[SOLVED] Store snapshots outside Omnia
Is there any option, to store snapshot outside Omnia to external medium? AFAIK, through reset button we could restore last snapshot from schnapps, I would like to store different snapshots for that purpose (to have option somehow import it to the schnapps moths/year later, and restore it as last snapshot).
Unfortunatelly, I didnt store Turris OS 3.5.3 full medkit. Its seems to be avaible here: https://repo.turris.cz/archive/omnia/3.5.3/medkit/omnia-medkit-latest-full.tar.gz
Snapshots are essentially filesystems stored at some point. So to store it you can mount it, tar content and than even use it as medkit. Because medkit is just tar of Turris OS filesystem in the end. I haven’t tested this, but it should work.
Thanks for reply. If anyone interested:
# schnapps list
    # | Type      | Date                      | Description
    1 | single    | 2017-02-24 14:06:05 +0100 | User created snapshot
    2 | single    | 2017-03-09 19:49:52 +0100 | 3.5.2
    3 | pre       | 2017-03-09 19:53:40 +0100 | Automatic pre-update snapshot
    4 | pre       | 2017-03-11 09:21:03 +0100 | Automatic pre-update snapshot
# btrfs subvolume list /
ID 256 gen 1289 top level 5 path @
ID 258 gen 8 top level 5 path @factory
ID 265 gen 1016 top level 5 path @1
ID 267 gen 1115 top level 5 path certbackup
ID 269 gen 1198 top level 5 path @2
ID 270 gen 1198 top level 5 path @3
ID 271 gen 1222 top level 5 path @4
mount -t btrfs -o subvolid=270 /dev/mmcblk0p1 /mnt/backup
I am also happy to find out this option
schnapps rollback [number]
Make snapshot corresponding to the number default for next boot. If called without any argument, go one step back. Numbers can be found via list command
