Socks5 settings
Can i setup a socks5 on Turris is that plausible?
I would like to use NordVPN Socks5 settings
but shadow socks doesn’t have username and password field
On standard OpenWrt there’s an srelay package. Running opkg find srelay returns no hits, unfortunately.
thats what i thought, how would i be able to do it, my issue is Virgin media (UK isp) cap port 443 at 40mbps even if you pay for fibre, and i thought socks5 would help with that or i can use untangle to jump ports.
Thanks for the quick reply by the way
