Segmentation fault, Omnia
I cross-compiled my program and everything worked fine. Now I am cross-compiling a new version that has libzmq as a dependency and I am getting segmentation fault when I want to run the cross-compiled program. I used gdb to find out more about the fault and this is the result:
Cannot access memory at address 0x258
Program received signal SIGSEGV, Segmentation fault.
0xb6faa2a8 in ?? () from /lib/ld-musl-armhf.so.1
Does anyone know how to solve it?
Thank you.
