I upgraded my Turris Omnia to TurrisOS 5.1.4 from 3.11.x yesterday. Honestly, a poor experience I must say. Most of the services are broken after upgrade. Anyway… Netmeter does not work anymore.
Here is debug run:
root@Turris:~# netmetr --debug
Checking uuid on the control server...
Sending the following request to https://control.netmetr.cz/RMBTControlServer/settings?skip_history=true
"uuid": "b22789a9-8aa5-40aa-b09a-3e0f60ec05df",
"language": "en_US",
"name": "RMBT",
"terms_and_conditions_accepted": "true",
"type": "DESKTOP",
"version_name": "Python netmetr client v1.6.0"
response:
"settings": [
"urls": {
"url_ipv6_check": "https://ipv6.control.netmetr.cz/RMBTControlServer/ip",
"control_ipv4_only": "ipv4.control.netmetr.cz",
"url_ipv4_check": "https://ipv4.control.netmetr.cz/RMBTControlServer/ip",
"control_ipv6_only": "ipv6.control.netmetr.cz",
"statistics": "https://www.netmetr.cz/en/stats_app.html"
"qostesttype_desc": [
"name": "DNS",
"test_type": "DNS"
"name": "Non Transparent Proxy",
"test_type": "NON_TRANSPARENT_PROXY"
"name": "HTTP Proxy",
"test_type": "HTTP_PROXY"
"name": "Website",
"test_type": "WEBSITE"
"name": "UDP",
"test_type": "UDP"
"name": "TCP",
"test_type": "TCP"
"name": "JITTER",
"test_type": "JITTER"
"versions": {
"control_server_version": "master_2.0.83-CZ_0.9.28-324-g4c7caa7"
Requesting test config from the control server...
Sending the following request to https://control.netmetr.cz/RMBTControlServer/testRequest
"client": "HW-PROBE",
"time": 1605802583000,
"timezone": "CET",
"type": "DESKTOP",
"version": "0.1"
response:
"user_server_selection": false,
"test_server_address": "ipv4.speed.netmetr.cz",
"test_server_port": 8081,
"test_server_name": "CZ.NIC (Prague)",
"test_server_encryption": false,
"test_server_type": "RMBT",
"test_duration": "5",
"test_numthreads": "3",
"test_numpings": "10",
"client_remote_ip": "151.237.228.177",
"result_url": "https://control.netmetr.cz/RMBTControlServer/result",
"result_qos_url": "https://control.netmetr.cz/RMBTControlServer/resultQoS",
"test_token": "30172177-0a5c-45c7-b38a-06ca163228e4_1605802583_g1nFIFwUCgVJkfdNzUgdOzKzS6s=",
"test_uuid": "30172177-0a5c-45c7-b38a-06ca163228e4",
"test_id": 9657314,
"test_wait": 0,
"error": []
Starting ping test...
ping_1_msec = 4.56
ping_2_msec = 4.65
ping_3_msec = 4.62
ping_4_msec = 4.65
ping_5_msec = 4.74
ping_6_msec = 4.55
ping_7_msec = 4.54
ping_8_msec = 4.55
ping_9_msec = 4.66
ping_10_msec = 4.64
Starting speed test...
==== rmbt 3f5c59bb2 ====
connecting...
connected with 3 flow(s) for dl; 3 flow(s) for ul
pretest downlink start... (min 1s)
pretest downlink end.
rtt_tcp_payload start... (11 times)
rtt_tcp_payload end.
downlink test start... (5s)
downlink test end.
pretest uplink start... (min 1s)
pretest uplink end.
uplink test start... (5s)
uplink test end.
disconnecting.
dl_throughput_mbps = 94.026179
ul_throughput_mbps = 93.972824
Exiting.
Speed test result:
"cnf_file_flows":"\/tmp\/tmpxk2l6u2i.xz"
"res_id_test":"30172177-0a5c-45c7-b38a-06ca163228e4",
"res_time_start_s":1605802588,
"res_time_end_s":1605802602,
"res_status":"success",
"res_status_msg":null,
"res_version_client":"3f5c59bb2",
"res_version_server":"RMBTv0.3",
"res_server_ip":"217.31.202.97",
"res_server_port":8081,
"res_encrypt":false,
"res_chunksize":4096,
"res_tcp_congestion":"cubic",
"res_total_bytes_dl":68950369,
"res_total_bytes_ul":70050986,
"res_uname_sysname":"Linux",
"res_uname_nodename":"Turris",
"res_uname_release":"4.14.206",
"res_uname_version":"#0 SMP Fri Nov 13 04:11:07 2020",
"res_uname_machine":"armv7l",
"res_rtt_tcp_payload_num":11,
"res_rtt_tcp_payload_client_ns":4636020,
"res_rtt_tcp_payload_server_ns":4633290,
"res_dl_num_flows":3,
"res_dl_time_ns":5095847624,
"res_dl_bytes":59892885,
"res_dl_throughput_kbps":94026.178833011363,
"res_ul_num_flows":3,
"res_ul_time_ns":5065645875,
"res_ul_bytes":59504131,
"res_ul_throughput_kbps":93972.82394912772
Sending the following request to https://control.netmetr.cz/RMBTControlServer/result
(speed detail omitted)
"client_language": "en_US",
"client_name": "HW-PROBE",
"client_version": "0.1",
"client_software_version": "Python netmetr client v1.6.0",
"geoLocations": [],
"model": "Turris Omnia",
"network_type": 98,
"product": "os: 5.1.4 hw: cznic,turris-omnia",
"test_bytes_download": 68950369,
"test_bytes_upload": 70050986,
"test_nsec_download": 5095847624,
"test_nsec_upload": 5065645875,
"test_num_threads": 3,
"test_ping_shortest": 4540000,
"num_threads_ul": 3,
"test_speed_download": 94026.17883301136,
"test_speed_upload": 93972.82394912772,
"pings": []
File "/usr/bin/netmetr", line 11, in <module>
load_entry_point('netmetr==1.6.0', 'console_scripts', 'netmetr')()
File "/usr/lib/python3.7/site-packages/netmetr/__main__.py", line 656, in main
File "/usr/lib/python3.7/site-packages/netmetr/__main__.py", line 362, in upload_result
File "/usr/lib/python3.7/site-packages/netmetr/__main__.py", line 102, in send_request
File "/usr/lib/python3.7/urllib/request.py", line 222, in urlopen
File "/usr/lib/python3.7/urllib/request.py", line 531, in open
File "/usr/lib/python3.7/urllib/request.py", line 641, in http_response
File "/usr/lib/python3.7/urllib/request.py", line 569, in error
File "/usr/lib/python3.7/urllib/request.py", line 503, in _call_chain
File "/usr/lib/python3.7/urllib/request.py", line 649, in http_error_default
urllib.error.HTTPError: HTTP Error 400: Bad Request
Here is the list of installed packages:
netmetr 1.6.0-3.7-1
foris-netmetr-plugin 4.6.2-3.7-1
foris-netmetr-plugin-l10n-cs 4.6.2-3.7-1
foris-controller-netmetr-module 0.4.2-3.7-3
reforis-netmetr-plugin 0.1.1-3.7-1
reforis-netmetr-plugin-l10n-cs 0.1.1-3.7-1
Any help, please?
