Různé err v logu - jejich původ a závažnost?
#1
2019-01-06 07:00:01 info /usr/sbin/cron[6944]: (root) CMD (/usr/share/server-uplink/contract_valid.sh)
2019-01-06 07:00:01 info /usr/sbin/cron[6945]: (root) CMD (netmetr --autostart --dwlhist --rwait 1800 &)
2019-01-06 07:00:01 info /usr/sbin/cron[6950]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-06 07:00:01 info /usr/sbin/cron[6949]: (root) CMD (/usr/share/firewall/turris-download)
2019-01-06 07:00:01 info /usr/sbin/cron[6946]: (root) CMD (/etc/init.d/haas-proxy restart  >/dev/null 2>&1)
2019-01-06 07:00:01 info /usr/sbin/cron[6947]: (root) CMD (/usr/share/nikola/bin/nikola.sh)
2019-01-06 07:00:01 info /usr/sbin/cron[6942]: (root) CMD (/usr/share/server-uplink/registration_code.sh)
2019-01-06 07:00:01 err server_uplink[]: Failed to download contract status
2019-01-06 07:00:02 info nikola[]: (v43) recognized WAN interfaces: eth1, lo
2019-01-06 07:00:30 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2019-01-06 07:00:56 info nikola[]: (v43) Establishing connection took 0.580989 seconds
2019-01-06 07:00:56 info nikola[]: (v43) Logrotate took 0.004798 seconds
2019-01-06 07:00:56 info nikola[]: (v43) Syslog parsing took 0.047203 seconds
2019-01-06 07:00:57 info nikola[]: (v43) Session init took 0.593541 seconds
2019-01-06 07:00:57 info nikola[]: (v43) Records parsed: 55
2019-01-06 07:00:57 info nikola[]: (v43) Records after filtering: 40
2019-01-06 07:00:57 info nikola[]: (v43) Records filtering took 0.010722 seconds
2019-01-06 07:00:57 info nikola[]: (v43) {'msg': 'Data were inserted into work queue.'}
2019-01-06 07:00:57 info nikola[]: (v43) Sending records took 0.058816 seconds
2019-01-06 07:01:01 info /usr/sbin/cron[7149]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-06 07:02:01 info /usr/sbin/cron[7188]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2019-01-06 07:02:01 info /usr/sbin/cron[7189]: (root) CMD (nethist_stats.lua)
2019-01-06 07:02:01 err server_uplink[]: Failed to get registration code
#2
Tohle me tak trosku irituje taky. Uz jsem se po foru nekolikrat snazil ziskat nejake detailnejsi info (nejen pro tuhle hlasku, mam jich v zaloze jeste par … )
… ono otazkou je, zda-li tato hlaska je rekneme “chtena” protoze server api.turris.cz/challenge.cgi cas od casu neodpovi v limitu (120sec) a nebo zda-li je neco spatne na me strane a blbne to porad a ja bych neco mel poresit ). >> /usr/share/server-uplink/registration_code.sh pri spusteni z ruky mi obvykle v dobe kontroly dava rc=0.
btw: o kus nize (v tom vystupu z logu) je jina “sluzba” co se ji taky nepodarilo dobouchat na api.turris.cz …
Takze to beru, ze je to oukej.
#3
Já byl v jisté době zvyklý, že log byl zcela čistý. Pokud vidím v logu err (chyba) tak cítím nutnost něco spravovat. Netuším, zde je to jen u mně nebo u všech uživatelů, jestli jsem si něco zmastil, zda je to důležité nebo prkotina, která vyšumí. Taky člověk neví, zda s tím má prudit emailem podporu. Ta ostatně nemá rychlou reakci, 14 dní, žádná míra. Přitom by stačilo reagovat … buďte v klidu, nejedná se o nic závažného.
Na tyto možná méně podstatné, ale typické error hlášky v logu by mělo být jedno jediné spešl téma.
Admini !!! řekněte si jak to chcete ?
#4
Vybrány další jednotlivosti
2019-01-06 23:02:09 err turris-firewall-rules[]: (v63) Failed to download https://api.turris.cz/firewall/turris-ipsets.gz.sign
2019-01-08 08:01:28 err kresd[19847]: [priming] cannot resolve address 'm.root-servers.net.', type: 28
2019-01-08 08:01:29 err kresd[19847]: [priming] cannot resolve address 'm.root-servers.net.', type: 1
2019-01-08 09:00:09 err nikola[]: (v43) Exception thrown: failed to initialize crypto library
2019-01-08 09:00:09 err nikola[]: (v43) Exception traceback: [<FrameSummary file /usr/lib/python3.6/site-packages/nikola/__main__.py, line 186 in main>, <FrameSummary file /usr/lib/python3.6/site-packages/nikola/rpc_wrapper.py, line 30 in __init__>]
2019-01-08 09:00:15 err server_uplink[]: Failed to get registration code
#5
I tried to get the answers too - in Failed to download turris-ipsets.gz.sign or Certificate for api.turris.cz but no answer …
#6
Cca 1x denně “crypto”
2019-01-09 21:00:01 err server_uplink[]: Failed to download contract status
2019-01-09 21:00:02 info nikola[]: (v43) recognized WAN interfaces: eth1, lo
2019-01-09 21:00:09 err nikola[]: (v43) Exception thrown: failed to initialize crypto library
2019-01-09 21:00:09 err nikola[]: (v43) Exception traceback: [<FrameSummary file /usr/lib/python3.6/site-packages/nikola/__main__.py, line 186 in main>, <FrameSummary file /usr/lib/python3.6/site-packages/nikola/rpc_wrapper.py, line 30 in __init__>]
#7
No tímhle se není potřeba znepokojovat, pokud jsou tedy v malém množství. Třeba v případě že internet vůbec nejde, můžou se tam vyskytovat periodicky. Vidím to jen dost výjimečně; zatím tedy nevím přesně proč.
#8
2019-01-16 19:00:01 err server_uplink[]: Failed to download contract status
2019-01-16 19:00:02 info nikola[]: (v43) recognized WAN interfaces: eth1, lo
2019-01-16 19:00:14 info nikola[]: (v43) Establishing connection took 0.586622 seconds
2019-01-16 19:00:14 info nikola[]: (v43) Logrotate took 0.004578 seconds
2019-01-16 19:00:14 info nikola[]: (v43) Syslog parsing took 0.067535 seconds
2019-01-16 19:00:15 info nikola[]: (v43) Session init took 0.586223 seconds
2019-01-16 19:00:15 info nikola[]: (v43) Records parsed: 71
2019-01-16 19:00:15 info nikola[]: (v43) Records after filtering: 51
2019-01-16 19:00:15 info nikola[]: (v43) Records filtering took 0.011610 seconds
2019-01-16 19:00:15 info nikola[]: (v43) {'msg': 'Data were inserted into work queue.'}
2019-01-16 19:00:15 info nikola[]: (v43) Sending records took 0.032709 seconds
2019-01-16 19:00:34 err server_uplink[]: Failed to get registration code
2019-01-16 19:00:55 err foris-controller[6332]: WARNING:turrishw:unsupported TOS version (on omnia): 3
2019-01-16 19:01:00 err foris-controller[6011]: Last message 'WARNING:turrishw:uns' repeated 3 times, suppressed by syslog-ng on Omnia
