SFP Use with another hardware
Hello Everyone,
Is this possible to use the sfp port to make a connection with another router or switch for example Cisco hardware ?
thx
Yes it is possible but will still disable the ethernet port. If this connection is not your WAN or upstream port then this will require changes to the configuration using LuCI or the config files but this is possible.
