Hi!
I have a Turris Omnia v3.6.1 as Internet Router for my Wilhelm.Tel FTTH access. The IPv4 Uplink is working fine with PPPoE but the IPv6 Uplink ceases working after 30 minutes.
What I have found so far is that the default route is deleted from the kernel 30 Minutes after the setting of the route:
# ip -ts -6 monitor label 1>>/var/log/ip-monitor.log &
# grep default.*via /var/log/ip-monitor.log
[2017-04-02T12:57:35.639232] [ROUTE]Deleted default from 2a02:2028:51b:2b00::/56 via fe80::aa9d:21ff:fee1:7f00 dev pppoe-wan proto static metric 512
[2017-04-02T13:14:13.247896] [ROUTE]default via 84.46.104.215 dev ppp0 proto static
[2017-04-02T13:14:17.395220] [ROUTE]default from 2a02:2028:548:e100::/56 via fe80::aa9d:21ff:fee1:7f00 dev ppp0 proto static metric 512
[2017-04-02T13:44:18.388291] [ROUTE]Deleted default from 2a02:2028:548:e100::/56 via fe80::aa9d:21ff:fee1:7f00 dev ppp0 proto static metric 512
[2017-04-02T14:13:03.349801] [ROUTE]default via 84.46.104.215 dev ppp0 proto static
[2017-04-02T14:13:06.761349] [ROUTE]default from 2a02:2028:548:e100::/56 via fe80::aa9d:21ff:fee1:7f00 dev ppp0 proto static metric 4096
[2017-04-02T14:13:07.394041] [ROUTE]default from 2a02:2028:548:e100::/56 via fe80::aa9d:21ff:fee1:7f00 dev ppp0 proto static metric 512
[2017-04-02T14:13:07.394210] [ROUTE]Deleted default from 2a02:2028:548:e100::/56 via fe80::aa9d:21ff:fee1:7f00 dev ppp0 proto static metric 4096
[2017-04-02T14:43:08.895168] [ROUTE]Deleted default from 2a02:2028:548:e100::/56 via fe80::aa9d:21ff:fee1:7f00 dev ppp0 proto static metric 512
In the system logs is nothing relevant to find
2017-04-02T12:42:23+02:00 warning odhcpd[2155]: DHCPV6 RELEASE IA_NA from 000100011d9062ad0862664ce61d on br-lan: ok 2a02:2028:548:e100::22a/128 fd9c:9819:4c58::22a/128
2017-04-02T12:42:55+02:00 warning odhcpd[2155]: DHCPV6 CONFIRM IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: not on-link 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T12:42:55+02:00 warning odhcpd[2155]: DHCPV6 SOLICIT IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: ok 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T12:42:56+02:00 warning odhcpd[2155]: DHCPV6 REQUEST IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: ok 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T12:43:01+02:00 info /usr/sbin/cron[31546]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2017-04-02T12:43:02+02:00 warning odhcpd[2155]: DHCPV6 CONFIRM IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: not on-link 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T14:43:09+02:00 warning odhcpd[]: Last message 'DHCPV6 CONFIRM IA_NA' repeated 1 times, supressed by syslog-ng on turris
2017-04-02T12:43:09+02:00 warning odhcpd[2155]: DHCPV6 SOLICIT IA_NA from 000100011f5b4bd92c56dcd48687 on br-lan: ok 2a02:2028:548:e100::1c0/128 fd9c:9819:4c58::1c0/128
2017-04-02T12:43:09+02:00 warning odhcpd[2155]: DHCPV6 SOLICIT IA_NA from 000100011d9062ad0862664ce61d on br-lan: ok 2a02:2028:548:e100::22a/128 fd9c:9819:4c58::22a/128
2017-04-02T12:43:10+02:00 warning odhcpd[2155]: DHCPV6 CONFIRM IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: not on-link 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T12:43:10+02:00 warning odhcpd[2155]: DHCPV6 SOLICIT IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: ok 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T14:43:10+02:00 debug kernel[]: [1003207.672984] ucollect-fake-open-inet: IN=pppoe-wan OUT= MAC= SRC=178.17.20.123 DST=84.46.35.158 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=382 DF PROTO=TCP SPT=28126 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x80000
2017-04-02T12:43:10+02:00 warning odhcpd[2155]: DHCPV6 REQUEST IA_NA from 000100011f5b4bd92c56dcd48687 on br-lan: ok 2a02:2028:548:e100::1c0/128 fd9c:9819:4c58::1c0/128
2017-04-02T12:43:10+02:00 warning odhcpd[2155]: DHCPV6 REQUEST IA_NA from 000100011d9062ad0862664ce61d on br-lan: ok 2a02:2028:548:e100::22a/128 fd9c:9819:4c58::22a/128
2017-04-02T12:43:11+02:00 warning odhcpd[2155]: DHCPV6 REQUEST IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: ok 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T14:43:13+02:00 debug kernel[]: [1003210.647454] ucollect-fake-open-inet: IN=pppoe-wan OUT= MAC= SRC=178.17.20.123 DST=84.46.35.158 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=401 DF PROTO=TCP SPT=28126 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x80000
2017-04-02T12:43:13+02:00 warning odhcpd[2155]: DHCPV6 RELEASE IA_NA from 000100011f5b4bd92c56dcd48687 on br-lan: ok 2a02:2028:548:e100::1c0/128 fd9c:9819:4c58::1c0/128
2017-04-02T12:43:13+02:00 warning odhcpd[2155]: DHCPV6 RELEASE IA_NA from 000100011d9062ad0862664ce61d on br-lan: ok 2a02:2028:548:e100::22a/128 fd9c:9819:4c58::22a/128
2017-04-02T14:43:19+02:00 debug kernel[]: [1003216.640397] ucollect-fake-open-inet: IN=pppoe-wan OUT= MAC= SRC=178.17.20.123 DST=84.46.35.158 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=422 DF PROTO=TCP SPT=28126 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x80000
2017-04-02T12:43:21+02:00 warning odhcpd[2155]: DHCPV6 CONFIRM IA_NA from 0004adfc3d22ee1f41b9403852c12de6e668 on br-lan: not on-link 2a02:2028:548:e100::960/128 fd9c:9819:4c58::960/128
2017-04-02T14:43:30+02:00 debug kernel[]: [1003227.966379] ucollect-fake-open-inet: IN=pppoe-wan OUT= MAC= SRC=185.98.90.221 DST=84.46.35.158 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=8078 DF PROTO=TCP SPT=53550 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x80000
2017-04-02T14:43:33+02:00 debug kernel[]: [1003230.505889] ucollect-fake-open-inet: IN=pppoe-wan OUT= MAC= SRC=185.98.90.221 DST=84.46.35.158 LEN=52 TOS=0x00 PREC=0x00 TTL=114 ID=8103 DF PROTO=TCP SPT=53550 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x80000
2017-04-02T14:43:39+02:00 debug kernel[]: [1003236.500594] ucollect-fake-open-inet: IN=pppoe-wan OUT= MAC= SRC=185.98.90.221 DST=84.46.35.158 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=8108 DF PROTO=TCP SPT=53550 DPT=80 WINDOW=8192 RES=0x00 SYN URGP=0 MARK=0x80000
The network config for wan6 looks like this:
network.wan6=interface
network.wan6.ifname='@wan'
network.wan6.proto='dhcpv6'
network.wan6.reqprefix='auto'
network.wan6.reqaddress='try'
EDIT: My provider send exactly one Router Advertisement with a validity time of 30 Min (1800 sec)
root@turris:/lib/netifd/proto# tcpdump -i pppoe-wan -n -vvvv -ttt icmp6 and 'ip6[40] = 134'
tcpdump: listening on pppoe-wan, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
00:00:00.000000 IP6 (class 0xe0, hlim 255, next-header ICMPv6 (58) payload length: 24) fe80::aa9d:21ff:fee1:7f00 > fe80::d:eaec:5225:3ca4: [icmp6 sum ok] ICMP6, router advertisement, length 24
hop limit 64, Flags [managed, other stateful], pref medium, router lifetime 1800s, reachable time 0s, retrans time 0s
mtu option (5), length 8 (1): 1492
0x0000: 0000 0000 05d4
This will propagated with the /lib/netifd/dhcpv6.script
to ubus
which removes the route as soon as the validity time is up.
root@turris:~# ifstatus wan6
"up": true,
"route": [
"target": "::",
"mask": 0,
"nexthop": "fe80::aa9d:21ff:fee1:7f00",
"metric": 512,
"valid": 118,
"source": "2a02:2028:541:3200::\/56"
Workaround: I have now added a /etc/odhcp6c.user
which gets called after from /lib/netifd/dhcpv6.script
on an update event. There I set the routes without any validity time checks…
# /etc/odhcp6c.user
logger -t odhcp6c.user INterface $1 State $2
# log env
env | logger -t odhcp6c.user
routing () {
if [ "$2" = "bound" ] ; then
for entry in $RA_ROUTES; do
local duplicate=0
local addr="${entry%%/*}"
entry="${entry#*/}"
local mask="${entry%%,*}"
entry="${entry#*,}"
local gw="${entry%%,*}"
entry="${entry#*,}"
local valid="${entry%%,*}"
entry="${entry#*,}"
local metric="${entry%%,*}"
for xentry in $RA_ROUTES; do
local xprefix="${xentry%%,*}"
xentry="${xentry#*,}"
local xgw="${xentry%%,*}"
[ -n "$gw" -a -z "$xgw" -a "$addr/$mask" = "$xprefix" ] && duplicate=1
done
if [ -z "$gw" -o "$duplicate" = 1 ]; then
# proto_add_ipv6_route "$addr" "$mask" "$gw" "$metric" "$valid" "$paddr"
logger -t odhcp6c.user setting route 1: ip route add "$addr"/"$mask" via "$gw" dev $1 metric "1$metric"
else
for prefix in $PREFIXES $ADDRESSES; do
local paddr="${prefix%%,*}"
logger -t odhcp6c.user setting route 2: ip route add "$addr"/"$mask" via "$gw" dev $1 metric "2$metric" from "$paddr"
done
fi
done
fi
routing $1 $2
I am not sure if my provider is wrong here of if the Turiss firmware has a bug here, but with the workaround I get IPv6 connectivity for more the 30 min
cheerio
Steve
