-base-en.postinst: .: line 4: can’t open ‘/etc/uci-defaults/luci-i18n-base-en’
Output from luci-i18n-commands-en.postinst:
/usr/lib/opkg/info//luci-i18n-commands-en.postinst: .: line 4: can’t open ‘/etc/uci-defaults/luci-i18n-commands-en’
Output from luci-i18n-base-de.postinst:
/usr/lib/opkg/info//luci-i18n-base-de.postinst: .: line 4: can’t open ‘/etc/uci-defaults/luci-i18n-base-de’
Output from luci-i18n-commands-de.postinst:
/usr/lib/opkg/info//luci-i18n-commands-de.postinst: .: line 4: can’t open ‘/etc/uci-defaults/luci-i18n-commands-de’
Output from foris-controller-openvpn-module.postinst:
[ -n ]
/etc/init.d/foris-controller restart
Output from foris-openvpn-plugin.postinst:
[ -n ]
/etc/init.d/openvpn enable
Output from foris-openvpn-plugin-l10n-de.postinst:
[ -n ]
Is there a more detailed log which shows what exactly is failing?
EDIT:
Rolled back again, removed l10n de, but updater hangs again:
Output from foris-wizard.postinst:
[ -n ]
Output from foris-diagnostics-plugin.postinst:
[ -n ]
[ -n ]
My updater is hanging but ddns was already disabled. Any tipps on what might be blocking the updater from succeeding, or how to find out which process is blocking it?
The error message that appears sometimes is:
Updater selhal:
[string “backend”]:1194: [string “backend”]:1185: Failed to lock the lock file //var/lock/opkg.lock: Resource temporarily unavailable
Next try: I did a factory reset with the built-in factory snapshot (press the reset buttin until 3 LEDs are lit)
Update to latest turrisOS runs through without any apparent errors.
but as soon as I add modules in FORIS->Updater it hangs again.
see schnapps list:
123 | rollback | 2019-05-20 14:53:41 +0000 | Rollback to snapshot factory
124 | pre | 2019-05-20 16:59:55 +0200 | Automatic pre-update snapshot
125 | post | 2019-05-20 17:06:54 +0200 | Automatic post-update snapshot
126 | pre | 2019-05-20 17:11:15 +0200 | Automatic pre-update snapshot
We also did a reset yesterday. Not sure if it was a factory reset or medkit though…
Afterwards we uploaded our configuration backup again.
Then we logged into SSH and started the updater.sh to have it updated to the latest version.
When it finished we restarted and the automatic updater works fine since then. Dunno what the problem actually was in the end…
After updater.sh finishes, just don’t use it anymore. It’s deprecated… You can use opkg update to trigger manual updates in newer versions.
So after being fed up with the turris a took a day today and dragged myself to install the HBT-medkit via USB Flash reset mode 4.
For Whatever Reason I ended up with a version 4.something istead of 5 (HBT!)
And guess what: After the first round of Updates while installing all the packeges once again the updater ceased working.
I didn’t recognise it at first, trying to recreate my lx containers, which dind not work at all, It came to my mind that DNS is not working. And this apparently and understandably breaks everything.
As you can imagine I tried once again fixing DNS, shuffleing through all the options in FORIS and LuCI, but it was simply not possible.
So after once again spending too many hours with the turris I am finally finished. Now my devices can’t even connect to the internet anymore.
I’ll get a proprietary router ASAP and ditch the turris.
Let’s try it slightly differently this time alright? Download HBS medkit, flash it to your router and you will see there is working DNS. There is still a way to download HBT medkit, but before you proceed through Updater tab, you need to use switch-branch hbt or whatever medkit you download.
Sorry for being so unfriendly. Apparently the latest HBT TurrisOS works as expected for my setup. It appeared magically on my half working Omnia via Auto Update.
