[Resolved] HELP: WPS? How do I start it (accustomed to a button)
I cannot get WPS to allow me to add a wireless printer…
I would appreciate any help. SSH is working perfectly.
It arrived in the mail today and works great, but no wireless printing yet.
Thank you
sh
Why you want to use WPS - it is worst security issue which you can make…
You can´t add password to printer static ?
Well, if you can assist me with adding the printer I will graciously accept that.
The problem is that the printer is currently unable to print as it is a wireless printer.
Give the following info
  • Printer brand + model
A lot of times you just have to configure the network through the mini-display of the printer.
WPS, is indeed one of the WORST if not THE WORST possible thing to use.
Brother HL2270dw
Thank you for the advice.
I took a quick look at the manual, to configure the wifi not using WPS, you have to connect the printer first using a cable.
I have since connected it using the connection wizard from Brother.
Thank you for the assistance Big_boss!
