Since the update of TOS from 5 to 6 I’m trying to run lighthttpd on port 81 and https on port 4443 as I have a nginx running at ports 80 & 443.
The method I used and described here Turris as a webserver [Turris wiki] doesn’t work anymore. The lighthttpd.conf still contains
server.port = 81
$SERVER[“socket”] == “[::]:81” { }
I also tried changing 90-turris-root.conf and set socket to 81. I even tried modifying /etc/init.d/lighthttpd and change the mdns entries there but still without success.
The only way atm to access turris/luci is to stop nginx and start lighthttpd and when finished do the reverse actions as I need nginx to access my internal hosts like xxxx.shadowsrealm.ch
Any ideas on how to set lighthttpd ports in TOS 6?
