[SOLVED] Memory consumption
is this memory consumption normal? In list of processes, I see no process with relevant memory consumption.
Thanks,
Pavel
With SSH connection you can see more detailed statistics from /proc/meminfo virtual file: less /proc/meminfo
If there is high usage in “Cached” then it is normal.
Yeahh, 1.2 GB cached.
------- :electric_plug: Search results for '' - Turris forum
well i started using majordomo, storing on my synology NAS, so thats probably the reason of bigger cache now. Good to know.
Mounted Samba share from Synology or somekind of another way?
I use this command
mount.cifs //192.168.2.10/majordomo_db /mnt/majordomo_db -o user=majordomo,password=user_12
on Synology I have user “majordomo” and simple shared folder in root. Simple.
