I’ve got a dog that chewed my power cable and destroyed my antennas . The power cable isn’t that difficult to get as there are many e-shops to obtain it from but the antennas are different story. Impossible to get it via any other source except sectron.cz shop that is listed in the official replacement post by Pepe. The short stockage of the item in the shop is too annoying and even impossible to order - the opposite example of how to run a business!
You’re providing a modular device and I expect HW parts availability to be much better. I mean if someone is expected to wait a long time it’s a big NO as a customer. And please… do not blame the shops… you could/should have thought of it in the beginning and act accordingly.
Are you sure you can’t just buy any dual-band wifi antenna? There should be plenty of them around, probably even in the nearest electro shop (though I agree that dual-band might be a little trickier to get, but nothing horrible).
Btw., if you’re changing antennas, perhaps you can consider buying five of them and remove the diplexer, which is just another attenuator in the signal path.
Sure alternative antennas do the job but I prefer the original ones. 1 of 3 antennas works so I planned to buy 2 units. It just seems like I have to replace all of those. Never mind as of now. At least I got the power supply lmao.
Most difficult is to get diplexers, all other parts are ok. But it would be great to have possibility to buy Mainboard for Turris Omnia as a replacement part.
