Solved: System log returns error 500
Ever since I started using the Omnia, I have gotten this error whenever I attempt to access the system log in LuCI:
500 Internal Server Error</h2>
<p>Sorry, the server encountered an unexpected error.</p>
<pre class="error500">/usr/lib/lua/luci/dispatcher.lua:460: Failed to execute call dispatcher target for entry '/admin/status/syslog'.
The called action terminated with an exception:
/usr/lib/lua/luci/template.lua:97: Failed to execute template 'admin_status/syslog'.
A runtime error occured: [string "/usr/lib/lua/luci/view/admin_status/syslog...."]:1: attempt to index global 'syslog' (a nil value)
stack traceback:
	[C]: in function 'assert'
	/usr/lib/lua/luci/dispatcher.lua:460: in function 'dispatch'
	/usr/lib/lua/luci/dispatcher.lua:141: in function </usr/lib/lua/luci/dispatcher.lua:140></pre>
   <footer>
<a href="https://github.com/openwrt/luci">Powered by LuCI 3200f7dc985b1ac048a62a96ffae783b3c285448 branch (git-16.212.24666-3200f7d)</a> / OpenWrt omnia 15.05 r49274
   </footer>
   </div>
  </div>
 </body>
</html>
I do have updates turned on, and they appear to be updating as they should.
Any pointers to what might be wrong, and what I can do to resolve it?
Best regards
fsteff
Hello
The reason is that you propably enabled and then disabled Turris Project data collection.
On disabling Turris removes some packages and then removes one important directory.
Just login on ssh or open LuCI command window and type two commands:
mkdir /etc/syslog-ng.d
/etc/init.d/syslog-ng restart
Thank you Cabal,
You were absolutely spot on with your diagnosis and fix.
Again, Thanks!
It is not mine diagnosis.
I found it here and applied to mine Omnia just before your question:)
