After upgrade Omnia from TOS 5.4.4 to TOS 6, I can see that NetMetr test is running every day at 04:23:
But Autostart is disabled in reForis:
And also in configuration file:
root@turris:/tmp# cat /etc/config/netmetr
config settings ‘settings’
option autostart_enabled ‘0’
option control_server ‘control.netmetr.cz’
option max_history_logs ‘30’
option uuid ‘357d83d6-xxxx-xxxx-xxxx-xxxxxxxxxxxx’
option client ‘HW-PROBE’
option sync_code ‘xxxxxxxxxxxx’
option autostart_delay ‘1392’
option protocol_mode ‘prefer_6’
list hours_to_run ‘4’
I tried to enable autostart in ReForis, save it, logout/login to reForis, disable autostart and save, but there is no change.
Any idea, how to disable autostart of NetMetr test?
