Segmentation fault when attempting to install transmission-web
I’m currently attempting to configure transmission, and by reading up on the transmission-client-configuration thread I find that the web part isn’t pre-installed, while everything else is.
So I’m now attempting to install transmission-web by going to LuCI > System > Software, then searching for transmission-web (For reasons unknown it does not appear if I just search for transmission !)
However instead of just installing the component, I get this:
What to do about it?
Installing packages from the LuCI web interface is broken at the moment. You’ll need to install from the command line.
Thanks so much!
Worked nicely from the command line.
