I just wanted to be sure I have set everything properly because my second disk partition is mounted twice…
My storage settings is like this
cat /etc/config/fstab
config global
option anon_swap '0'
option anon_mount '0'
option auto_swap '1'
option auto_mount '1'
option delay_root '5'
option check_fs '0'
config mount
option enabled '1'
option uuid '5d480389-b3ac-4d5d-90d4-88111c83b1cd'
option target '/nas'
option enabled_fsck '1'
Is this all correct? Thank you.
