I need some help regarding an old Turris Omnia unit that has not been used since a while. I try to reset it, so I can get access back at it, do updates and see if it works fine yet.
I pushed 5 seconds the reset button, then wait it resets, and then when I connect with computer on router IP, it asks me for a password that I can’t find out anywhere Documentation states it should ask me for a new password !
Reset not working ? unit defective ? Firmware really old ?
As I’m not sure which model it is I enclose below an inside picture (looks like I had installed in it an SSD).
By this you did standard reboot, AFIK. See Omnia - Turris Documentation You’ll most probably need factory reset (or flash from internet). Be warned - both of them will remove any of your previous changes/settings… and you’ll not need any password
Thanks for the link as the other tutorial I had found was stating only to hold 5s the reset button ! With that one I got the proper reset procedure which worked fine Once resetted it made all its updates from v3 to v5 and now running the mode modern GUI and so ready for second hand sale
